Adjusting Oversaturation through CMS? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-12-2013, 11:32 PM - Thread Starter
Tangled Cable's Avatar
Quoted: 115 Post(s)
Liked: 36
I understand that you aren't supposed to be able to adjust undersaturation through a CMS but I thought I could reduce over saturation with one ... I'm calibrating my W1070 which has a full CMS including individual saturation controls ... but they don't seem to make a difference ... Could I be doing something wrong?
Tangled Cable is offline
post #2 of 9 Old 11-12-2013, 11:49 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
No, unfortunately the gamut can only be made smaller.
Some TVs do have a little bit of headroom, as their default setting already is slightly undersaturated from native.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 9 Old 11-13-2013, 06:07 AM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
Yes, CMS controls should indeed be able to reduce over saturation - as you correctly state, it is not possible to increase saturation...
So, yes, I think you must be doing something incorrectly...
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #4 of 9 Old 11-13-2013, 08:27 AM
Gordon Fraser's Avatar
Quoted: 114 Post(s)
Liked: 149
Steve
Or of course the CMS control may not actually be working in the manner expected...
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #5 of 9 Old 11-13-2013, 08:31 AM
Quoted: 320 Post(s)
Liked: 627
Yep, that is also true, and is common with many internal display CMS operations, and is a reason why external LUT boxes, such as Lumagen, eeColor, etc., exist...
Steve Shaw
LIGHT ILLUSION
post #6 of 9 Old 11-13-2013, 09:48 AM
xvfx's Avatar
Quoted: 408 Post(s)
Liked: 225
I was thinking about this. I may be thinking wrong but what if xvYCC was enabled? that would make the triangle much bigger right? so you could adjust the CMS 100% points to their proper Rec 709 points right? instead of before when it's off as it was undersaturated.
I've never used or seen xvYCC in use but would that cause weird things since no content uses it anyway. Even if the CMS is properly adjusted?…
xvfx is offline
post #7 of 9 Old 11-13-2013, 06:41 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
No, turning xvYCC on will accomplish nothing. xvYCC has to be present in the incoming video signal for it to do anything, In otherwords, the video has to be mastered in xvYCC for anything to happen. Turning on xvYCC and sending conventional consumer video will achieve nothing, you'll get normal old video because the consumer video stream is NOT an xvYCC video stream.
If the CMS controls aren't fixing an oversaturation problem, the controls are not working correctly... and one thing calibrators the world over understand is this: just because a TV has calibration controls doesn't mean the controls work right. Sometimes the controls are mislabeled. So before you give up completely, try other CMS controls to see if they affect saturation or not.
Also try the Color control to see if that affects saturation (up or down) -- some Color controls do, some don't, you can't assume what your control does until you makes some measurements before moving the control and compare those to measurements you make after making an adjustment. If your color control has a range of, say 100, and it is set to 50 and you are trying to increase saturation, I would raise the Color control by about 10 clicks for the second measurement so there' a big enough move to see on the graph in your calibration software. If the saturation does not change significantly, it's likely that your Color control is adjusting color luminance rather than saturation. That can come in handy when a TV has low color luminance and there are no CMS controls... you might be able to use Color to raise luminance enough to eliminate some of the errors. Also, don't assume the measurements you get in one picture mode (like Standard or Cinema, or Dynamic or Movie or Game or whatever) are going to be the same for all picture modes... you may find that 1 or more modes have undersaturated color, but some other mode has much better color saturation so measure all of them... though Dynamic mode is almost always locked out of being able to be adjusted to be accurate... most brands with a mode like that disable calibration controls when you select Dynamic mode.
So... if you need to decrease color saturation.... check all the picture modes and also check how adjusting the Color control up or down affects color (it might change saturation, it might change luminance, it might change both) and see if either of those help you out... and don't forget to adjust all 3 CMS controls for at least 1 color to see what each control really does to the color. Sometimes the CMS controls adjust hue, saturation, and luminance, but they might control 2 of those parameters at the same time. No way to tell without making measurements to see what's going on. Once you understand better what each CMS control is doing to the measured position for each color, you can better determine if they are going to be useful in fixing errors you are measuring.
Tangled Cable likes this.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #8 of 9 Old 11-13-2013, 11:25 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 36
Thanks to all of you for all the great advice. I'm going to take another run at this tonight and see what I come up with.
post #9 of 9 Old 11-14-2013, 09:43 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
If you can find the needed patterns on one of the free pattern disk to do a saturation sweep (not on the avs709 dis) that would be very helpful. My HC3000 tracked rather well and was only out at 100% saturation (no cms to fix it) but I then new it was more accurate for the majority of content then you would think just looking at the single points of the CMS workflow chart.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Reply Display Calibration
