HCFR and the spyder 4 express/pro - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 32 Old 12-29-2013, 11:14 PM - Thread Starter
rallyman03's Avatar
Hey guys,
I'm new to the community and really appreciate your opinion. I have quite a bit of experience with tvs and electronics in general and have always been one of those people that keeps up to date in this area. I just purchase a Samsung un55f7100 and I am looking into calibration as I want the best out of my tv. Instead of purchasing isf calibration from best buy I wanted to try my hand at using hcfr. I've read through a couple guides and have a rudimentary knowledge as I have spend 5 years in installing/selling tvs in the past.
My question is if im going to be using hcfr to calibrate do i want the spyder 4 express (no ambient light sensor) or do i want the pro model (ambient light sensor)? If I do go for the pro model how does hcfr use this sensor. Do i have to input initial readings or does the sensor/hcfr take the light into account when displaying other values? My tv does have day and night settings so if I can take advantage of properly calibrating both scenarios i would like to. But if HCFR doesn't use this info then Ill save the money on the sensor.
Thanks for your input.
rallyman03 is offline
post #2 of 32 Old 12-30-2013, 05:03 AM
realzven's Avatar
Liked: 84
Originally Posted by rallyman03 View Post
Hey guys,
the hardware in the differents spyder 4 is strictly the same : buy the cheaper one (spyder 4 express or spyder 4 hdtv...)
the sensor is not necessary for our purpose of display calibration, always calibrate in controled light room (a bat cave at night, with no light is the optimum biggrin.gif)
The calibration is viewing image in respect of the international imaging standard, for night and day settings calibrate with due respect to the standard
If you really want to calibrate a day settings (some says is no more real calibration...) you can try a lower gamma or boost 100% white but check for white clipping, color clipping and eye strain...
but with that least solution you are quite out of the standard...
i'd like to say : "it's always preference vs reference"
ps : for more education in calibration stuff, you can look at the Michael Chen tremendous site http://www.tlvexp.ca/ :
some calibration tips, very good articles, a calibration quizz, an e-learning and somes awesome calibration video training
ps n°2 : if you're more serious about calibration, take a look at the display 3 or display pro colorimeter, a way better than the spyder 4 (better repeatability, more accurate at low light level, more fast and work with all others cal software (hcfr, chormapure, calman) if in the future you want to update your gear).
The i1 pro spectro REV D (used for 250 / 400 $) is the way to go if you want the accuracy of the spectro
the best combo is the D3 + i1 pro, the D3 profiled with the i1 pro (best of both world : accuracy and speed, good repeatability, accurate at low light level from 0,001 ft/L...)
realzven is offline
post #3 of 32 Old 12-30-2013, 05:19 AM
realzven is offline
post #5 of 32 Old 12-30-2013, 05:35 AM
realzven's Avatar
Liked: 84
realzven is offline
post #6 of 32 Old 12-30-2013, 06:27 AM - Thread Starter
rallyman03's Avatar
Wow thanks for all the responses guys! Ill look over all the resource's you've made available. (oh what a can of worms I have opened for myself :) )
All of you have an amazing new year!
post #7 of 32 Old 12-30-2013, 07:01 AM
realzven's Avatar
Liked: 84
realzven is offline
post #8 of 32 Old 12-30-2013, 08:09 AM - Thread Starter
rallyman03's Avatar
Will do. However now you have me wondering if I should just go straight to the display pro or would that be a waste for a noobie?
Sent from my Nexus 4 using Tapatalk
post #9 of 32 Old 12-30-2013, 08:54 AM
realzven's Avatar
Liked: 84
i can't answer and decide for you... it depends on what you are looking for...
- Calibrate only one (your) display or more (family, friends, others...) ?
- budget : you have the budget for the display pro ?
- time : have you a lot of time to spend hours of learning calibration stuff, training, testing ?
I think if you have the budget the display pro is the way to go, and if you've finished your calibration you can sell your Display pro more easily than the spyder 4 wink.gif
realzven is offline
post #10 of 32 Old 12-30-2013, 10:37 AM - Thread Starter
rallyman03's Avatar
I would be calibrating my displays and all my friends / family. I can make the budget for the display pro (lol). I'm just at the very beginning of my learning curve. But I am a bit of a perfectionist. Am I going to get much better results using the pro and hcfr? Then i would over the spyder and hcfr?
post #11 of 32 Old 12-30-2013, 10:45 AM
realzven's Avatar
Liked: 84
realzven is offline
post #12 of 32 Old 12-30-2013, 10:54 AM - Thread Starter
rallyman03's Avatar
Haha well I guess its settled then. Thanks for all your help. I'll keep you posted on how everything goes.
post #13 of 32 Old 02-03-2014, 07:28 AM
brunskog's Avatar
Does the X-RITE I1 DISPLAY PRO work for calibrating plasma TV as well?
brunskog is offline
post #14 of 32 Old 02-04-2014, 02:32 AM
mytbyte's Avatar
Liked: 25
Absolutely!
mytbyte is online now
post #15 of 32 Old 02-04-2014, 02:39 AM
brunskog's Avatar
Much better than the i1 Display 2 for a normal home user?
brunskog is offline
post #16 of 32 Old 02-04-2014, 07:16 AM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
The I1 Display pro is faster with better repeatiblility , reads at the lower end better and has sealed optics so it drifts less over time. So yes it is a better meter
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #17 of 32 Old 02-05-2014, 12:29 PM
howzz1854's Avatar
what did you guys mean by D3 + i1Pro? i know that i1 Pro refers to the i1 Display Pro http://www.amazon.com/gp/product/B0055MBQOW/ref=s9_psimh_gw_p421_d3_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=001CJWYXN8K7XNDZZMKN&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
but what did you guys mean by D3?
i am also in the same boat as op. i have the option of upgrading my ancient Spyder2 express, which i no longer use for any of my LED monitor, or 60 inch LED ES8000 samsung. the upgrade plan provided by data color will give me 30% off.
TV: Samsung 60inch 60ES8000 LED TV,
Sound System: Pioneer VSX 1120-K, 2x JBL Stadium fronts, 1x JBL EC35 center, 4x JBL L820 surrounds, 1x JBL SUB12 for a complete 7.1
Headphones: Sennheiser HD598, HD650 headphone, Audio Technica ATH-AD700, AD900X
howzz1854 is offline
post #18 of 32 Old 02-05-2014, 12:42 PM
rahzel's Avatar
Liked: 148
The i1Pro is not the same as the i1Display Pro. The i1Pro is a spectro; the i1Display Pro is a colorimeter. The actual model number of the i1Display Pro is EODIS3 (Eye One Display 3), so people usually call it D3 or i1D3 for short.
Many calibrators purchase both so that they can get the best of both worlds by profiling their colorimeters. You get the accuracy of the spectro, with the speed and low-light capability of the colorimeter.
rahzel is offline
post #19 of 32 Old 02-05-2014, 01:50 PM
howzz1854's Avatar
ok. now i am confused. Spectro? you mean Spectrometer? i thought all we need is a color meter like i1Display pro (AKA i1D3) and a calibration software. what is a spectrometer? and how does it differ from a colormeter.
post #20 of 32 Old 02-05-2014, 02:27 PM
rahzel's Avatar
Liked: 148
http://www.tlvexp.ca/2012/04/do-calibration-tables-really-work-for-tri-stim-devices/
http://www.avsforum.com/t/1487208/colorimeters-and-spectrographs-questions#post_23657729
The D3 is pretty good on its own, especially on certain displays, and is what many DIYers use. It's the minimum I would recommend. But if you want to ensure accuracy, something like an i1Pro rev.D is a good affordable solution if you want to take it to the next level, but that's your call to make.
edit: FYI, the C6 is based on the D3 probe, but includes additional tables to help improve accuracy.
http://store.spectracal.com/c6-vs-oem
rahzel is offline
post #21 of 32 Old 02-05-2014, 03:04 PM
howzz1854's Avatar
so the i1Pro is basically an enhanced edition of the i1D3?
is it this? http://www.curtpalme.com/ChromaPure_EyeOneDisplay3.shtm
somebody need to ****ing slap those engineers around on their naming convention. i1 Display Pro = i1 Display 3; and i1 Pro is not i1 Display Pro. WTF!!!. makes me really frustrated and angry. maybe i'll just go with a spyder 4
post #22 of 32 Old 02-05-2014, 03:27 PM
rahzel's Avatar
Liked: 148
No, the i1Pro is a spectrometer, the i1Display Pro and its variations are colorimeters. The i1Pro is a completely different meter. Read the links that I provided to know the differences between the two (spectro and colorimeter) and how the D3's accuracy can vary depending on the display. That should give you a better idea of why people buy both the D3 and i1Pro. Basically they profile their D3s (colorimeter) to their i1Pro (spectro) so that they have the accuracy of the i1Pro/spectro, but the speed and low-light capability of the D3/colorimeter to ensure accuracy. Using the D3 by itself is generally not as accurate.
You may be confused as why there's a meter called the i1Display 3 Pro. This is Chromapure's enhanced version of the D3 which includes additional tables to improve accuracy. Hopefully this clears things up:
i1Display Pro / i1Display 3 / D3 / i1D3 / EODIS3 - colorimeter
i1Display 3 Pro - Chromapure's enhanced version of the D3 with additional tables - colorimeter
C6 - SpectraCal's enhanced version with additional tables (among other things) - colorimeter
i1Pro - spectrometer
rahzel is offline
post #23 of 32 Old 02-05-2014, 03:36 PM
mytbyte's Avatar
Liked: 25
And then there is colormunki display and colormunki spectro so one should also be careful in distinguishing what others are referring to when they just talk colormunki rolleyes.gif ...
post #24 of 32 Old 02-05-2014, 04:24 PM
howzz1854's Avatar
ok. thanks for clearing that all up.
where can you buy the i1 Pro at? i can't find it on Amazon.
also. is there an update to date guide for HCFR. i am debating and deciding which colormeter to get, but i am also investigating which software to use that's not too complicated, so an up to date guide would be preferred than a guide that's written back in 2008.
i plan on using it for my 60ES8000 samsung LED tv.
post #25 of 32 Old 12-11-2015, 02:47 PM
doctorG4's Avatar
Quoted: 24 Post(s)
Unhappy HCFR does not see spyder4
Help!
I have a recently bought a spyder4 Elite and installed the Datacolor sw on my Mac OSX 10.10. Unfortunately I came to realise it does not do what I need (i.e. I want to calibrate my projector with a BR player and not with the computer as source).
Found then HCFR and installed in my Parallel Windows XP Virtual Machine.
I also installed Datacolor SW in Windows and that works fine but HCFR does not, it starts OK but the spyder4 sensor is not recognised and I only get "simulated sensor" in the HCFR GUI. All the instructions I found on how to add "drivers" using Windows drive manager do not seem to do anything and selectiong the windows Datacolor driver directory results in a message that there is nothing to install different from what I've already installed.
The HCFR site mentions the need to run c:\program files\HCFR Calibration\Tools" then run the command "spyd4en". This file does not exists in that directory.
I also installed Argyll and run oeminst and get message that dccmtr.dll is loaded however then it complains that no CD is found (?).
I have spent more that half day with no progress whatsoever and HCFR does not simply sees the spyder sensor.
Any idea ?
doctorG4 is offline
post #26 of 32 Old 12-11-2015, 02:57 PM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
As a test your can try LightSpace CMS with the free DPS license.
That will work with the Spyder probe, so will check it works ok.
You can download the software and the free DPS license from the Light Illusion website.
There is also a User Guide: http://www.lightillusion.com/manual_...ots_guide.html
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #27 of 32 Old 12-14-2015, 09:54 AM
doctorG4's Avatar
Quoted: 24 Post(s)
Steve
Thanks for the tip. I have filled a request for the free software.
doctorG4 is offline
post #28 of 32 Old 12-14-2015, 03:31 PM
gwgill's Avatar
Quoted: 245 Post(s)
Liked: 181
You need to install the ArgyllCMS .sys driver. (Don't be confused by all the old HCFR talk about installing .dll files). General MSWin installation instructions are here. Skip to the part about installing the driver.
You need to switch from the Datacolor .sys driver to the ArgyllCMS .sys driver. Locate the the .inf & .sys drivers in the HCFR package or ArgyllCMS, and follow the instructions on how to install them.
It is not necessary to run this, just desirable, since it will install the different display type instrument calibrations.
So put the Spyder install CD in the (virtual) machine and continue !
See the first HCFR thread article for links to all this.
doctorG4 likes this.
gwgill is offline
post #29 of 32 Old 12-16-2015, 02:53 PM
doctorG4's Avatar
Quoted: 24 Post(s)
Whoa! That was a lot of information!!
Thanks. I'll sit down and try all out...
Inviato dal mio iPhone utilizzando Tapatalk
doctorG4 is offline
post #30 of 32 Old 12-21-2015, 02:02 PM
doctorG4's Avatar
Quoted: 24 Post(s)
Argyll installed. Also Lightspace does not show Spyder4
OK. I have installed the Argyll drivers (claims to be version of driver 1.2.6 from 2012) as explained above. The device manager now shows them and HCFR nows display the Spyder4 !! :-) still when I start LightSpace CMS as suggested above I do not see the Spyder4 in the interface... must be something stupid but I cannot find it.
Suggestions ?
Name:	device manager.png
ID:	1133482   Click image for larger version
Name:	Screen Shot 2015-12-21 at 21.57.51 .jpg
Last edited by doctorG4; 12-21-2015 at 02:12 PM. Reason: HCFR works but not Lightspace CMS
doctorG4 is offline
Reply Display Calibration
