Panasonic 50st60 blurry & dark picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-12-2013, 10:17 PM - Thread Starter
kevgees's Avatar
I just purchase the panasonic 50st60 and its a great tv. I just for rid of my 14 year old panasonic pwdy7 tv i think it was. My old panasonics tv picture looks way better than the 50st60 right now! I know it shouldn't so I want to know if anyone has good calibration settings to get my the best picture on the tv. The picture right now is too blurry and too dark. Some stuff looks old on it and some dent! Please help!!
kevgees is offline
post #2 of 10 Old 12-13-2013, 11:38 AM
tylerSC's Avatar
Quoted: 823 Post(s)
Liked: 183
The default mode on this TV is Standard Mode, which is a bit dim and dull. Go into Picture Settings menu and change to Custom Mode. Under Pro Settings change panel brightness to High. Have AGC on 12. Put gamma detail on S-curve. Then the TV is plenty bright. In fact, I have Brightness set to 0. Have CATS turned off. And to make the picture sharper, turn Sharpness to 85 to 90. Then this TV is very bright, with vivid colors that pop. Contrast 95. And images are sharp. Although some don't like the sharpness this high, it made the images appear sharp to me. But adjust to your tastes in Custom Mode. Much better than Standard Mode. Also see ST60 threads in Plasma Displays forum.
tylerSC is offline
post #3 of 10 Old 12-13-2013, 11:55 AM
chunon's Avatar
Quoted: 2508 Post(s)
Liked: 2234
This is the wrong place for your post, Post in the ST60 Series discussion thread and those settings are so far out in left field they are not even remotely accurate.
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #4 of 10 Old 12-13-2013, 12:03 PM
PlasmaPZ80U's Avatar
Quoted: 2319 Post(s)
Liked: 716
if you're going to do all that, you could save yourself the effort and just put the set in Vivid mode defaults
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #5 of 10 Old 12-13-2013, 12:05 PM
GeorgeAB's Avatar
Location: Denver, CO metro area, www.cinemaquestinc.com
Quoted: 152 Post(s)
Liked: 260
Terrible advice for anyone seeking a correct image!
GeorgeAB is offline
post #6 of 10 Old 12-13-2013, 01:26 PM
Gregg Loewen's Avatar
Quoted: 24 Post(s)
Liked: 76
Alan, I think Tyler was trying to be funny.
Dunno.
G
President, Lion Audio Video Consultants Inc.
Lead THX Video Standards Instructor
Gregg Loewen is offline
post #7 of 10 Old 12-13-2013, 01:40 PM
rahzel's Avatar
Liked: 148
^I don't think he was. :|
rahzel is offline
post #8 of 10 Old 12-13-2013, 01:59 PM
GeorgeAB's Avatar
Quoted: 152 Post(s)
Liked: 260
Dunno.
G
So was I...... Ok, actually not. Perhaps Tyler can clear this up. I failed to see the jest. Maybe you know Tyler, personally. It has served me reasonably well to take people at their word at first encounter.
GeorgeAB is offline
post #9 of 10 Old 12-16-2013, 07:10 PM
Hampton77's Avatar
What type of media are you watching? If movies are your primary use for the TV, then I would recommend having it calibrated. If you aren't in the market for that, I would look at d-nice's settings and recommendations. Beyond that, I would avoid using anyone else's settings as they are going to be tailored to their screen and taste, although you will likely end up better off than you are now. The suggestions above (sharpness near max???) are pretty misguided as far as anything resembling proper, but if calibration is not an option for you then it is just a matter of taste anyway.
Hampton77 is offline
post #10 of 10 Old 12-16-2013, 07:12 PM
Hampton77's Avatar
failed to mention the option of purchasing a basic calibration package and doing it yourself. You will get good results if you research a bit, but beware, it is addictive...
Reply Display Calibration
