Bought a i1pro for dirt cheap, anything wrong with it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-08-2014, 09:12 PM - Thread Starter
cfelicio's Avatar
Hi Guys,
Today I managed to "snag" a i1pro for $10. Surreal! The unit looks banged up from outside, but for $10 I took a chance... It only came with the base (same serial).
I remember someone mentioning that if the i1diagnostics are good, then the unit is usually good... I'm posting my results here, does it look ok?
Start testing
General Information
Date and Time: 2014-04-08T20:20:10
Application version: 4.0.0.127, 32-bit
SDK version i1Pro: 4.1.1.1572
SDK version i1iO: 2.1.1.1572
Platform: Microsoft Windows 7 Professional Service Pack 1 (Build 7601), 64-bit
i1iO Connection Test
i1Pro not mounted on i1iO
Open instrument
Connection: Successful
Open instrument '\\?\usb#vid_0971&pid_2000#6&df2ee03&0&6#{989d6515-e122-4442-a357-751457f102a5}': Successful
Instrument information
Instrument inspection: Successful
Serial number i1Pro: 879254
Type: i1Pro (M2 only)
Revision: D
Firmware version: 503
CPLD version: 999
Dark measurement count: 41
Lamp burning time: 4.0 seconds
Spot measurement count: 14
Scan measurement count: 0
Factory calibration: 2007-09-27
Spectral Module ID: 01-d44b2e11000038
Instrument Licences
Measurement Modes: [ReflectanceSpot, ReflectanceScan, EmissionSpot]
Licensed functionality: [Has UVcut filter, Spectral values, Tristimulus, Density]
Licensed Modules:
i1Match Module "Scanner": NOT licensed
i1Match Module "Monitor": NOT licensed
i1Match Module "Printer": NOT licensed
i1Match Module "Printer RGB only": NOT licensed
i1Match Module "Printer CMYK only": NOT licensed
i1Match Module "Beamer": NOT licensed
i1Match Module "Printer Easy RGB": NOT licensed
i1Match Module "Printer Easy CMYK": NOT licensed
i1Match Module "Digicam": NOT licensed
i1Match Module "Editor": NOT licensed
i1Profiler Module "Display Profiling": NOT licensed
i1Profiler Module "RGB Printer Profiling": NOT licensed
i1Profiler Module "CMYK Printer Profiling": NOT licensed
i1Profiler Module "Printer QA": NOT licensed
i1Profiler Module "Advanced-Mode": NOT licensed
i1Profiler Module "Projector": NOT licensed
Button Test
Button: Successful
Emission test
Emission calibration: Successful
Prepare the instrument for emission measurement
White measurement: Successful (X=84.669 Y=88.963 Z=92.308)
Gray measurement: Successful (X=31.945 Y=33.069 Z=37.806)
Black measurement: Successful (X=0.144 Y=0.135 Z=0.199)
Red measurement: Successful (X=38.510 Y=19.946 Z=1.535)
Green measurement: Successful (X=31.797 Y=63.686 Z=8.602)
Blue measurement: Successful (X=15.315 Y=6.158 Z=83.317)
Emission: Successful
Button Test
Button: Successful
Noise Tests
Dark measurement: Successful (dark noise: -186.396)
Noise measurements: Successful
Noise result: Successful (electronic noise: 2.751)
Reflectance test
Reflectance Spot calibration: Successful
Reflectance Spot measurement 1: Successful (95.837, -0.383, 2.534)
Reflectance Spot measurement 2: Successful (95.847, -0.382, 2.557)
Reflectance Spot measurement 3: Successful (95.835, -0.391, 2.586)
Reflectance Spot measurement 4: Successful (95.835, -0.382, 2.549)
Reflectance Spot measurement 5: Successful (95.840, -0.399, 2.576)
Reflectance Spot measurement 6: Successful (95.838, -0.383, 2.542)
Reflectance Spot measurement 7: Successful (95.833, -0.374, 2.543)
Reflectance Spot measurement 8: Successful (95.839, -0.389, 2.568)
Reflectance Spot measurement 9: Successful (95.834, -0.376, 2.542)
Reflectance Spot measurement 10: Successful (95.839, -0.381, 2.525)
Lamp test: Successful (minL=95.833 meanL=95.838 MIT=0.0121233603 CIT=0.0112199998 LOT=6.59139156)
Reflectance drift test: Successful (0.018)
Reflectance Scan calibration: Successful
I also own a Colormunki Photo, maybe I can run dispcalgui and compare them to see if the results are somewhat similar?
cfelicio is offline
post #2 of 7 Old 04-09-2014, 02:06 AM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
The fact that none of the additional capabilities (monitor, etc.) are licensed means that this is an OEM version. Wonder where the original owner got it.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 7 Old 04-09-2014, 02:36 AM
gwgill's Avatar
Quoted: 245 Post(s)
Liked: 181
From the measurement counts, it looks like it's never been used.
[ X-Rite's driver updates this info, but note that ArgyllCMS's drivers do not. ]
gwgill is offline
post #4 of 7 Old 04-09-2014, 11:09 PM - Thread Starter
cfelicio's Avatar
Yeah, it had 0 counts until I ran the diagnostics, now it has some...
I'm attaching the grayscale and primaries measured from my 2209WA monitor (not calibrated yet), does it look right? I feel the luminance is a bit low compared to the other 2 devices? But maybe normal, I have no clue... smile.gif
colors.JPG 216k .JPG file
grayscale.JPG 242k .JPG file
ID:	77154   Click image for larger version
cfelicio is offline
post #5 of 7 Old 04-11-2014, 02:07 PM
randal_r's Avatar
Quoted: 168 Post(s)
Liked: 113
randal_r is offline
post #6 of 7 Old 04-12-2014, 12:31 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Originally Posted by randal_r View Post
I would make one more suggestion; buy yourself an i1 Pro 3.
spacediver is offline
post #7 of 7 Old 04-12-2014, 09:12 PM
randal_r's Avatar
Quoted: 168 Post(s)
Liked: 113
randal_r is offline
Reply Display Calibration
