Calman & C6 capable of laser/LED based calibration? - AVS Forum | Home Theater Discussions And Reviews
Old 06-17-2014, 10:10 AM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
I have a Panasonic PT-RZ370U in my possession and would like to see what I can get out of it. Its a single chip DLP with LED/Laser-combined (R, B: LED; G: Laser diode) light engine.
http://www.panasonic.com/business/pr.../PT-RZ370U.asp
This is for a commercial application with strictly PC/MAC sources for power point presentations.
If so what would the recommended table, color space and gamma targets?
BTW this projector looks remarkably good. Black floor is probable too high for dedicated HT use but a media room with some ambient light it would be perfect.
I'll post my measurements and opinions post calibration.
Thanks in advance for the guidance.
TL
trans_lux is offline
Old 06-17-2014, 02:14 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
RGB LED is going to be your best bet.
You'd probably need to profile against a spectro to get the last little bit of accuracy.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 06-18-2014, 08:22 AM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Thanks Joel
Any recommendations on a target color space and gamma?
Usually I would use sRGB for pc/mac.
Old 06-18-2014, 02:47 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Originally Posted by trans_lux View Post
Thanks Joel
sRGB and Rec.709 are virtually interchangeable and what nearly all content is mastered for.
Joel Barsotti
SpectraCal
sotti is offline
Old 06-19-2014, 05:30 AM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Thanks Joel
sRGB gamma is 2.2?
Old 06-19-2014, 01:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Thanks Joel
sRGB gamma is 2.2?
no sRGB has it's own gamma that is very similar to BT.1886, but with a baked in tail instead of a measured offset.
Measuring black wasn't very feasible in 1996 when they established the standard.
Joel Barsotti
SpectraCal
sotti is offline
