I just picked up a CL-200 (not a CL-200A) from a forum member and should have the meter by the end of the week. Does anyone know which software programs support this meter and if you do, could you recommend one that you think is best suited for this meter and is the most intuitive. I was looking into Calman or Chromapure but I don't see anywhere on their websites saying this meter is supported.
Originally Posted by Seegs108 /t/1532605/software-recommendations-for-a-minolta-cl-200#post_24741630
Yes some CalMAN licenses do support the CL-200. Also note the communication cable is proprietary and is expensive from KM if yours did not come with one. We do however have the pinout and connector part numbers so you can build your own with parts from Digikey.
Yes, it's possible with meter addon, SpectraCAL is flexible with Home users that need to use a better meter that is not supported with their current licence. They can offer you a meter addon for a price.
I contacted SpectraCal and they told me they can't offer me a add-on for my meter and that I'd need to buy a Professional version of their software. The cheapest version that supports my meter is $1599. Yikes...
Are there no other calibration software suites that support this meter for something a bit more reasonable? Reasonable to me would be under $500.
what exactly are you hoping to measure with the instrument, and what controls will you be using to calibrate the thing you're measuring?
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
