How low can the i1 display pro read - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 58 Old 06-13-2014, 08:51 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
I'm considering getting an i1display pro so that I can properly adjust the gamma of my FW900 using Argyll. Right now, the black level of my display is below 0.01 nits, which means that my DTP-94 can't pick it up. As a result, I'm unable to generate an appropriate LUT without raising the black level.
According to Tom Huffman, it is capable of reading down to 0.003 cd/m2, which might be good enough for my needs (I'm gonna try and borrow a Minolta LS-100 from my lab to check, since that unit reads down to 0.001 cd/m2).
Here is the page where Tom describes his data:
http://www.chromapure.com/newgear_display3.asp
I'm wondering if anyone else can confirm this low light capability of the i1d3. Note: I'm not interested in accurate chromaticity readings, I'm just concerned with its ability to accurately measure low luminances.
spacediver is offline
post #2 of 58 Old 06-14-2014, 10:22 AM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
That is what I've found as well looking at this data set, at low light levels the 1-sigma uncertainty in Y is 0.002 nits when using the Klein as a reference.
zoyd is offline
post #3 of 58 Old 06-14-2014, 11:03 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Yea, I looked at your thread recently and was amazed at that level of precision at low light levels. I don't see any measurements at levels lower than 0.01 nits in that data set (though I haven't looked through the .ti3 files). But I'm assuming in different cases you've found the i1d3 can measure below 0.01 nits right? Off hand, do you remember the lowest reading it reported?
post #4 of 58 Old 06-14-2014, 11:08 AM
Chad B's Avatar
Quoted: 495 Post(s)
Liked: 1185
In CalMAN I've had my i1D3 report readings as low as .0006 fL with good repeatability with the LLH on 5 seconds.
Chad B is online now
post #5 of 58 Old 06-14-2014, 11:28 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
wow, Chad, that is remarkable.
post #6 of 58 Old 06-14-2014, 11:33 AM
zoyd's Avatar
Liked: 1051
Based on the precision seen 0.002 nit differences are measurable given enough averaging. Both ChadB and LarryinRI have reliably measured VT60s at these levels with the D3.
zoyd is offline
post #7 of 58 Old 06-14-2014, 11:40 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
ah, right - I didn't make the connection, understood.
post #8 of 58 Old 06-15-2014, 06:40 PM
gwgill's Avatar
Quoted: 245 Post(s)
Liked: 182
It will depend on the driver a little (i.e. don't expect the X-Rite and ArgyllCMS drivers to have precisicely the same behavior), but ultimately the resolution is limited by the maximum integration time (20 sec) and the L2F sensors. So one transition in 20 seconds is the lowest possible limit. In practice there may be a threshold below which the sensor returns 0.
Using the ArgyllCMS driver in it's default mode, it will integrate for 20 seconds, and the lowest non-zero value of Y seems to be about around 0.002 cd/m^2.
gwgill is offline
post #9 of 58 Old 06-15-2014, 07:22 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
thanks for this info, quite a remarkable piece of hardware.
post #10 of 58 Old 06-18-2014, 08:50 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Since this old issue has come up again, I thought that I would re-do my initial test, this time using greater precision.
You can see the result by going to our i1Display Pro New Gear article, scrolling down to the update under Low-Light Sensitivity Test. Or if you can just go directly to the video.
spacediver likes this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #11 of 58 Old 06-19-2014, 05:41 AM
22point8's Avatar
Quoted: 141 Post(s)
Liked: 70
Sony PVM 2044QM (made in January 1990), thats as good as the greyscale gets because the front panel green gain pot doesn't work so theres only green bias. Anyway, 0.002cdm2 black (0.002278).
22point8 is offline
post #12 of 58 Old 06-19-2014, 05:42 AM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
In order to get accurate reading of the black floor you would need a Klein K10 that reads all the way down to 0.00002 fl.?
trans_lux is offline
post #13 of 58 Old 06-19-2014, 08:47 AM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1521
Hi, Klein K-10A takes 256 measurements per second at any luminance level, low/ultra low/ high..whatever..... From these 256 measurements it's doing an average internally and returns the results to the software 8 times per second, this means that it's measurement time is fixed at 125 ms. (0.125 sec).
The advantage of that fixed 125ms measuring time is that the patch you are measuring it's measured instantly, when you hit measure.
There tons of displays that are autodimming when you display a patch for some seconds more than normally, a lot of displays like LED's are shutting down their backlight or some plasma (like KURO) are entering to a panel 'shutdown' mode.
When you will try to measure these displays black level with a meter other that Klein, you are not sure that the returned results are accurate because during the about 10-20 seconds that will require to return you the results, the panel's luminance level will not be the same during all this time.
buzzard767 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #14 of 58 Old 06-19-2014, 09:34 AM
Chad B's Avatar
Quoted: 495 Post(s)
Liked: 1185
Ted, do you know if that means that a single read sample of the K-10a in CalMAN is actually an average of 32 readings (256/8)? And if that's the case, would setting Calman to 3 read average mean that readings would take less than half a second and be an average of 96 readings? That would make CalMAN's LLH settings for the Klein seem like overkill.
What about ChromaPure, do you know if it's the same? Thanks.
post #15 of 58 Old 06-19-2014, 09:45 AM
Chad B's Avatar
Quoted: 495 Post(s)
Liked: 1185
When I take black level readings with my i1D3 on a display that dims with no signal, I put up a pattern with a bit of content somewhere else on the screen to keep the display "awake". With displays like the Samsung F8500 with it's floating blacks and Black Optimizer, that can return very different results than a totally black screen, but arguably more relevant.
post #16 of 58 Old 06-19-2014, 10:21 AM
Liked: 1521
If I remember well, one time I was checking the measurements log files with CalMAN it takes to measure about 50ms with single measurement, but I will confirm it the next time
125 ms is for LightSpace.
post #17 of 58 Old 06-19-2014, 11:15 AM
HDTVChallenged's Avatar
Liked: 215
As I've said before ... sometimes our fond memories and high regards for CRT tech is very often ... unwarranted.
I wonder how many transfers and color grades, over the years, were created using CRT monitors with a blue bias in the lower range of the grayscale. ...
ConnecTEDDD likes this.
HDTVChallenged is offline
post #18 of 58 Old 06-19-2014, 12:07 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
I'd like to think that studios wouldn't be that sloppy (plus they probably used BVMs, though not sure about this).
The FW900 was also used in practice in many studios.
Here are some recent measurements of my FW900 after only a hardware calibration using the service port. The gamma is way dark because I brought the G2 voltage to a ridiculously low level, but after Argyll, I'm able to get a virtually perfect 2.4 gamma response (and without any quantization artifacts). The values shown are before I used Argyll. I may be receiving a minolta LS-100 soon and will share the near black response when I do.
The grayscale tracks remarkably well despite the process only involving essentially a 2 point grayscale adjustment. (edit: note that these are CIE76 values, which are lower than CIE 2000)
Here are the same measurements but using the CIE2000 delta E formula:
post #19 of 58 Old 06-19-2014, 05:19 PM
Synnove's Avatar
Nice results. Only limited to 80nits though? I'm sure if you get a LUT box hooked up to it you'll end up with fantastic results. What's the gamut like?
Synnove is offline
post #20 of 58 Old 06-19-2014, 06:29 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
More like 89 nits, which is about factory spec for these units. I could drive it higher but that would probably reduce the lifespan of the tube. Plus, halation is an issue with these units (lighter areas spread their glow to surrounding areas), and that would likely be magnified if I increased peak luminance.
Because these CRTs are so linear, not sure how much difference a LUT box or a 3D LUT would make, but it is something I'm looking forward to experimenting with.
phosphors are based on the SMPTE-C primaries (which is a gamut associated with Rec 601). Not quite Rec 709 but close enough. Interestingly, much HD material was until quite recently mastered with these primaries.
post #21 of 58 Old 06-20-2014, 10:56 AM
Liked: 215
Here is the pitfall in relying on dE numbers alone ... you're clearly off the rails at 20% and below. y=0.3176 and y=0.3095 is *quite* blue relative to D65. Whether or not this is a "major" problem visually is another topic.
PS: Studio's not sloppy? How about "Bram Stoker's Dracula" (BD) ... "Blade Runner" (DVD) ... just off the top of my noggin.
post #22 of 58 Old 06-20-2014, 11:23 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
dE isn't the problem, it is the way it is being calculated in this case. The CIELUV dE of x0.3108, y0.3176 is 9.3. CIELAB is 6.9. CIEDE2000 is 11.4. However, this screenshot reports only 1.1. This is not correct.
Tom Huffman
Springfield, MO
post #23 of 58 Old 06-20-2014, 11:44 AM
22point8's Avatar
Quoted: 141 Post(s)
Liked: 70
The absolute Y W/O Gamma might account for it.
22point8 is offline
post #24 of 58 Old 06-20-2014, 03:19 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
The formula takes the luminance into account, since this is perceptually relevant when perceiving color difference.
post #25 of 58 Old 06-20-2014, 03:25 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Even taking that into account (which you shouldn't), the CIEDE2000 dE is 3.5, assuming a 2.22 gamma.
Tom Huffman
Springfield, MO
post #26 of 58 Old 06-20-2014, 03:44 PM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Why shouldn't you?
There are contexts where one is only interested in chromaticity errors, discounting what the luminance should be at any given input level, and this is most certainly one of them, as I am only interested in how the grayscale tracked.
post #27 of 58 Old 06-20-2014, 04:00 PM
zoyd's Avatar
Liked: 1051
The screenshot is correct if you use 88.97 nits for Ywhite when calculating Lab (or Luv) coordinates for reference and target. This suppresses color differences when comparing dark patches which one could argue is appropriate if you are luminance adapted to scenes with a peak white present. If you want a more sensitive measure use the "relative Y" option, this will scale the white reference for conversion to Lab (Luv) such that L* = 100 at Y=0.47 nits for the 20% patch for example.
zoyd is offline
post #28 of 58 Old 06-20-2014, 06:33 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Lab and Luv ALWAYS use relative luminance to assign a value for lightness in the 0-100 range. Peak white in almost never present in film content, which is a relatively dim medium. In fact, it is rarely over 50%.
There are only two ways to do this. Either you look at the chromaticity difference only and ignore the luminance, in which case,
Reference
L: 100
a: 0.0
b: 0.0
Measured
L: 100
a: 4.88
b: -4.85
The CIEDE2000 for this pair of colors is 7.3.
or,
you include luminance with an assumed gamma (2.22 for the example), in which case
Reference
L: 19.26
a: 0
b: 0
Measured
L: 4.697
a: 0.599
b: -0.6039
The CIEDE2000 for this pair of colors is 9.4. Ordinarily, using this method would result in a much lower dE score, but in this particular instance both the chromaticity and the luminance have large errors.
What you doing is really weird. You assign the SAME L value of 19.26 to both reference and test color. In other words, for the measured color you use the ideal luminance for 20% regardless of how it actually measures. This is the worst of both worlds. You consider luminance in that you use the expected luminance of that video level, but then you also ignore luminance by using the ideal luminance for the test value. This results in an absurdly low color difference of 1.1 for a color that is visibly blue (relative to D65) and with an awful gamma of 3.26. I would suggest that this is not very helpful.
Tom Huffman
Springfield, MO
post #29 of 58 Old 06-20-2014, 06:36 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Why shouldn't you?
My point exactly. Grayscale should be about chromaticity errors only. If you want to consider luminance errors, then look to gamma. Perhaps I misunderstood what the previous poster was referring to by "absolute Y W/O Gamma".
Tom Huffman
Springfield, MO
post #30 of 58 Old 06-20-2014, 06:40 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
No, it really doesn't. See my post below. In one way it does, while in a more important way it does not.
Tom Huffman
Springfield, MO
Reply Display Calibration
