Help Calibrating a Seiki SE65JY25 65" 240HZ Back-Lit LED with a Innolux V645H1_PE1 Panel..What do SSC MUI and ODCLK SSC do? - AVS Forum | Home Theater Discussions And Reviews
Old 11-25-2013, 12:49 PM - Thread Starter
homerjr43's Avatar
Hello,
I just purchased the Seiki SE65JY25 65" and the picture out of the box was not good. I have adjusted the contrast, back light, and color levels a bit. I have also properly adjusted the overscan for 60hz and 24hz material, but I would love to disable the image processing or have some type of control.
Does anyone know what SSC MUI and ODCLK SSC do?
Can anyone help me make some more adjustments, there is no apparent control of the 240hz processing or smooth motion settings? Do these have different names in the locked service menu?
Thanks for your help!
homerjr43 is offline
Old 11-25-2013, 01:30 PM - Thread Starter
homerjr43's Avatar
So after running through a few calibration screens, it appears that the Gamma on the seiki is way out of wack. I cannot adjust it to look good at any value from gamma 1.2-2.4. I am using the test pattern located at http://www.photoscientia.co.uk/Gamma.htm no matter what settings i change the boxes never become gray. They stay colored. Does anyone know how to resolve this?
Old 11-27-2013, 12:21 PM
cutchy32's Avatar
I believe the ssc miu stands for serial synchronous controller memory interface unit and ODCLK SSC is the clock frequency of the controller.
cutchy32 is offline
Old 01-30-2014, 11:25 AM
dawg1020's Avatar
Where did you find the "gamma" setting? Nothing in the service menu simply says "gamma" that I've seen.
dawg1020 is offline
Old 02-03-2014, 01:37 AM
strifllel's Avatar
I bought the 120hz version of this and see a memc setting to disable motion interpolation immediately when I press menu.
Is this not the case for you?
strifllel is offline
Old 02-03-2014, 02:02 AM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1518
Hello, The patterns you tryed to set your gamma are a really waste of time, you need a meter and software to perform gamma calibration.
Calibration without meter/software can't be performed, with a disk you can adjust some basic controls and you will be able to prevent some problems.
The truth is that by using any calibration disk you just preparing the display before start using your meter/software.
Start by selecting the Cinema / Movie Mode of your display bacause this mode has always better performace vs. the other modes of you display.
In case you don't have software/hardware at home, you can set some basic settings of your display.
For example, you can set:
Brightness Pattern to set the Black Level (Brightness Control) of the Display; to prevent crushing of shadow details or raised black levels.
Contrast Pattern to set the White Level (Contrast Control) of the Display; to prevent color detail clipping up to peak white levels and above reference white level color shifts/discoloration.
Use Sharpness Pattern to prevent edge enhancement (halo/ringing effect) or soft contouring (blurring of the image details).
Use Color Clipping Pattern to prevent clipping of each color channel.
Use a Grayscale Ramp to check which color temperature mode (normal/warm1/warm2 etc) of your display looks more neutral to your eyes.
You can use the Colour Reproduction Patterns to check your display's controls / various mode settings / enhancements of your display, if they introducing problems or if they are broken and you have to leave them untouched to prevent new problems. (no smooth color graduations, distortions, discoloration, clipping, banding, posterization, crushed shadow details, raised black levels etc.)
But you can't set your peak light output, perform RGB Balance of your grayscale, calibrate your Primary/Secondary Colors (Hue/Saturation/Lightness), fix your gamma levels etc. for REC.709 without a meter/software.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
Old 02-03-2014, 03:19 PM
Rolls-Royce's Avatar
Quoted: 240 Post(s)
Liked: 354
To add to what TED said, those "monitor gamma" patterns are not accurate because they rely too heavily on your individual eyesight, how much or how little you squint, room lighting, etc. Don't rely on them.
ConnecTEDDD likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
Old 05-13-2014, 02:46 PM
pogotv's Avatar
Hello
I also have one of these Seiki systems.
How did you do your adjustments you described.?
There is nothing in the manual.  Could you detail how its done or point me to a link that would educate me :)
Many Thanks
pogotv is offline
Old 05-13-2014, 03:08 PM
Liked: 1518
Originally Posted by pogotv View Post
Hello
There is nothing in the manual.  Could you detail how its done or point me to a link that would educate me smile.gif
Many Thanks
Hi, you can view these videos for the start:
https://www.youtube.com/user/SpectraCal
Seiki Se65jy25 65 Inch Led Hdtv
