spectrophotometers, spectroradiometers, and the i1 pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-05-2013, 08:06 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
I've noticed that people conflate these terms a lot, so I thought I'd share the proper definitions:
A spectrophotometer measures spectral reflectance of an illuminated object.
A spectroradiometer measures spectral radiance of an emissive source.
This is a somewhat strange definition, since the terms "photometric" and "radiometric" are usually distinguished based on the luminous spectral efficiency function of the human eye. In the case of these instruments, however, the terms "photometer" and "radiometer" do not seem to reflect this distinction.
Based on the above definitions, the i1 pro is technically both a spectrophotometer and a spectroradiometer. However, X-Rite does not classify the instrument as a spectroradiometer. After a lengthy discussion with the head of their tech support, it turns out that the reason for this is because the i1 pro does not meet international standards and certifications of a spectroradiometer. I'm assuming this has to do with the quality of the dispersing optics, and/or wavelength sampling abilities. They actually consider the i1 pro to be functioning as a colorimeter when measuring emissive displays, as its express use is for deriving colorimetric data (X Y Z), rather than spectral radiance data (even though it is deriving this data from spectral radiance data rather than directly from the source, as a true colorimeter would).
However, there are industry professionals who refer to the i1 pro as a true spectroradiometer.
Thought I'd share this, as it brings up a couple interesting points:
1) Do you classify an instrument based on how it achieves its measurements, or on the units it explicitly outputs?
2) Do you classify an instrument based on its fundamental operation (the i1 pro certainly is a spectroradiometer in the strict sense of the word), or based on its ability to meet international standards of certification?
spacediver is offline
post #2 of 8 Old 12-06-2013, 08:50 AM
derekjsmith's Avatar
Liked: 113
To us (SpectraCal) anything that measures raw spectrum and then uses a CMF to derive XYZ as it's base internal measurement is a spectroradiometer or spectro for short. Add the ability to illuminate and you have a spectrophotometer. You are right the X-Rite i1Pro/i1Pro G2 are both a spectroradiometer and a spectrophotometer depending on the the mode used. Most spectro's are one or the other.
Devices that use filters be it 3 to 40 that mimic CMF are a colorimeter. Most are tristim's 3-6 filters but some like the KM CS-200 have 40 filters to create a "Spectral Fit Method".
For us we break it down to two classes spectro's and tristim's. Spectro's give us SPD and tristim's give us XYZ.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #3 of 8 Old 12-06-2013, 10:10 AM
Liked: 113
post #4 of 8 Old 12-06-2013, 10:11 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Thanks Derek, that's good to know. I guess X-Rite distinguishes between a scientific definition and a commercial definition.
post #5 of 8 Old 12-06-2013, 10:52 AM
turbe's Avatar
Quoted: 13 Post(s)
Liked: 95
I just use Spectro when I reference the i1Pro (1/2) and have for a long time.. for our purposes, it's fine.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #6 of 8 Old 12-06-2013, 11:00 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Yea, most people do. I was just interested in the "official" definitions.
I first came across the proper distinction in Yoshi Ohno's chapter in Colorimetry: Understanding the CIE system.
excerpt:
GeorgeAB likes this.
post #7 of 8 Old 12-06-2013, 11:17 AM
turbe's Avatar
Quoted: 13 Post(s)
Liked: 95
You got a bit more out of X-Rite in regards to not meeting international standards/certifications for spectroradiometer.
Perhaps tracking down specific info on those would be of value of this thread...
ControlCAL™
turbe is offline
post #8 of 8 Old 12-06-2013, 11:28 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
believe me, it took many back and forths before I got that critical piece of information, although the person was very patient with my questions.
I found this, from NIST, which appears to list the minimal requirements for certification of a spectrophotometric components and function. Will look around for a similar document for spectroradiometers.
Reply Display Calibration
