Dummy calibrating a monitor with i1display pro - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 04-19-2014, 05:23 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Originally Posted by Stereodude View Post
You have to plug in your meter and have it on the screen again. It will make some measurements using the installed profile and give you a report of the results.
Here are the measurements report. Everything looks fine, but I could certainly use some feedback.
smokarz is offline
post #32 of 44 Old 04-21-2014, 11:09 AM
dschlic1's Avatar
Quoted: 73 Post(s)
Liked: 27
After some search and studying on the web, it looks like the icc profiles are only used by some programs, not all. For some reason Windows does not perform the color correction, nor do most graphics drivers. That being said, on my laptop, I have a rather high end NVIDIA graphic adapter and the driver for that adapter does allow a two point gray scale adjustment. That adjustment carries through for all programs on the computer including Windows itself.
I do not use i1Profile as there is no why to see or measure the results. It is color calibration for the masses. ColorHCFR or Argyll is the route I prefer.
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #33 of 44 Old 04-21-2014, 05:57 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Is there anyway to know which programs use icc profiles?
smokarz is offline
post #34 of 44 Old 04-22-2014, 11:14 AM
dschlic1's Avatar
Quoted: 73 Post(s)
Liked: 27
No really. Some times in the data sheet for the program it will say.
dschlic1 is offline
post #35 of 44 Old 04-22-2014, 01:23 PM
HDTVChallenged's Avatar
Liked: 215
Humm .... I'm not sure that's really true. In my experience with XP and Win7, a system wide ICC profile "sticks" unless a program deliberately resets the LUTs on the graphics card. On my laptop, it's obvious when this happens as the display's "native" CCT is in the 9500K range. In either case, one can usually reset to the desired ICC profile manually after launching a program. (Screen Resolution->Advanced Settings ... in Win7)
HDTVChallenged is offline
post #36 of 44 Old 04-22-2014, 02:25 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
As I wrote earlier in the thread, there is a software accessible component to the profile that is used by rare individual programs that have a "Use Color Management" option, e.g. Picasa. Most other programs lack the option, e.g. Paint .NET, and they can't benefit from this part of the profile. However, profiles also contain a hardware component (video card LUT and monitor settings) that is system-wide and set by programs like SpectraCal's PC Client 3, and all programs benefit from this. The Windows Color Management control panel has always baffled me, because setting different profiles as the default doesn't have any immediate, obvious system-wide effect. That is, when I switch between profiles in PC Client 3, there is an obvious change to my desktop background picture. This does not happen when I use the Windows control panel. How exactly are you making this happen?
sawfish is offline
post #37 of 44 Old 04-22-2014, 04:55 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
After I run DispCalGUI, and have it loaded the profile.
I then went into Color Management to confirmed the profile I've created after calibrating was loaded. It was.
smokarz is offline
post #38 of 44 Old 04-22-2014, 05:19 PM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1518
Color Gamut control/calibration is not possible...
PC/MAC are only can use VCGT (Video Card Gamma Tables) which are 1D LUT (RGB(Grayscale) & Gamma only), so your Color Gamut can't corrected, but if you are using a ICC capable software; like photoshop for example, your color gamut correction of your calibration you performed will be applyed there, If you open a picture there you will get the correct colors wink.gif
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #39 of 44 Old 04-22-2014, 06:05 PM
Liked: 215
On the color management page(Win7), try toggling the "Use My Settings for this Device" check-box twice. You should wind up with the box "checked." This forces windows to reload the default profile for the display.
It's kind of a crap-shoot, sometimes the profile loads on it's own at boot time, some times it doesn't ... I've just gotten into the habit of checking/toggling it manually every time I boot up.
post #40 of 44 Old 04-22-2014, 07:38 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Still doesn't have any effect on the desktop. Did you also use the Windows calibration feature accessible through the same control panel? I haven't done that and don't have any reason to. Maybe it's the prerequisite for getting Windows to program the LUT and set display settings with DDC. If so, I don't know why it would seemingly ignore the profiles created by Calman, which are the ones I'm switching between in the control panel. When I switch between them in Calman Client 3, there's an obvious change in desktop gamma.
sawfish is offline
post #41 of 44 Old 04-22-2014, 11:55 PM
Liked: 215
For Win7, Yes. You need to enable that check box on the system default page (Go to the "Advanced" tab and click "Change System defaults ..." button, then go to the "Advanced" tab on that page.) I can't help with Win8.x
But you *don't* want to actually do a "Windows Calibration" which amounts to nothing more than calibration by eyeball, IIRC.
Also you need to make sure the ICC or ICM profile is where Windows can find it and it should be set as the "default" for the device. The documentation is completely inadequate, and the Windows color management system is overly complicated if all you want to do is calibrate your display. Honestly, if your Calman solution is working well, the Windows Color Management might be more trouble than it's worth. smile.gif
post #42 of 44 Old 04-23-2014, 12:21 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
For the 8 y/o old monitor I was using, Calman Client 3 would annoyingly prompt me about reading DDC every single time it was started or I resumed from sleep, and since the application of the profile doesn't survive a reboot, I began looking into why. I hoped I could get away with using the Windows Control Panel applet, but it doesn't apply profiles the way Client 3 does; at least, I could not get it to apply the LUT and monitor adjustments. While Client 3 behaves perfectly with my new monitor and TV, I do have issues with it when logging on as a different user. It would be great if I could avoid running it except during calibration, but I can't get the Windows applet to do what Client 3 does.
As best I can tell, Windows Color Management supports visual calibration of a monitor and can record and later apply the changes one makes through it. It also supports central management of ICM profiles, including the ones Calman creates, and software that is color management-aware can query Windows for the profiles and use them. However, the Windows applet apparently cannot apply the LUT and monitor adjustments contained in those Calman ICM profiles, which makes it pretty much useless to me.
sawfish is offline
post #43 of 44 Old 04-23-2014, 01:36 PM
derekjsmith's Avatar
Liked: 116
Update to the current version of Client 3. It does this rediscovery silently now.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #44 of 44 Old 04-23-2014, 02:26 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
AFAIK, I am using the latest Calman Client, 3.0.1.61. When I log off Windows 7 x64 and back on as a different user (both admin accounts), I get two error boxes with the messages:
1. Access to the database file is not allowed. [ 1914,File name = C:\ProgramData\SpectraCal\CalMAN Client 3\Data\MonitorsDB.2.3.sdf,SeCreateFile ]
2. Object reference not set to an instance of an object.
When I log off and back on to my usual account, it works fine.
I've also noticed that the program also leaves behind a ton of detritus; I currently have 1,595 ICM files with GUID names in my temp folder dating back three weeks.
sawfish is offline
Reply Display Calibration
