Is there still no software that preserves software calibrated / ICC monitor profiles in Windows when launching games??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 11-02-2013, 04:58 PM - Thread Starter
MonarchX's Avatar
Liked: 31
In summary - Windows resets saved software calibration / ICC monitor profiles when games are launched (most of the time). There is yet to be a tool that would force saved ICC monitor profiles to be used by any game for nVidia video card owners. AMD allowed PowerStrip to force such profiles using "direct write to hardware" method, which nVidia does not allow on their hardware. There are several programs, such as Monitor Calibration Wizard, Color Clutch, Borderless Window Mode, etc., but none are effective, most do not work, others can heavily reduce frame rate (Borderless Window Mode).
You can read more about it here - https://forums.geforce.com/default/topic/501853/nvidia-forever-ignoring-custom-color-profile-support-in-full-screen-games-collaboration-thread-/
I am SO surprised that nobody could come up with a tool that really does work for all cards and all games. Someone told me that Spyder3 software successfully forces ICC profiles for all games. Is that true? I know that i1 Profiler that came with my i1 Display Pro colorimeter does NOT force ICC profiles when games are launched. Why can't CalMAN come up with a tool that could do it? They could make good money for selling software that can force ICC profiles!
I know this problem persists in Windows XP, Vista, and 7. Could someone confirm that it still exists in Windows 8 and/or 8.1?
MonarchX is offline
post #2 of 26 Old 11-03-2013, 02:45 AM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
SpaceMatch DCM will work, but uses LUTs rather than ICC profiles for very obvious reasons...
It uses the VCGT capability of any/all graphics cards, and can be set and not affected by any ICC stuff.
It can read any active ICC, and then save the data as a LUT for direct use without needing any ICC active capability..
See: http://www.lightillusion.com/spacematch.html
Cheers,
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #3 of 26 Old 11-03-2013, 09:09 AM - Thread Starter
MonarchX's Avatar
Liked: 31
Awesome, but not affordable even for graphics enthusiasts... It is something that would be used by a professional game developing studio.
At least there is hope that such a program is possible. A cheaper, crippled and highly limited version that would only convert existing ICC profile into a force-able LUT would be awesome. Any person with a colorimeter like i1 Display Pro and Spyder3 would be potential buyers.
MonarchX is offline
post #4 of 26 Old 11-03-2013, 07:54 PM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
The command line utility dispwin from the ArgyllCMS package can read profile vcgt tags from either active or stored profiles and load them into the video card hardware LUTs for you. Or you can use the gui front-end dispCalGui. Runs on mac, pc, or linux (for free)
zoyd is offline
post #5 of 26 Old 11-04-2013, 02:05 AM
AV-Freak's Avatar
Just use a monitor with an internal 3D or matrix LUT.
AV-Freak is offline
post #6 of 26 Old 11-04-2013, 10:26 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
First off games don't use ICC, the game it self has to be written to take advantage of ICC on windows. So you'll likely never see that.
As for the graphics card LUT, the only reason a game would change the LUT would be because the game designers wanted to change the LUT. The call to update the LUT in windows is an open interface, there is nothing any software can do and no callback from the OS when this happens. So often times the in game brightness or gamma slider will reset the systems gamma table, and their is no way any other software can be notified this happens.
So it is not possible with the windows API to do this, you'd have to write a custom video card driver (Also simply not possible). We can push the LUT based on a timer, which is what datacolor does, but their isn't a true solution to other applications updating your calibration data.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #7 of 26 Old 11-05-2013, 09:31 AM - Thread Starter
MonarchX's Avatar
Liked: 31
PowerStrip can do it for AMD cards. It writes directly to hardware, which Nvidia does not allow. Games don't just change gamma, but also white balance and etc...
MonarchX is offline
post #8 of 26 Old 11-05-2013, 09:33 AM - Thread Starter
MonarchX's Avatar
Liked: 31
Even for nvidia cards??? Nvidia strictly prohibits writing directly to hardware...
MonarchX is offline
post #9 of 26 Old 11-05-2013, 09:52 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
It's an operating system API call.
Joel Barsotti
SpectraCal
sotti is offline
post #10 of 26 Old 11-05-2013, 09:55 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
It's a 1D LUT, anyone can overwrite, 1D LUTs can change gamma or white point or both. Game designers use it for gamma, color calibration apps use it for calibration.
via directX:
http://msdn.microsoft.com/en-us/library/windows/desktop/bb174434(v=vs.85).aspx
via windows api:
http://msdn.microsoft.com/en-us/library/windows/desktop/dd372194(v=vs.85).aspx
Any application can call those at any time. There are no calls to lock, and no way to register for a callback when that happens. The reason this is an issue is not because developers don't care, it's because microsoft hasn't provided us a means of enforcement.
Joel Barsotti
SpectraCal
sotti is offline
post #11 of 26 Old 11-08-2013, 08:50 AM - Thread Starter
MonarchX's Avatar
Liked: 31
via directX:
via windows api:
Now I am confused even more. First you say that is it not possible and it would require writing a whole new driver. Then people posted several apps that supposedly make it possible and I know for a fact that PowerStrip makes it possible for AMD video cards, and then you say that it is a 1D LUT and any program can overwrite it. So, how can it be not possible if any program can overwrite it? That makes no sense to me.
I am extremely perplexed...
MonarchX is offline
post #12 of 26 Old 11-08-2013, 09:10 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
You misinterpreted their responses. They were showing you that any app can write the LUT. You had said nvidia locks people out of writing directly to hardware. The software mentioned above, most likely uses the same API calls since they've been around since windows 2000, it may also have had an earlier implementation that work on windows 9x.
Joel Barsotti
SpectraCal
sotti is offline
post #13 of 26 Old 11-08-2013, 09:11 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Originally Posted by lanbaidiluo View Post
good,that it is a 1D LUT and any program can overwrite it. So, how can it be not possible if any program can overwrite it? That makes no sense to me.
pNEg
Any app can overwrite it.
Joel Barsotti
SpectraCal
sotti is offline
post #14 of 26 Old 11-08-2013, 11:59 AM - Thread Starter
MonarchX's Avatar
Liked: 31
So with those apps, ICC profiles can be set/forced in games without reverting back to default Windows ICC, right???????
MonarchX is offline
post #15 of 26 Old 11-08-2013, 12:20 PM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
The game itself is the "app" that preferably would do it...
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #16 of 26 Old 11-08-2013, 01:17 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
which app what?
Any app/game/utility/windows executable can change the 1D LUT at anytime.
Nothing, not a single app/game/utility can prevent other apps from changing the 1D LUT.
Joel Barsotti
SpectraCal
sotti is offline
post #17 of 26 Old 11-08-2013, 01:52 PM - Thread Starter
MonarchX's Avatar
Liked: 31
When I say APPS - I mean small utilities, programs, etc. NOT GAMES. So, are there any APPS that could ENFORCE ICC profiles in GAMES? PowerStrip does it 100%, so don't tell me that that can't prevent games from reseting ICC profiles because PowerStrip DOES enforce them. You need to force it AFTER the game has already started and you may need to do once in a while if a game tries to reset it, but in the end, PowerStrip will force the ICC profile in any game. It works only for AMD. I need one for nVidia!
"The command line utility dispwin from the ArgyllCMS package can read profile vcgt tags from either active or stored profiles and load them into the video card hardware LUTs for you. Or you can use the gui front-end dispCalGui."
Would the above quoted app work?
MonarchX is offline
post #18 of 26 Old 11-08-2013, 03:26 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
No, it won't
The games you are having problems with are overwriting your LUT. No one can stop that.
Joel Barsotti
SpectraCal
sotti is offline
post #19 of 26 Old 11-08-2013, 04:37 PM - Thread Starter
MonarchX's Avatar
Liked: 31
No, it won't
But PowerStrip does!!! Are you denying that too?
MonarchX is offline
post #20 of 26 Old 11-09-2013, 11:58 AM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
If this is true, then how come the powerstrip solution only works on AMD and not nvidia cards?
spacediver is offline
post #21 of 26 Old 11-09-2013, 12:03 PM - Thread Starter
MonarchX's Avatar
Liked: 31
I provided a link in the original post to a forum where it is discussed and then I discussed it 3 times in this thread already... So, again... AMD allows software to write directly to hardware, which is what PowerStrip does when it forces selected ICC profiles. nVidia does not allow any software to write directly to hardware, including PowerStrip.
MonarchX is offline
post #22 of 26 Old 11-09-2013, 01:05 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
yep I read through that thread when you originally posted the link. I'm confused by Sotti's response, as he seems to be implying that powerstrip overwrites the LUTs in the same way that games do, and therefore that powerstrip should be able to intervene regardless of what video card you use.
But this is clearly not the case (unless I'm misunderstanding something here)
post #23 of 26 Old 11-09-2013, 06:38 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
It's not an ICC profile. It's a 1D LUT. There is a big difference between the two.
Joel Barsotti
SpectraCal
sotti is offline
post #24 of 26 Old 12-29-2013, 09:48 PM
Yukon Trooper's Avatar
Liked: 26
Could you explain this a bit further? For example, will this override the LUT calls made by games?
Thanks for all the great info in this thread.
Yukon Trooper is offline
post #25 of 26 Old 12-29-2013, 10:18 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
If a game re-establishes its own LUT call, then I believe it will override it. Some games have an option to allow overriding. One solution is to run the game, go back and check if the LUT has changed, and if it has, reload the LUT.
post #26 of 26 Old 12-30-2013, 05:31 PM - Thread Starter
MonarchX's Avatar
Liked: 31
Windowed Borderless Gaming program works like a charm and works with almost every game. Some say that running a game in such a mode will prevent it from utilizing all the PC resources to their fullest, but I ran BioShock Infinite, Sleeping Dogs, and BF4 benchmarks in Fullscreen and Borderless Modes and found that there was no difference in avg, min, and max FPS between the modes.
MonarchX is offline
Reply Display Calibration
