Calibration - Calman 5 D8000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-23-2013, 09:24 PM - Thread Starter
stryderlis's Avatar
Quoted: 20 Post(s)
Recalibrated my Samsung d8000, anything I can do better?
stryderlis is offline
post #2 of 11 Old 10-23-2013, 11:22 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Depends on the accuracy of the meter and whether you did the stuff that does not use the software, correctly. Add to it that graphs also lie ...
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 11 Old 10-24-2013, 06:07 AM - Thread Starter
stryderlis's Avatar
Quoted: 20 Post(s)
I used an i1 display pro colormeter. I'm assuming the only way to know if it's accurate is to profile it with a spectrometer but I don't have one of those. I'm assuming the stuff that doesn't use the software like brightness and contrast?
post #4 of 11 Old 10-24-2013, 07:31 AM
Quoted: 40 Post(s)
Liked: 142
Greetings
The software stuff doesn't matter much if you messed up the other stuff. (There's more to calibration than software and hardware.)
Regards
post #5 of 11 Old 10-24-2013, 07:52 AM - Thread Starter
stryderlis's Avatar
Quoted: 20 Post(s)
Care to elaborate what other stuff you are referring to? I always thought you set your brightness and contrast then hook up the meter and run the software to measure the patterns, in general.
post #6 of 11 Old 10-24-2013, 11:22 AM
Quoted: 40 Post(s)
Liked: 142
Greetings
http://www.tlvexp.ca/2013/04/calibration-knowledge-challenge/
What I am talking about is for you to go take this fun quiz and tell us how you did if you feel you have a good understanding of the calibration process. You should ace it. smile.gif
regards
post #7 of 11 Old 10-24-2013, 12:32 PM
ConnecTEDDD's Avatar
Quoted: 1053 Post(s)
Liked: 1518
There things beyong pretty charts that can be caused by faulty Display controls or extreme use of TV controls (to get low dE numbers) than can produce distortions, discoloration, clipping, banding, posterization, crushed shadow details, raised black levels of your display, things that meter's can't see.
There is an example of what patterns you have to check here, to check for these types of errors.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #8 of 11 Old 10-24-2013, 03:55 PM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
The man asked a simple question. The Question is ! Take a look at his charts and do you see anything that would Help him, that you can tell from his charts.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is offline
post #9 of 11 Old 10-24-2013, 04:06 PM
Liked: 1518
He has to moved to the CMS calibration now.
post #10 of 11 Old 10-25-2013, 06:48 AM
ellisda1's Avatar
I'd first spend some time with the 10 pt WB calibration. On my D8000 I can get a nearly flat gamma plot, with GS dEs below 0.5 for the entire range. Looks like you have too much "blue" for the entire range and the gamma could be much better.
Then you can look at the CMS. On my D8000, Blue always meters a bit low (i1Pro), but I think it's probably because of low light intensity. I've recently added a Lumagen mini and it makes the calibration go really easily...
ellisda1 is offline
post #11 of 11 Old 10-25-2013, 08:15 AM - Thread Starter
stryderlis's Avatar
Quoted: 20 Post(s)
I redid my 10pt, it seems to look better now. I downloaded the new Calman and it messed up my scale and I couldn't figure out how to adjust the scale until yesterday. Now that I'm able to zoom in, I was able to fine adjust my 10pt. See new graphs, let me know what else might be better improved. I also did the CMS while I was at it.
Image generated by GPL Ghostscript (device=ppmraw)
Reply Display Calibration
