Best Vizio E421VO calibration settings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-04-2013, 12:42 AM - Thread Starter
GilFis's Avatar
Im sorry if this is the wrong thread to put this question at, im new here. If im ok then id like to ask, what are the best calibration settings for this model. An important note is that I mainly use this tv for playing video games from a PS3(and later on ps4).
Thanks for all who can,will, or try to help me out on this one.
GilFis is offline
post #2 of 17 Old 12-04-2013, 01:10 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Is it possible to get a large flashing "copying setting does NOT work" sticky at the top of this subforum?
To answer the question, you can't copy setting and expect a better looking tv. As a matter of fact, you have an above 94% change your set will be worse.
http://www.tlvexp.ca/2012/12/the-fruits-of-copying-settings-the-pioneer-lottery/
Why? thousand of parts your tv is made of all have small tolerances, making each tv unique.
What can you do?
Download a free basic settings disc and do brightness, contrast, geometry and sharpness yourself. Free disc: AVS709 or Mascior's Calibration Disc.
http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
http://www.avsforum.com/t/1463980/masciors-calibration-disc
Beyond that:
1: Pay for a professional calibration
2: buy equipment and spend a few hours (some say more than a 100) trying to learn calibration for your tv set.
GeorgeAB likes this.
Wouter73 is offline
post #3 of 17 Old 12-04-2013, 10:29 AM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
You're perpetuating a stubborn myth. Copying others' settings is not the equivalent of calibration. Please read this "sticky" thread from the top of this section of the forum:
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
GeorgeAB is online now
post #4 of 17 Old 12-04-2013, 12:09 PM - Thread Starter
GilFis's Avatar
I dont have a blue ray or dvd burner, is there another way?
GilFis is offline
post #5 of 17 Old 12-04-2013, 12:12 PM
10k
10k's Avatar
Quoted: 1277 Post(s)
Liked: 1333
If your TV can play files off USB stick you can copy the files onto one and play them that way. Or you could hook a computer up via HDMI and play the files from that. Or stream the files to your ps3 and play them that way.
10k is online now
post #6 of 17 Old 12-04-2013, 12:16 PM - Thread Starter
GilFis's Avatar
Really, but I read that the AVC and that other program are ment to be played on a blue ray player? Do you think ill have success putting the AVC file on a flash drive and playing it through my ps3 would work?
GilFis is offline
post #7 of 17 Old 12-04-2013, 12:22 PM
10k
10k's Avatar
Liked: 1333
The avs709 link provided above ( http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration ) has the files in various formats. Your PS3 should be able to play one of them.
10k is online now
post #8 of 17 Old 12-04-2013, 12:44 PM - Thread Starter
GilFis's Avatar
I noticed that there are some things that the mp4 download does not contain that the other downloads do, are these going to hinder me from achieving the best results, as in, will these missing features hinder me from achieving the same results if I was to use the other formats that do contan the added features?
GilFis is offline
post #9 of 17 Old 12-04-2013, 03:10 PM - Thread Starter
GilFis's Avatar
Hello?
GilFis is offline
post #10 of 17 Old 12-04-2013, 03:44 PM - Thread Starter
GilFis's Avatar
GilFis is offline
post #11 of 17 Old 12-04-2013, 05:29 PM - Thread Starter
GilFis's Avatar
Hello?
GilFis is offline
post #12 of 17 Old 12-04-2013, 09:33 PM
willieconway's Avatar
Quoted: 121 Post(s)
Liked: 130
No.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is online now
post #13 of 17 Old 12-05-2013, 07:00 AM
10k
10k's Avatar
Liked: 1333
The mp4 files are more than sufficient for what you will be able to do by eye. Disney WOW disc might be easier to use though.
10k is online now
post #14 of 17 Old 12-05-2013, 11:37 AM - Thread Starter
GilFis's Avatar
Ok, so I used the avs hd 709 on my tv and it seemed to make it less vibrant. Is that normal? It seems there no longer any bright colors anymore. The tv does seem to have more detail in it though, its a lot different
GilFis is offline
post #15 of 17 Old 12-05-2013, 11:43 AM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
Give it a few days, you may find you prefer the more accurate picture
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #16 of 17 Old 12-05-2013, 11:57 AM
10k
10k's Avatar
Liked: 1333
Definitely. First sight of a calibrated TV is like jumping in the river for a swim. At first it is uncomfortable and a bit shocking, but before you know it you are having the time of your life smile.gif
10k is online now
post #17 of 17 Old 12-05-2013, 02:38 PM - Thread Starter
GilFis's Avatar
Is blurr also normal? When doing the tests using avs hd 709, even with sharpeness at 0, there were still some jaggedness
GilFis is offline
Reply Display Calibration
