Lumagen New Radiance 21xx Video Processors - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31 of 54 Old 07-14-2014, 06:24 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1053 Post(s)
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070314 Firmware Update
Release Notes
Fix for issue with rs232 test pattern usage that would often give a corrupted picture. (Update time ~3 minutes @57k)
Download Link
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #32 of 54 Old 07-15-2014, 05:43 PM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070414 Firmware Update
Release Notes
Another rs232 test pattern problem fixed.
An issue with screen being blank fixed.
Problem with using left arrow on remote for aspect changes fixed. (Update time ~3 minutes @57k)
Download Link
post #33 of 54 Old 07-17-2014, 12:22 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070514 Firmware Update
Release Notes
One more fix for an issue with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
Download Link
post #34 of 54 Old 07-19-2014, 12:40 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070714 Firmware Update
Release Notes
Found 2 other issues with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
Download Link
post #35 of 54 Old 07-22-2014, 12:40 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070814 Firmware Update
Release Notes
A fix for exiting test patterns when using vertical shift (bottom of screen left uncleared). (Update time ~3 minutes @57k)
Download Link
post #36 of 54 Old 07-31-2014, 11:52 PM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072014 Firmware Update
Release Notes
Small horizontal and vertical chroma improvements.
Added a CUE (chroma upsample error) setting under Input: Video Setup: RES: Picture.
Fixed an issue to handle 720p50 framepacked 3D source.
Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (Update time ~15 minutes @57k)
Download Link
post #37 of 54 Old 08-03-2014, 05:46 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072114 Firmware Update
Release Notes
Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (note: bug occurred in 072014 and this update replaces it) (Update time ~15 minutes @57k)
Download Link
post #38 of 54 Old 08-13-2014, 03:06 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072214 Firmware Update
Release Notes
Improved the CUE filter menu, filter did not immediately turn on when enabled. (Update time ~3 minutes @57k)
Download Link
post #39 of 54 Old 08-26-2014, 12:37 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 080114 Firmware Update
Release Notes
Fix for a configuration saving issue that didn't allow the "undo save" to work properly.
Also, another fix for working with the configuration utility.
Note the configuration utility was also just updated to version 1.8. as the earlier version was not downloading the CMS portion of the configuration to save on a PC for 21XX units. If you backed up your 21xx configuration earlier you should back it up again after performing this update and downloading the new 1.8 version of the configuration utility.
There were some improvements to the config utility as well. (Update time ~3 minutes @57k)
Download Link
post #40 of 54 Old 08-27-2014, 07:40 PM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
We are a day or two away from releasing the 17x17x17 3D LUT for the 21XX series. Note this is only for the 21XX series. The 20XX units remain at 9x9x9, and the other Radiance units at 5x5x5.
Spectracal and Chromapure now have a 21XX unit for testing, and we will have a unit in the U.K. for Light Illusion next week. None have the Radiance 17x17x17 release yet, but we will be posting it in the next two days or so.
Based on my communications with all three companies it sounds like all will make it a priority to get their programs updated for the larger Radiance cube size pretty quickly especially since the commands are essentially the same as the 9x9x9 cube (with a couple minor additions).
Jim Peterson
Lumagen
jrp is offline
post #41 of 54 Old 08-28-2014, 12:56 AM - Thread Starter
Liked: 1517
Hello Jim, LightSpace is already supporting the 17x17x17 for Lumagen 21xx Series from 28 May 2014 with LightSpace CMS 6.6.0.1901 release.
post #42 of 54 Old 08-28-2014, 01:01 AM - Thread Starter
Liked: 1517
Jim, do you recommend for the 21xx users to perform for the start the 21-Point RGB Balance of the 1D LUT Table and later move to 17-Point Cube or skip the 1D LUT Table?
post #43 of 54 Old 08-28-2014, 08:42 PM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
It is possible unless they are using the "Fast 3D LUT write command" (which I believe they are). This command did not get extensions for 17x17x17 until last week and we only notified the calibration software companies this week. Other aspects of the 3D LUT accesses are the same, so if they have an option to use the older "Slow" 3D LUT write mode it could work, but then it would take a long time to write the 17x17x17 LUT
We have increased the BAUD rate for 3D LUT writes and reads in the new release as well, so using the Fast 3D LUT Write, the time to write the 9x9x9 with old software is about the same as writing the 17x17x17 with new software.
So I am sure they will have a new release soon to support both Fast 3D LUT Write and the faster BAUD rate.
Jim Peterson
Lumagen
jrp is offline
post #44 of 54 Old 08-28-2014, 08:55 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Hello Jim.
Please see this post.
HCFR - Open source projector and display calibration software
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #45 of 54 Old 08-28-2014, 09:11 PM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
Because of the way the 1D LUT and 3D LUT interact near the gray vector, you still should do the 1D LUT first.
My brief synopsys of Radiance calibration is now (with Radiance at defaults):
Set black and white levels in display/projector using Radiance adjustable patterns.
Set 100% White-balance in display/projector using Radiance adjustable patterns (when possible, else use Radiance in 2-point 1D LUT mode)
Check Gamma and use Radiance Gamma-Factor for coarse Gamma
If you change Gamma-Factor, recheck Black and White levels.
Calibrate with Radiance 1D LUT.
Calibrate with Radiance 3D LUT.
Recheck grayscale. While we officially recommend to not change the 1D LUT after changing the 3D LUT, 1D LUT tweaks may help overall dE's.
If you have to calibrate the 100% White Balance in the Radiance, this might not stay calibrated with some calibration software if you auto-calibrate grayscale, and so you would have to manually calibrate grayscale. Many professional calibrators still prefer to calibrate grayscale manually, so this may or may not be an issue.
Kris Deering likes this.
Jim Peterson
Lumagen
jrp is offline
post #46 of 54 Old 08-29-2014, 12:43 PM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 081514 Firmware Update
Release Notes
Added 17x17x17 CMS (4.913 Color Points) along with corresponding menu and rs232 command options.
Added option to enable Darbee enhancement for just 2d or just 3d sources.
If you back up your setup to a PC Be sure to download the new configuration (v1.8) utility from the Lumagen Utilities page to use with your Radiance 21xx. (Update time ~15 minutes @57k)
Download Link
post #47 of 54 Old 09-03-2014, 03:42 PM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 081814 Firmware Update
Release Notes
Location values for 17x17x17 gamut adjustment via the menu were off by 1 for a few locations due to a rounding error. (Update time ~3 minutes @57k)
Download Link
post #48 of 54 Old 09-08-2014, 02:48 PM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 082014 Firmware Update
Release Notes
Bugfix for configuring analog composite inputs (2143, 2144 only). The menu would show settings being made for these inputs without corresponding changes to the picture. (Update time ~3 minutes @57k)
Download Link
post #49 of 54 Old 09-09-2014, 03:25 PM - Thread Starter
Liked: 1517
CalMAN 5.4.0 build 1632 Open Beta Released @ 09 September 2014
Release Notes
This is an early open beta of CalMAN 5.4.0 which contains support for the new Lumagen 21xx series and the 17x cube sizes.
In adding this support, we needed to make some changes which could potential affect the older Radiance models. We have not seen evidence of that in our internal testing, but please let us know if anything pops up.
Download Link
WiFi-Spy likes this.
post #50 of 54 Old 09-13-2014, 03:03 AM - Thread Starter
Liked: 1517
LightSpace CMS 6.6.3.1972 (12 September 2014) Closed Beta
Light Illussion has released a Closed Beta Version of LightSpace CMS that supports the Lumagen 21xx uploading of 17-Point Cube 3D LUT Tables.
Because I don't have a Lumagen 21xx here to test it, If any LightSpace user with Lumagen 21xx need to test it, I can provide him the download link via a simple PM.
post #51 of 54 Old 09-20-2014, 03:06 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 091014 Firmware Update
Release Notes
Fix for a bug which under some circumstance could give strange colors in grayscale intermittently. (Update time ~15 minutes @57k)
Download Link
post #52 of 54 Old 09-23-2014, 12:28 AM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 091114 Firmware Update
Release Notes
Fix for an issue that changes a 17x17x17 CMS to an 8 point CMS when copying from a CMS location to another. (Update time ~3 minutes @57k)
Download Link
post #53 of 54 Old 09-30-2014, 04:02 PM - Thread Starter
Liked: 1517
CalMAN 5.4.0 build 1752 Open Beta Released @ 01 October 2014
Release Notes
The only real change is the new Radiance 21xx series should work at the higher baud rate across the USB port.
Note - There's currently an issue that is you connect to the Radiance as a Source after you connected to it as a display, it may not use full speed.
We're still looking at the performance issues some of you have reported.
Download Link
post #54 of 54 Old 10-14-2014, 12:46 PM - Thread Starter
Liked: 1517
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 100514 Firmware Update
Release Notes
Fix for not correctly handling Pal (576i) video on analog inputs and not being able to power up on an analog input.
This update is only helpful for units with analog inputs (2124/2144). (Update time ~3 minutes @57k)
Download Link
Reply Display Calibration
