Free Test Patterns to Check for White Crush at Higher APL's on Plasma (5% step grayscale with larger than 12% APL patterns)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 11-12-2013, 11:39 AM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 2316 Post(s)
Liked: 716
I know there are many free pattern discs or other formats like .mp4 files, especially for plasma calibration. I have found that my S60 plasma seems to show a severe dropoff in top end gamma (especially 95%) when the Contrast in Cinema mode, PB Mid, is turned up past the default 85, but this only occurs with larger APL patterns, like 12% (it doesn't occur with 10% APL, I've checked). I'm wondering if there are 13%, 14%, or larger (fixed APL) patterns available for grayscale (21-point, 5% steps) on any of the free pattern discs/files available on this forum.
It has to be APL, not standard, since I want to measure on-screen gamma (factor out ABL).
It should have 5% steps, so I can look at 95% stim.
It should be larger than 12% of total screen area, since I already have 12% APL on CMD HD and 10% APL on GCD.
I basically trying to find the brightest contrast setting that doesn't crush whites/highlight details with moderate to high APL content. Standard windows are misleading for this, since they are affected by ABL, especially at the higher stim levels (near white). I can get 50 fL max light output in Cinema mode (with contrast 90 or higher and 10% standard windows), but only 40 fL with default contrast (85). To be fair, I'm not just looking at 95% stim, but basically every level 75% stim and above (75, 80, 85, 90, 95).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #2 of 38 Old 11-12-2013, 04:18 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
If you are able to set your video card to full range over hdmi you could use the HCFR pattern generator "near white" sequence to do this test. This will output patterns in 1% increments (as many as you want) starting at 100% (level 235) - # of patterns. The patterns can also be set to any area with any level of background stimulus. You'll also need to load a linear calibration to the video card if you want to measure the correct display white balance.
zoyd is offline
post #3 of 38 Old 11-12-2013, 06:28 PM
zoyd's Avatar
Liked: 1064
I just did this test because I was curious. There was no significant deviation from the desired transfer function until I hit about 20% area patterns which start to roll off above 95% input level. By 24% you can see significant luminance roll-off at about 92% input level.
If you look at the gamma graph when you do this it gets pretty noisy above 90% due to the ratio of small numbers so I prefer to look at the luminance graph instead. Plotted is the %Luminance vs. %Stimulus. All window sizes are on a 22% fixed background. Even with the drop in output using the 24% size the white balance errors remained under 2 dE2000.
Note that luminance values above the straight line mean the display is reaching peak output before it should (lower effective gamma) due to the decrease in peak luminance.
15% Area
18% Area
20% Area
22% Area
24% Area
zoyd is offline
post #4 of 38 Old 11-13-2013, 01:07 AM
Barsk's Avatar
Quoted: 42 Post(s)
Hmm, if the pattern in use in not a contant energy pattern then you have some fluctuation that can cause the ABL circuits to cut in when you get to the highest IREs. That could also be an explanation to the drop-off in gamma.
And just to clear out ny misunderstanding, when saying drop-off. If the gamma decreases, then luma has actually increased from what it should be.
I tend to find my clipping point by using constant measurements and increase contrast until color balance gets off. That seems to be working fine. But I am not sure that covers all possible problems such as CMS and gamma nonlinearities.
Barsk is offline
post #5 of 38 Old 11-13-2013, 01:43 AM
zoyd's Avatar
Liked: 1064
Think of gamma as a ratio, there are two ways gamma can go down at a particular video level, either the luminance goes up or the peak luminance goes down. We are discussing the later case.
zoyd is offline
post #6 of 38 Old 11-13-2013, 01:52 AM
Barsk's Avatar
Quoted: 42 Post(s)
You are correct. Didn't think of that.
Barsk is offline
post #7 of 38 Old 11-13-2013, 04:59 AM
ndaa75's Avatar
Zoom or overscan function?
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #8 of 38 Old 11-13-2013, 08:21 AM - Thread Starter
Liked: 716
to be clear, I'm referring to a drop off in point gamma
for example with contrast 90, and 12% APL windows, gamma at 95% was 0.8 (target was 2.4 in that case)
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #9 of 38 Old 11-13-2013, 08:36 AM
ndaa75's Avatar
That's a big drop - presumably you took a 100% measurement also?
ndaa75 is offline
post #10 of 38 Old 11-13-2013, 08:36 AM - Thread Starter
Liked: 716
my question still stands: are there are larger than 12% APL patterns in 5% (or finer near white) increments for use in a BD player/PS3?
using my laptop as a pattern generator seems likely to cause issues and I'm not sure the zoom or overscan function is the best choice either
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #11 of 38 Old 11-13-2013, 08:37 AM - Thread Starter
Liked: 716
yes, I did a series read in CalMAN 5 (21-points)
I have since changed overall gamma to 2.2 and I can post 21-step grayscale readings using the 12% APL windows on your disc for Contrast 85, 86, 87, 88, 89, 90 (after 90 the image stops getting brighter with this pattern size).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #12 of 38 Old 11-13-2013, 08:42 AM
ndaa75's Avatar
Other than the overscan or zoom (which may I note I have tried with no notable issues) im not sure.
ndaa75 is offline
post #13 of 38 Old 11-13-2013, 11:58 AM - Thread Starter
Liked: 716
Here are the 21-pt readings using the CMD HD Disc's 12% APL patterns. I measured gamma (and deltaL) for Contrast 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, and 85 again (to account for meter drift). Target gamma is 2.26, because the initial read with 85 was 2.27 and the final read with 85 was 2.25. Let me know which Contrast setting appears best in terms of visible gamma errors while maximizing light output at 100% white. The C6 was unprofiled for these readings, so ignore the grayscale color readings.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #14 of 38 Old 11-13-2013, 12:16 PM - Thread Starter
Liked: 716
I think 88 is the highest setting before the deltaL's get much higher for the last third of the grayscale. I took more measurements just to be 100% sure:
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #15 of 38 Old 11-13-2013, 12:38 PM
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2136
Have you tryed to use CalMAN 5 Dynamic Range workflow page using the Dynamic Range Chapter of the Ted's LightSpace CMS Calibration Disk you got?
If you tryed it, what Contrast Setting gave you the most linear curve of your near reference white of your display?
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #16 of 38 Old 11-13-2013, 12:41 PM - Thread Starter
Liked: 716
I'm using the 12% APL patterns on the CMD HD Disc for this since this behavior doesn't occur with smaller pattern sizes like 10% or 11% and I need to use a fixed APL pattern to make sure the gamma numbers at the top end are not affected by ABL.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #17 of 38 Old 11-18-2013, 02:44 PM - Thread Starter
Liked: 716
I did some more tests using fixed APL patterns of various sizes/types...
Contrast is at 100 in Cinema mode, PB Mid:
Note that I've included 11 and 21 point grayscale reads from Ted's disc just for comparison purposes (since those are the patterns I use for actual calibration).
ConnecTEDDD likes this.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #18 of 38 Old 11-18-2013, 02:53 PM - Thread Starter
Liked: 716
What I've found is that only the 12% APL patterns show the undesirable gamma behavior in the top third of the grayscale... lower and higher (fixed APL) patterns don't show any such effects, even with contrast turned up to max (100).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #19 of 38 Old 11-19-2013, 08:36 AM - Thread Starter
Liked: 716
Anyone know why the 12% APL patterns are off but larger and smaller ones are not? Is this odd behavior on the display or are the patterns off somehow (either from the download/decompression/burning process or an issue with the RGB triplets in the source file)?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #20 of 38 Old 11-19-2013, 01:42 PM
ndaa75's Avatar
I've checked the triplets in Photoshop is evening and all seems ok. I'll do a run tomorrow and compare.
ndaa75 is offline
post #21 of 38 Old 11-19-2013, 02:43 PM
ndaa75's Avatar
VT30 default gamma settings, contrast mid, ISF mode
Photoshop .tga file 12% APL. Window triplet 213, 213, 213
ndaa75 is offline
post #22 of 38 Old 11-19-2013, 02:54 PM
ndaa75's Avatar
Contrast max, gamma default.
ndaa75 is offline
post #23 of 38 Old 11-20-2013, 10:09 AM
ndaa75's Avatar
Perhaps your settings in combo with that pattern type are pushing the limits with the ABL really kicking in. Hence the similarity to a full field graph.
ndaa75 is offline
post #24 of 38 Old 11-20-2013, 10:23 AM - Thread Starter
Liked: 716
Well, higher fixed APL patterns like the APL Large patterns on the AVS disc and the Equal Energy Windows on the Spears and Munsil disc don't do this (and by looking at the 100% white reading, I can see that they are engaging the ABL a lot more so than the 12% APL windows on the CMD disc).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #25 of 38 Old 11-20-2013, 12:04 PM
ndaa75's Avatar
The AVS disk Large APLs are entirely different (not seen the S&M ones) since they don't engage the entire display unlike these larger APL patterns, which is why I made the similarity with full fields. Anyways something isn't right, the patterns check out fine, so other than a skewed dynamic range or the patterns are behaving in the same way as full fields, I cannot help.
ndaa75 is offline
post #26 of 38 Old 11-20-2013, 12:16 PM - Thread Starter
Liked: 716
thanks, anyway
since I don't see any issues with all the other APL pattern types/sizes I have at my disposal, I'm going to leave contrast at 100 and get every last nit of brightness this set has
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #27 of 38 Old 11-25-2013, 01:04 PM - Thread Starter
Liked: 716
I don't quite understand what you mean by this. Those patterns are definitely engaging ABL more since peak light output is much lower with them vs. 12% APL.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #28 of 38 Old 11-25-2013, 01:31 PM
ndaa75's Avatar
What I mean is that the 12% APL on the disk are showing, in your case, similarity to a full field gs run in terms how your gamma curve looks.
ndaa75 is offline
post #29 of 38 Old 11-25-2013, 10:05 PM - Thread Starter
Liked: 716
could be (though I don't understand why), since measuring gamma with full fields looks terrible (due to ABL)
the 7.5% APL windows are fine, though, as are the 10% APL windows on the GCD disk
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #30 of 38 Old 11-26-2013, 12:03 AM
ndaa75's Avatar
The central area is larger on the 12% APL than either of the two other pattern sizes. Could be that this pattern is right on the limit (on your display) up to a certain point in contrast before it starts to exhibit full field pattern type behaviour.
ndaa75 is offline
Reply Display Calibration
