JETI/Klein/Lumagen/eeColor/Discus Virtual COM Port Drivers For Windows 8.1 Released - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ConnecTEDDD
  • 1 Post By sillysally
post #1 of 6 Old 11-07-2013, 02:11 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1518
FTDI VCP CDM 2.08.30 WHQL Certified for Win 8.1 32/64-bit can be downloaded from here.
JETI / Klein / Discus meters or Lumagen / eeColor Video Processor-LUT Boxes are using these drivers.
Virtual COM port (VCP) drivers cause the USB device to appear as an additional COM port available to the PC.
Application software can access the USB device in the same way as it would access a standard COM port.
Plutotype likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2 of 6 Old 08-06-2014, 11:27 AM
Quoted: 1393 Post(s)
Liked: 587
Ted
Is there any reason not to use 2.10?
JimP is offline
post #3 of 6 Old 08-06-2014, 11:31 AM - Thread Starter
Liked: 1518
Originally Posted by JimP View Post
Ted
I forgot to update this thread for the 2.10 release notes.
post #4 of 6 Old 08-06-2014, 02:05 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Ted the latest FTDI drivers are 2.10.00 for Xp and newer Windows up to 8.1.
You may want to change your OP to read the same, these drivers are not just for Windows 8.1.
Also when downloading these drives you may want to use 2.10.00 WHQL Certified setup exe.
Its all automatic, just open the zip file and click on the exe..
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #5 of 6 Old 08-06-2014, 02:29 PM - Thread Starter
Liked: 1518
ss
Hi ss,
2.08.00 drivers released at 01 August 2013 but with no support for windows 8.1
Later @ early November; when I posted here about this... 2.08.00 for Windows 8.1 came out, that's why you see that thread tittle.
post #6 of 6 Old 08-06-2014, 03:24 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Originally Posted by ConnecTEDDD View Post
Hi ss,
Hello Ted,
Yes I know, but when I saw Jim's post I thought you may want to update.
I am sure you forgot all about this thread you started. Knowing you, you are always on top of these kinds of updates.
Like your updates for you calibration disc, you are second to non.
ss
ConnecTEDDD likes this.
Reply Display Calibration
