Any DIY method of checking a meters accuracy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-06-2014, 10:24 PM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Have a 4 year old OTC-100 that has seen very little use and has never been calibrated.
Is there a way to determine the meters accuracy or lack there of other than sending it in for calibration?
Thank
TL
trans_lux is offline
post #2 of 8 Old 02-06-2014, 11:02 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
See this thread
spacediver is offline
post #3 of 8 Old 02-06-2014, 11:04 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Thank
TL
Unfortunately without some kind of known reference there is no way to test it. Being that the Sencore OTC-1000/X-Rite Hubble is a colorimeter, each table needs to be checked on the specific type of display.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 8 Old 02-07-2014, 08:21 AM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Wow that's quite the thread!
post #5 of 8 Old 02-07-2014, 10:49 AM
dschlic1's Avatar
Quoted: 71 Post(s)
Liked: 27
I quick gut check might be to measure the color temperature of mid day sunlight. It should be close to 6500K.
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #6 of 8 Old 02-07-2014, 12:08 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
I think most of us have pondered the "how can I be sure"
question about our meters.
other than getting a reference meter or sending the meter off
I have not read of a DIY method that can tell you.
I suggested a DIY get together here is SoCal but had no takers.
Loving D65
CalWldLif is offline
post #7 of 8 Old 02-08-2014, 11:02 AM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
IIRC, D65 (which is what you want to check for rather than 6500K, which can range from a green to a magenta tint) was said to be closest to sunlight at midday on a snow-covered winter day. Sunlight most other times of the year is roughly 5400-5500K. Because it isn't a precise reference, I'd hesitate to use it to validate a meter, even as a quick check .
ConnecTEDDD likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #8 of 8 Old 02-19-2014, 07:31 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
thinking I'd rather look at a luminous yellow tinge on mine than green or magenta,but it's probably different for every tv..Some site says if you stare at the clouds(at the right time) on a sunny day, and then you could try and make the Tvs grayscale/white the same color of the clouds.Supposedly staring at clouds resets the eyes too the right color temperature.Never tried it as I always thought staring into bright light made them less accurate.
Vic12345 is offline
Reply Display Calibration
