Auto calibration issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2014, 07:14 PM - Thread Starter
chunon's Avatar
Quoted: 2464 Post(s)
Liked: 2208
Using Calman 5 to do auto calibration> Connecting to display okay but Calman is taking measurement making adjustments but not changing the display controls. Any ideas ?
65C6 OLED/65 A1E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #2 of 3 Old 02-23-2014, 09:34 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
Depending on what part of the TV or projector CalMAN is communicating with, it may not be adjusting the User Menu controls. The big question is... is CalMAN really making measurable changes? If you manually measure grayscale and colors BEFORE you do Auto-Calibration, then you manually measure grayscale and colors AFTER Auto-Calibration, do your manual BEFORE and AFTER measurements differ? And if so, presumably the AFTER Auto-Calibration measurements are BETTER than the BEFORE measurements. If all that is true, CalMAN is simply changing settings you can't see. Which is perfectly fine / legitimate. You do know that the User Menu controls are not the only controls in video displays... right?
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #3 of 3 Old 02-24-2014, 04:48 AM - Thread Starter
chunon's Avatar
Liked: 2208
Doug thanks for the response and i should have been more specific. I have a Panasonic VT60, after actually reading the documentation I found that my set has to be connected thru wireless for the autocal to work. The software seemed to indicate it was connected but that must have been false. The autocal doesnt make any corrections in the service menu that I am aware of for this model. I had experience with autocal on my VT50 and was always able to see adjustments in the user menu.
65C6 OLED/65 A1E
chunon is offline
Reply Display Calibration
