Calman RGB... how do you use Direct Display Control? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-29-2013, 10:19 AM - Thread Starter
earwicker7's Avatar
According to Calman RGB, my monitor has DDC capabilities. How do you use them? It said something about the monitor needing to be connected with a USB cable, but I don't see a USB port on the monitor. What am I missing?
earwicker7 is offline
post #2 of 5 Old 10-29-2013, 11:52 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
does it have a serial port?
if yes, then if your computer has a serial port, need a straight thru
serial cable.
if your pc has a usb, you need a usb to serial cable/adapter.
Loving D65
CalWldLif is offline
post #3 of 5 Old 10-29-2013, 12:53 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
You don't need a USB connection.
If the Client detects DDC it will use it. You can open the preferences to see if it's detected.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 5 Old 10-29-2013, 04:25 PM - Thread Starter
earwicker7's Avatar
serial cable.
Do computers even have serial ports anymore? Hmm, I'll have to check and see if I have an adaptor at home in my box of spare PC parts.
It did detect it, but I got a message about needing a USB cable, although I'm not at home now, so I might have misunderstood the message.
When it does work, does it just adjust brightness and contrast, etc., so that you don't end up with your arm going numb from adjusting the monitor's controls?
post #5 of 5 Old 10-30-2013, 09:26 AM - Thread Starter
earwicker7's Avatar
I got it to work without an additional cable. There was a button which needed to be clicked, and that was it. Woohoo!
Reply Display Calibration
