FTDI VCP CDM 2.10.00 WHQL Certified for Windows 32/64-bit can be downloaded from here .
JETI / Klein / Discus meters or Lumagen Video Processors / eeColor 3D LUT Boxes are using these drivers to communicate.
Virtual COM port (VCP) drivers cause the USB device to appear as an additional COM port available to the PC.
Application software can access the USB device in the same way as it would access a standard COM port.
Release Fixes
Support for Selective Suspend.
NOTE: Microsoft have ended support for certifying XP and VISTA through their WHCK test program. As such current builds will still work on XP and VISTA but are not Microsoft certified.
Originally Posted by ConnecTEDDD /t/1525531/jeti-klein-lumagen-eecol...port-drivers-update-for-windows#post_24560375
Release Fixes
Hi Jim, I have no idea of any bugfixes that this release solves, I installed these drivers yesterday and used my eeColor/Klein/JETI to perform a 21-Point Cube without any problem.
FTDI VCP CDM 2.12.16 (16 March 2016) WHQL Certified for Windows 32/64-bit can be downloaded from here. (download the executable setup for easier driver installation)
Release Notes
WHQL certified release.
Release Fixes
Fixed problem with serial number string returned from D2XX API functions when serial number bit is not set in EEPROM.
FTDI VCP CDM 2.12.24 (10 October 2016) WHQL Certified for Windows 32/64-bit can be downloaded from here. (download the executable setup for easier driver installation)
FTDI VCP CDM 2.12.28 (24 August 2017) WHQL Certified for Windows 32/64-bit can be downloaded from here. (download the executable setup for easier driver installation)
FTDI VCP CDM 2.12.36.2 (15 June 2021) WHQL Certified for Windows 32/64-bit can be downloaded from here. (download the executable setup for easier driver installation)
Release Notes
Release Fixes
Fix FT4222 Rev C installation problem.
Fix static library problem.
Update driver version number.
FTDI VCP CDM 2.12.36.4 (7 July 2021) WHQL Certified for Windows 32/64-bit can be downloaded from here. (download the executable setup for easier driver installation)
Release Notes
Release Fixes
Fix compatibility issue with FT_Prog.
Fix intermittent fault on startup with Win10 on Lenovo laptop.
Note: VCP webpage has a broken link for the executable setup, here you can download it.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
