calibrating LG TV with HCFL blue channel problem - AVS Forum | Home Theater Discussions And Reviews
Old 06-13-2014, 03:33 AM - Thread Starter
niro750's Avatar
Question calibrating LG TV with HCFL blue channel problem
Hi all, when calibrating my display with my new colourmunki display I was able to use 10 point IRE with my setup disc and above very acceptable results but... In the higher IRE chapters I noticed that the blue channel was sitting far too high. Adjusting the colour temperature to warn brought it down but only so far after maxing out the blue channel adjustment at -50.
The only way I found I could get it to read 100% was by boosting the red and green channels to compensate (i realise you don't normally adjust 3 channels) so the overall light output of the top few IRE. Settings are now a bit brighter, I dropped the contrast a tad to keep my output at about 40 fL which is comfortable.
Is there any real problem with doing this? Or is there a better way of bringing the blue down? My errors were tiny up until about 70 IRE.
Cheers guys.
niro750 is offline
Old 06-14-2014, 01:32 AM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
Make sure you choose the most accurate pre-set picture mode before you dive into the calibration. Usually we pick Movie/Cinema mode. If you are using any other mode, there will almost always be a heavy blue push. And pick a color temperature that is the closest to 6500 kelvin (usually warm 2). That being said, it is always better to have a blue error vs red or green. But since you are doing a 10 pt adjustment, you should be able to nail down all errors if done correctly ofcourse.
ZKACAL is offline
Old 06-14-2014, 01:02 PM - Thread Starter
niro750's Avatar
Thanks, I am using the isf calibration setting which I think overrides the likes of game and cinema. I have selected the warmest temperature and it left me with blue levels at about 115% after adjusting the blue down as far as possible. I pushed the green and red until all were 100% but I think it has thrown the luminance out a bit and now I think I need to get the gamma calibrated better
niro750 is offline
Old 06-19-2014, 11:36 AM
HDTVChallenged's Avatar
Liked: 215
Model number would help. Plasma or LCD/LED? ... I'm guessing LCD since it's 10pt.
First reset all the 10pts adjustments to zero.
For LG's start at 100% and work your way down. Also you need to verify that contrast is set properly so that both whiter-than-white can be displayed without clipping and that the 10pt controls actually line up with the appropriate video levels. (80 for 80, not 80 for 90) On my LG these two contrast settings happen to line up "perfectly."
PS: Adding red is as effective as subtracting blue. (Holding green constant.)
HDTVChallenged is offline
