How low can the i1 display pro read - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #31 of 58 Old 06-20-2014, 09:38 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Originally Posted by TomHuffman View Post
My point exactly. Grayscale should be about chromaticity errors only. If you want to consider luminance errors, then look to gamma. Perhaps I misunderstood what the previous poster was referring to by "absolute Y W/O Gamma".
Sorry I misunderstood you.
spacediver is offline
post #32 of 58 Old 06-20-2014, 10:26 PM
HDTVChallenged's Avatar
Liked: 215
To clarify: HCFR users should use dE76 (Luv) with "relative Y" if you want to iron out the greyscale as much as possible. Alternatively, one could just minimize the delta-xy readings, with the "recommended" dE setting.
RyanHomsey likes this.
HDTVChallenged is offline
post #33 of 58 Old 06-21-2014, 03:23 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
yes, the default behavior is the same as what's used in CM, ArgyllCMS, and LS - the grayscale is treated just like any other color, and color differences are calculated in a color space where L* = 100 is at reference white.
If you wish to use a different luminance reference (to amplify grayscale errors for real-time adjustments for example) you should use the relative Y option although the absolute values obtained are of questionable perceptual relevance. In my opinion the relative Y numbers do not correlate well with perceived errors for very low luminance patches (say 10% video level and below). Another alternative is to use the "gray world" assumption option, this will assign L* = 100 to the 15% linear light level which is a typical average luminance level in film and video reproduction.
zoyd is offline
post #34 of 58 Old 06-21-2014, 05:16 AM
zoyd's Avatar
Liked: 1064
The CIEDE2000 for this pair of colors is 7.3.
or,
The CIEDE2000 for this pair of colors is 9.4. Ordinarily, using this method would result in a much lower dE score, but in this particular instance both the chromaticity and the luminance have large errors.
yes, choosing the relative Y option will yield dE = 7.3 for this measurement and choosing the absolute with gamma will yield dE = 9.4.
The absolute Y w/o gamma option sets the target luminance equal to the measured luminance to remove the L component of the error vector. This yields better correlation with perceptual errors than the relative Y option for most of the levels. But I always recommend to switch to the full error vector for final proofing after gamma adjustments to get the full picture. This particular measurement is not a good example to use because as you point out the luminance error is very high and driving the error vector more then is typical.
zoyd is offline
post #35 of 58 Old 06-21-2014, 10:13 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
When I have time I'll take some more measurements after Argyll gamma correction and post the delta Es with the more stringent settings.
post #36 of 58 Old 07-16-2014, 03:40 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Originally Posted by gwgill View Post
Using the ArgyllCMS driver in it's default mode, it will integrate for 20 seconds, and the lowest non-zero value of Y seems to be about around 0.002 cd/m^2.
That's exactly what my black level reads with the i1 display pro - 0.002 cd/m^2.
post #37 of 58 Old 07-16-2014, 07:10 PM
<^..^>Smokey Joe's Avatar
Quoted: 75 Post(s)
Liked: 101
0.002 cd/m^2 +/- what?
Masterpiece Calibration Ltd
Lincolnvilleshire
New Zealand
<^..^>Smokey Joe is offline
post #38 of 58 Old 07-16-2014, 07:14 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
that was the reading I got when I measured my min luminance on my display: 0.002 cd/m^2. It didn't give me a confidence interval or anything. Not sure what you mean!
post #39 of 58 Old 07-16-2014, 07:47 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
0.002 cd/m^2
isn't that @ .0007 ftl
CalWldLif is offline
post #40 of 58 Old 07-16-2014, 08:11 PM
Quoted: 75 Post(s)
Liked: 101
Detection alone is not accuracy, detection is where a signal starts returning a value, but it is rare that detection limit and repeatable accuracy are the same. Hence +/- (value) around the around the measured value. At the detection limit the +/-(value) typically grows in error.
For reference equipment the error is typically around <2% of the sweet spot, for example the Jeti 1211 Spec is ± 2 % @ 100 cd/m² and illuminant A
So that is 98cd/m² ~ 102cd/m² of the reading value
Error can get worse around detection limits, it could be 10~20% or more. Reference equipment can hold 2% to close to the detection limit, however there is always a roll off.
The reported spec for the i1D3 is 0.1cd/m² but be sure the accuracy at 100cd/m² is by chance as good as a reference device.
So far no one has shown stats with proof that anything below 0.1cd/m² is anything but signal noise.
Lincolnvilleshire
New Zealand
post #41 of 58 Old 07-16-2014, 08:12 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Originally Posted by CalWldLif View Post
0.002 cd/m^2
More like 0.00058 ftl, but yes
And it might well be lower - I'm hoping to get a minolta LS-100 to test it!
post #42 of 58 Old 07-16-2014, 08:21 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Detection alone is not accuracy...
True, but if I'm understanding Zoyd's measurements correctly (reported earlier in this thread), the precision of the instrument is around that level.
I'll take some near black measurements tonight from the first few consecutive video levels. The results might speak to how much of the readings are due to noise.
post #43 of 58 Old 07-16-2014, 09:42 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
So at night, my black level is apparently too low to register, so I loaded up a LUT that raises the black level - here are some readings (in cd/m^2):
0%: unable to read
1%: 0.002
2%: 0.008
3%: 0.017
4% 0.027
Highly unlikely that anything below 0.01 let alone 0.1 is noise.
post #44 of 58 Old 07-16-2014, 10:11 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
0%: unable to read
1%: 0.002
2%: 0.008
3%: 0.017
4% 0.027
wow. what tv?
post #45 of 58 Old 07-16-2014, 10:30 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
wow. what tv?
It's a computer monitor: Sony GDM-FW900 - 24 inch widescreen high resolution CRT, often used in professional video studios up until a few years ago.
post #46 of 58 Old 07-16-2014, 11:44 PM
-Hitman-'s Avatar
Quoted: 164 Post(s)
Liked: 117
Had my I1D3 for a couple of months, on my Pioneer KRP-600m, I get between 0.00045fl and 0.0004fl.
-Hitman- is offline
post #47 of 58 Old 07-17-2014, 02:30 PM
Quoted: 75 Post(s)
Liked: 101
0%: unable to read
1%: 0.002
2%: 0.008
3%: 0.017
4% 0.027
Look, I'm not trying to pop your balloon, or anyone elses for that matter. Trouble is this, measured value and intended value can be two intirely different things. The intended value is the reference level, just because you measure something at the detection limit of the detector doesn't actually mean that it returns a value resembling the intended reference value, you might even be able to repeat the measured value, but it could still carry 20% error. The light source might not even output the correct reference value, how do you know unless you have ultimate reference systems.
What I'd call reference here is a CS2000 or PR670, intergration spheres and pure/controlled light sources, even my Jeti 1211 isn't good enough because it isnt sensitive enough for this low level.
The Device is rated at 0.1 cd/m^2 probably because this is where intended values and measured values become an an acceptable difference. Below that detected values measured will fall foul of compounded error, where you could state that something has been measured, but the actual error is unknown. You can't even place a dE value upon it.
Lincolnvilleshire
New Zealand
post #48 of 58 Old 07-17-2014, 02:55 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
Dnice modified? I didn't think stock 600m's got that low, only 500m's did.
sorry for being off topic....
1forsnow is offline
post #49 of 58 Old 07-17-2014, 03:03 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
I thought we were talking about precision here, not accuracy.
Keep in mind that the Jeti 1211 is a spectroradiometer, which is a class of instrument generally less sensitive than a colorimeter.
When it comes to precision, however, I think we have some very solid data indicating that the precision of the instrument is around 0.002 cd/m^2.
post #50 of 58 Old 07-17-2014, 03:16 PM
-Hitman-'s Avatar
Quoted: 164 Post(s)
Liked: 117
Tweaked yes but not by D-Nice.
That measurement was taken as an average from calman5 with auto sync, sync on - I either get 0004 or an error code in CM like "E2 XX" instead of measurement data from the D3.
-Hitman- is offline
post #51 of 58 Old 07-17-2014, 03:41 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
0%: unable to read
1%: 0.002
2%: 0.008
3%: 0.017
4% 0.027
Different TV but additional data for the Display Pro (Display 3.)
The Official ChromaPure thread
Larry
LarryInRI is offline
post #52 of 58 Old 02-22-2015, 06:22 AM
Soulnight's Avatar
Quoted: 272 Post(s)
Liked: 178
I am with you.
So nobody compared the low values with the minolta LS 1000, or Klein K10a?
0,002cd/m2 +- ??%
Actually even for the minolta ls 100, the values are maybe not so accurate as people believe because the +-2,5% are given for a color temperature of about 2800K.
Like almost all luxmeter around here, the precision given (3%) is for a luminance A (about 2800K). And for some other color temparature, It can be really far from it.
Exemple with the AEMC CA813: 0,01lx+-3% @ 2800K BUT +-11% for some other light sources...
Soulnight is offline
post #53 of 58 Old 02-23-2015, 03:56 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
somewhat relevant, I ended up using a DSLR to measure my display's black level - got around 0.0006 cd/m2. Writeup over here
post #54 of 58 Old 10-28-2015, 10:24 AM
Soulnight's Avatar
Quoted: 272 Post(s)
Liked: 178
Originally Posted by zoyd View Post
Based on the precision seen 0.002 nit differences are measurable given enough averaging. Both ChadB and LarryinRI have reliably measured VT60s at these levels with the D3.
Hi,
so say you have measured 0.005nit with i1 display pro.
You are saying that the truth could be anywhere between:
0.005-0,002
0.005+0,002
Thank you.
post #55 of 58 Old 10-28-2015, 02:54 PM
zoyd's Avatar
Liked: 1064
That's a reasonable assumption. The display pro agrees with my CR-100 to +/- 0.001 @ 0.008 nits when measuring my plasma black level.
W3Rman likes this.
zoyd is offline
post #56 of 58 Old 10-28-2015, 03:17 PM
Soulnight's Avatar
Quoted: 272 Post(s)
Liked: 178
post #57 of 58 Old 10-29-2015, 10:15 AM
Quoted: 132 Post(s)
Liked: 4
Good CRT monitors can have "infinite" contrast ratio and extremely low black levels that maybe only Klein K-10 can detect or whichever is the most powerful colorimeter there is. I can't wait to save up $1200 to buy that CRT monitor and experience amazing image quality. My FG2421 pales in comparison to it, aside from sharpness.
Hardware: i1Pro & i1Display Pro. Software: CalMAN 5 Enthusiast Edition, HCFR Calibration, ArgyllCMS + dispcalGUI, madVR.
HDTV: Samsung LN40B550 40" CCFL SPVA LCD @ 1080p, 60Hz, 2700:1 CR. Gaming Monitor: Eizo Foris FG2421 24" LED MVA LCD @ 1080p, 120Hz + backlight-strobing, 4700:1 CR.
HTPC: Intel i7 3770K @ 4.8Ghz, 16GB 2200Mhz RAM, GeForce GTX 1080 @ 2000/11000Mhz, 256GB + 500GB SSD, 2TB HDD, Windows 10 Pro (x64)
Masharak is offline
post #58 of 58 Old 10-29-2015, 10:47 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Originally Posted by Masharak View Post
Good CRT monitors can have "infinite" contrast ratio and extremely low black levels...
I don't think this is true. I've tested quite a few high end trinitrons, and the guns don't turn off completely, even with very low G2 voltages.
... that maybe only Klein K-10 can detect or whichever is the most powerful colorimeter there is.
If you have patience, time, and some programming know how, you can use a DSLR, along with a regular colorimeter, to detect even lower luminances than a Klein. See my method here.
Reply Display Calibration
