Is an i1Pro Rev A worth purchasing? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 10-29-2013, 11:03 AM - Thread Starter
dschlic1's Avatar
Quoted: 72 Post(s)
Liked: 27
I have an opportunity to purchase an i1Pro Rev A. It reportedly passes all diagnostics. What would be a fair price for this unit? $150?
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #2 of 20 Old 10-29-2013, 01:16 PM
turbe's Avatar
Liked: 95
That would be the maximum $ IMO..
Have the seller send you the results of the i1 Diagnostics, verify serial number and date of test.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #3 of 20 Old 10-29-2013, 02:35 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 846
Tom did comparison of a new I1Pro 2 and a D3 using his reference Jeti 1201. see link.
http://www.avsforum.com/t/1487208/colorimeters-and-spectrographs-questions/30#post_23780172
You may be better off getting a new D3 for now. If you find you like being a DIY calibrator then later on look for a good I1Pro 2 for profiling your D3.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #4 of 20 Old 10-29-2013, 03:52 PM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
ss
that data might not tell the full story, especially for LCD displays (CCFL or LED backlit)... since the samples used could greatly influence the results, there is just too much variation with LCD displays for any one table to be accurate 100% of the time
also, that data is not favorable for plasma owners, since the spectro easily outdid the D3's plasma table
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #5 of 20 Old 10-29-2013, 05:49 PM
Liked: 559
There is always that possibility
Let me ask you this, when you take WRGB readings what % of light output do you use. 75% maybe.
So lets say you use triplets at a very low light level, I would think the D3 will be the winner. Ideally what you want to use is a Good D3 and profile it with a Good I1Pro 2, or better still use a K10-A and profile it with a Jeti.
ss
that's what I do, profile my C6 to my i1Pro rev D
post #6 of 20 Old 10-29-2013, 05:51 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 846
There is always that possibility.
But I would think Tom would be able to explain better than me.
ss
post #7 of 20 Old 10-29-2013, 11:06 PM
stryderlis's Avatar
Quoted: 20 Post(s)
What's the difference between all the different 1i pro revs? I know the Rev D is the one to get but what about the others assuming they have been checked out by x-rite. Anyone know the advantages of each version vs the previous version?
stryderlis is offline
post #8 of 20 Old 10-30-2013, 10:47 AM - Thread Starter
dschlic1's Avatar
Quoted: 72 Post(s)
Liked: 27
I have the i1Display Pro (i1D3). I was thinking about acquiring a spectro to profile the i1D3. In my research it appears that all revs are equally accurate, however the Rev A is about twice as slow as the Rev B and D. Because I will be using it for profiling, speed is not a real issue.
dschlic1 is offline
post #9 of 20 Old 10-30-2013, 11:15 AM
ConnecTEDDD's Avatar
Quoted: 1048 Post(s)
Liked: 1516
The accurancy between Rev A - B - D has remain the same. If the unit is not tested, it's performance is unknown. i1Diagnostics can't tell you enough informations about it's performance on Emissive measurements (for Displays).
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #10 of 20 Old 10-30-2013, 11:17 AM
Liked: 1516
What are the differences between Rev A, B & D i1 Pro devices?
In April 2005, GretagMacbeth (now part of X-Rite) began shipping a revised version of the i1 Pro Spectrophotometer in all end user packages.
The Revision B instrument is much faster than the older Revision A instrument, yet there is no difference in accuracy between the two.
The Revision B instrument also has improved Teflon pads on the bottom to reduce paper scratching if you use the old style ruler.
In August 2006 Rev D was introduced, with changes made to the material content to comply with the Europe RoHS legislation.
Parts of the components were replaced with new materials to make them lead-free.
There was no change to performance in Rev D instruments; in terms of speed and accuracy they are the same as Rev B.
In order to clearly identify the i1 Pro devices in the field a new revision had to be introduced.
But the Rev. A i1PRO it's propably a 10 years old meter...
post #11 of 20 Old 10-30-2013, 11:20 AM
Liked: 1516
Cleaning the Eye-One
The Eye-One is a precision measurement device. To ensure proper functionality and a long life time it is required to store the Eye-One in a dust free and dry place.
If during the testing procedure you are requested to clean the white reference and the measurement head proceed as follows:
Unlock the measurement head by turning it clock wise and lift it carefully.
Clean the inserted glass plate on both sides using compressed air. Cans with compressed air can be purchased in any store for photographic supply. DO NOT try to blow away dust with your breath! DO NOT try to clean the glass plate with a cloth! To clean the white reference use a soft cloth with water and very little soap or alcohol. Dry the white reference carefully also using a soft cloth. Once dry use compressed air to remove dust from the white reference.
DO NOT use any scratching or aggressive detergents to clean the white reference. Usage of such detergents may cause damage to the white reference and your Eye-One might not work properly afterwards.
post #12 of 20 Old 10-30-2013, 11:51 AM
stryderlis's Avatar
Quoted: 20 Post(s)
Is there no Rev C? I see you guys provided information for Rev A, B and D. So it looks like they just skipped C?
post #13 of 20 Old 10-30-2013, 12:12 PM
turbe's Avatar
Liked: 95
I believe Michael Chen has one and it's good (checked to his Jeti 1211).
ControlCAL™
turbe is offline
post #14 of 20 Old 10-30-2013, 12:22 PM
Liked: 559
which revisions does the i1pro2 come in?
post #15 of 20 Old 10-30-2013, 12:57 PM
turbe's Avatar
Liked: 95
only one, Rev E
Some specs for A - E: http://www.xrite.com/documents/literature/en/L7-518_i1PRO-i1PRO2_en.pdf
ControlCAL™
turbe is offline
post #16 of 20 Old 10-30-2013, 01:54 PM
Liked: 1516
Yes, but Michael knows how+where to store it.
post #17 of 20 Old 10-30-2013, 07:59 PM
Liked: 559
isn't his an i1 beamer? also, I think he mentioned it was a bit off in measuring absolute light output (in his colorimeter tables article)
post #18 of 20 Old 10-30-2013, 10:47 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Yes, it is a beamer ... and the light output reading is always lower than what the other meters read. That part is irrelevant in the calibration process of course since we don't shoot for light output targets. smile.gif
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #19 of 20 Old 10-31-2013, 09:39 AM
turbe's Avatar
Liked: 95
Michael, I can't find your related posts, how old is it?
ControlCAL™
turbe is offline
post #20 of 20 Old 10-31-2013, 11:47 AM
Quoted: 40 Post(s)
Liked: 142
Greetings
2002 time frame ... got it with colorfacts ... boy that was an eternity ago.
regards
Reply Display Calibration
