Eye-based calibrations and patterns - Can they be trusted? What do they really show? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-06-2013, 02:18 PM - Thread Starter
MonarchX's Avatar
Liked: 31
There are some tests out there that are supposedly designed for those who do not have colorimeters, but I wonder what those tests really show and mean.
For example, this contrast test - http://www.lagom.nl/lcd-test/contrast.php shows that my blue conrtast is too high because it is hard to distinguish the bands on the blue strip as they closer to 100% IRE (right side). However, I used ArgyllCMS calibration for desktop (not madVR) and loaded the produced .cal file into videocard, and measured the calibration with HCFR. HCFR reported perfect luminance (including blue), gamma (including blue), RGB WB, and all saturation/colorchecker sweeps under dE 3.5, mostly under dE 3. Yet, the uploaded file did not really change the way that blue strip looks like... How can I have near perfect measured luminance and gamma while that picture shows that my blue contrast is still too high?
Then there is this pattern - http://www.lagom.nl/lcd-test/gamma_calibration.php that shows 1.6 for my blue gamma @ 48%. How is that possible when HCFR reports blue and luminance gamma of 2.2 @ 48% IRE with and even without ArgyllCMS calibration? If this test is incorrect, then what does it actually show?
Is it truly impossible to calibrate gray scale to a point where its more or less acceptable? My i1D3 does not measure blacks that well and it is a common advice to trust readings for 10-100% IRE, but check near-black levels with your eyes to make sure they are not red, green, or blue. The same can be done with all IRE steps. Sure, you won't get anywhere near the results you would get with a colorimeter, but you could at least fix huge problems where the color is obviously either too red, or too green, or too blue. You can definitely calibrate black and white levels. If that gamma test on Lagom site shows accurate gamma, but you could technically calibrate gamma by looking at 10% IRE steps, BUT thus far that test shows my blue gamma is 1.6, while HCFR shows 2.2. Monitor calibration wizard has similar patterns for gamma calibration. I used them a couple of times and the results were incredibly bad...
Also, a side-question regarding sharpness in general - Is it truly bad to have a slight hint of sharpening, using setting 1-5/100 instead of 0? I saw several semi-pro calibrators use sharpness 5 and one even used 10. I ventured into SM and realized that even with Sharpness = 0 and edge enhancement turned off, there is still some sharpening applied because if I were to turn it off entirely in SM, things would get very blurry. So, in the end, the only way to truly turn of sharpness is to use 4:4:4 PC Mode because any 4:2:2 mode (even Movie) ends up sharpening things up a bit. I personally like to use Game Mode, which also retains a tiny bit of sharpness that creates a small halo around the black rectangle in this test - http://www.lagom.nl/lcd-test/sharpness.php but I never saw anything like that in a movie. I know I am supposed to use Movie Mode, but I have my reasons to use Game Mode and I just wanted to know if that slight sharpening alone would distor
MonarchX is offline
post #2 of 5 Old 12-06-2013, 02:21 PM
xvfx's Avatar
Quoted: 408 Post(s)
Liked: 225
The last I read, that site is for PC colour space…
xvfx is offline
post #3 of 5 Old 12-06-2013, 03:34 PM - Thread Starter
MonarchX's Avatar
Liked: 31
sRGB color space is very close to Rec709 color space, and all other calibration aspects like gamma, blacks, whites, etc. are the same. I do not see how color space has anything to do with tests on that site.
MonarchX is offline
post #4 of 5 Old 12-09-2013, 02:09 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
I think xvfx meant the 16-235 vs 0-255 distinction, though I'm not sure if that's relevant here either (haven't really gone through original post carefully).
As for sRGB and Rec709, the gamuts are identical.
spacediver is offline
post #5 of 5 Old 12-09-2013, 02:31 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
....Is it truly impossible to calibrate gray scale to a point where its more or less acceptable?....
....I just wanted to know if that slight sharpening alone would distor
Please define "more or less acceptable."
Any white edges or ringing introduced via increasing a sharpness control is adding information to the picture not originally in the program.
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants affiliate
"Advancing the art and science of electronic imaging"
GeorgeAB is offline
Reply Display Calibration
