New 4K Pattern Generator from DVDO - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #1 of 227 Old 02-04-2014, 11:01 AM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
http://www.dvdo.com/avlabtpg/
http://www.marketwatch.com/story/hepatology-publishes-12-week-phase-iii-extension-study-data-of-sebelipase-alfa-in-adults-with-late-onset-lal-deficiency-2013-02-04?reflink=MW_news_stmp
It's the newest 4k generator from DVDO. MSRP is $1299. No word if it does 3d LUT as far as I can see. Size is great and has MHL. Calman 5 support
ConnecTEDDD likes this.
avsform1 is offline
post #2 of 227 Old 02-04-2014, 11:15 AM
ConnecTEDDD's Avatar
Quoted: 1044 Post(s)
Liked: 1514
This important detail is something that someone from CalMAN crew can confirm, if it can be used as a 8bit RGB Triplet Generator, and not only as RGB Percentage generator like the older DVDO products were was not possible to be used as a 3D LUT Cube pattern generators.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3 of 227 Old 02-04-2014, 11:19 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Unfortunately it is exactly the same pattern generator capability as in the older Duo products.
None the less, we will be adding support for it.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 227 Old 02-04-2014, 11:27 AM
derekjsmith's Avatar
Liked: 116
This is basically the guts of a Duo with a 4k HDMI transmitter. The form factor is really small and portable.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #5 of 227 Old 02-04-2014, 11:27 AM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
Wow... Why put out a new product that not capable of technology that the Lumagens and Accupel has had for over a year? What would be nice would be a Lumagen pattern generator and Accupel video processor. Don't get me wrong I like DVDO, but basically putting a DUO with 4k patterns and no processing....
avsform1 is offline
post #6 of 227 Old 02-09-2014, 01:47 AM
mkoper's Avatar
Quoted: 29 Post(s)
Liked: 54
I'm on ISF seminar in Amsterdam right now and we have opportunity to play with this device. It is very fast and has a nice remote to control the patterns. 4K resolutions are supported including 60Hz with 4:4:4 chroma subsampling, anyway its firmware is still in alpha-stage and the amount of patterns is limited to ISF workflow in calman. The good news is that there is the DVDO's Director of product management - David Feller and he is open to suggestion!
He already promised custom patterns through USB (aka RGB triplets). We've also discussed:
- 3D patterns
- more pre-calibration patterns like precision color clipping, etc.
- motion patterns (for evaluating display performance), but that may be a little harder
- digital signal evaluation - the device has HDMI Input so there could be cursors to point a pixel and check its digital value
Did I mention that this device is USB powered?
We've just discovered that if the device is connected as DUO it will do all triplets including color checker. If connected as AVLab-TPG it won't. Color checker fails wink.gif
mkoper is offline
post #7 of 227 Old 02-09-2014, 09:51 AM
turbe's Avatar
Liked: 95
need/want Full triplet, not just R%G%B% triplet
And update the Duo's as well,
it's easier to implement/code full triplet vs %, if there is no space, remove % and do full triplet. I'm sure they "Can Do It!"
That's being advertised (from what I'm reading) as a feature already, the units there don't even have R%G%B% now?
from: http://www.dvdo.com/avlabtpg/ (Key Features):
Dynamically generated patterns via USB control
I still don't see all the output options available / specs - do you have anything from David on this?
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #8 of 227 Old 02-09-2014, 10:43 AM
dfeller's Avatar
Hi Turbe, just checking, you want to be able to call up as custom pattern with 4 parameters, r,g,b, window size, with r,g,b as exact hex values not percentage correct? 8, 10, or 12 bits each depending on color depth mode. And perhaps ire of window background as well?
D
dfeller is offline
post #9 of 227 Old 02-09-2014, 10:44 AM
dfeller's Avatar
And 'promise' is a big word. We are collecting inputs now.
dfeller is offline
post #10 of 227 Old 02-09-2014, 11:26 AM
turbe's Avatar
Liked: 95
D
Hi David,
yes that would be great, at all bit depths (or at the maximum - we do the conversion down).. one command for all and/or set size and background with two separate commands*).
* I would think you would want the option to change those two with the remote as well
As far as priority, I'd put #1)full triplet, #2)size and #3)background (in that order) before 3D patterns! The market for your generator would be greater with the LUT support here / coming.
If you did the same with the Duo, I think you would increase sales as well.
ControlCAL™
turbe is offline
post #11 of 227 Old 02-09-2014, 12:03 PM
turbe's Avatar
Liked: 95
D
I read through your post a little too fast.. Input exact R value, G value and B value with Decimal vs Hex preferred..
ControlCAL™
turbe is offline
post #12 of 227 Old 02-09-2014, 01:18 PM
PE06MCG's Avatar
Liked: 51
Hi David
From the point of view of my Duo which hopefully will benefit from any improvements.
I think the problem is that each colour as a non decimal point percentage can only have 100 values per R,G and B channel whereas the colours in video seem to go from 0 to 250+.per channel (sorry my theory and maths are suspect).
The Duo is great as a Pattern Generator but is restricted by this constraint.
Any method to overcome this would be good for your PG and a sales stimulus for the Duo.
Simply adding a single decimal point to existing integer only percentages would give us more patterns than we will ever need..
PE06MCG is offline
post #13 of 227 Old 02-10-2014, 02:13 AM
dfeller's Avatar
Understood, let me talk to spectral and see what command format they prefer. That is a simple request. What other packages does everyone use... chromapure, what else?
dfeller is offline
post #14 of 227 Old 02-10-2014, 04:46 AM
PE06MCG's Avatar
Liked: 51
Thanks David,
Certainly Spectracal are unable to use your PG for any 3D LUT users via say an eeColorbox,or a Fuji or more expensive external boxes.
They are currently using the Lumagen range (which has the capability to display all patterns) .
Other software is Light Illusion which also uses Lumagen products for the same purpose.
Tom H. has not yet entered into the 3D LUT area.
PE06MCG is offline
post #15 of 227 Old 02-10-2014, 09:10 AM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
If you did the same with the Duo, I think you would increase sales as well.[/quote]
+1
From what I here the new Panasonic will have the capability to have 3D LUT built into the sets. This would be a great for this unit.
avsform1 is offline
post #16 of 227 Old 02-10-2014, 10:18 AM
turbe's Avatar
Liked: 95
+1
ControlCAL™
turbe is offline
post #17 of 227 Old 02-10-2014, 10:38 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Um, ChromaPure has supported the 125-point and 729-point LUT from the Lumagen since it was released.
Gregg Loewen and ConnecTEDDD like this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #18 of 227 Old 02-10-2014, 10:40 AM
PE06MCG's Avatar
Liked: 51
Apologies Tom.
I was not aware of this definitely something I should have known.
PE06MCG is offline
post #19 of 227 Old 02-10-2014, 11:50 AM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
Also it would be useful to be able to show custom patterns or images, in .png format at least. That's a feature of my VideoForge that I like and use. Custom patterns can be very useful for specialized tests, and images can help you check your work as you go along to catch any problems that might be evading the selected measurements.
Chad B is online now
post #20 of 227 Old 02-10-2014, 02:10 PM
mkoper's Avatar
Quoted: 29 Post(s)
Liked: 54
As far as i know it's already supported.
mkoper is offline
post #21 of 227 Old 02-10-2014, 02:42 PM
D6500Ken's Avatar
Quoted: 33 Post(s)
Liked: 55
I noticed Menu and Exit buttons on the IR remote. Are these functional?
If so, is there any info on the menu structure?
Ken Whitcomb
Calibrations Inc
Indianapolis, IN
Calibrations Inc
Indianapolis, IN
RECENTLY ADDED!
Colorimetry Reseach CR-250 4 nm spectroradiometer and Colorimetry Research CR-100 colorimeter
D6500Ken is offline
post #22 of 227 Old 02-10-2014, 05:07 PM
mkoper's Avatar
Quoted: 29 Post(s)
Liked: 54
If you hit the menu button you'll be able to control the output signal parameters such as:
- bit depth (8/10/12)
- dynamic range (normal/full)
- signal format (rgb,ycbcr 422, ycbcr 444)
- framerate: SD and HD framerates are supported, as well as 4K (24, 25, 30Hz) with full capability, and 4K (50Hz, 60Hz) with 4:2:0 chroma subsampling only.
mkoper is offline
post #23 of 227 Old 02-10-2014, 06:04 PM
JAlanMurray's Avatar
First let me say I am somewhat biased about this unit as a reseller and co-developer. This is the best low cost generator I have seen in a while - we put it to the test in Amsterdam and got great results and feedback. My guess is David (DVDO) has loads of enhancements underway already - easy to upgrade in the field via mini USB port. We used it stand-alone into several 4K panels and even went into a QD780B (Quantum Data 4K Analyzer) to see the exact formats coming in. We also drove it with CalMAN for 3 days with no glitches except the latest release candidate that causes the color checker to go batty. The previous version - where you select a DVDO-Duo worked just fine and for basic grayscale and CMS calibration it was flawless and very fast and you can power it right off the display or computer. Obviously, I will keep my QD780B - it is bar none the best HDMI analyzer/generator in the field, but for about an 8th the price I would definitely have the new DVDO TPG also. If you are seeking to purchase the new TPG AVProAlliance has 100 units landing in the next few weeks.
JAlanMurray is offline
post #24 of 227 Old 02-11-2014, 09:16 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 103
How are resolution patterns displayed? Can it display a range of burst frequencies up to 4k, and if so can the size and frequency range of the bursts be continuously varied? Images? Thanks. -- John
John Mason is online now
post #25 of 227 Old 03-03-2014, 03:01 PM
Matt0509's Avatar
Yes, they are functional buttons, you get and OSD menu.
Matt0509 is offline
post #26 of 227 Old 03-14-2014, 04:58 PM
turbe's Avatar
Liked: 95
It looks like the AVLabTPG now supports full RGB Triplet (though I've only seen 0-255 listed):
***Update***
AVLabTPG now supports RGB Triplets! (RGB 0-255)
Hopefully they can be addressed at 10-bit and 12-bit (supports 8, 10 and 12 output per Datasheet*)
*Rev. 2 Datasheet doesn't show Full Triplet Support, time for Rev. 3?
ControlCAL™
turbe is offline
post #27 of 227 Old 03-15-2014, 04:09 AM
PE06MCG's Avatar
Liked: 51
This is hopefully good news for Duo owners as well, however I am a little confused by the data sheet.
As I understood it the PG used the Duo as a basis for hardware then combines it with parts of the Quick6 to give 4K.
I notice that the Duo 'works in' up to 10 bit both horizontally and vertically according to its chip data yet the PG claims to be able to process 12 bit (as well as 10 bit). Perhaps they are different things and it still 'works in' 10 bit?
If not it would seem to indicate that it does not use the same chip as the Duo which would be bad news for those of us who would hope for a firmware update on the Duo (to get the 0-255 capability).
turbe likes this.
PE06MCG is offline
post #28 of 227 Old 04-24-2014, 10:20 AM
Liked: 1514
New AVLab TPG Firmware Update Version 01.01 Released
The Enhancements
* Added new patterns.
- Sharpness
- 75% in each color (default for remote)
- ANSI contrast 3x3, 4x4 bwb and wbw
- half patterns (for testing source calibrations)
* Added new output format RGB limited.
* New Firmware update option - when in normal operating mode connected via USB to a PC, press F/W update button at any time to enter F/W update (mass storage) mode.
* Added new AA serial command that supports full (0-255) triplets with APL control - this new command is in addition to the existing AF (0-100%) IRE triplet command.
*Triplet command includes R/G/B in 0-255, input range, output range, output window size, window background color, output format.
* Improved remote control response.
* Added serial commands to control output format, bit depth, range (for inclusion in CMS software control).
* Updated pass-through mode - disable test patterns, pass EDID back to input.
Download Link
post #29 of 227 Old 05-01-2014, 01:11 AM
venkatesh_m's Avatar
Quoted: 33 Post(s)
Liked: 26
Am I right to presume that it does not support 3D frame packed/SBS/TopBottom formats at the moment?
venkatesh_m is online now
post #30 of 227 Old 05-01-2014, 10:47 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
They are working on 3D but haven't released it yet.
Tom Huffman
Springfield, MO
Reply Display Calibration
