Green Blacks on Sonys - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-21-2014, 11:14 PM - Thread Starter
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
After doing traditional 2 pt calibration on Sonys, I tend to end up getting a green push around 10% gray. Every other value is fine however. You can clearly see the green on the brightness pattern (17 and up). Is there any way to fix this without ruining the rest of the grayscale?
On my Panasonic plasma, I was advised to only calibrate the high end to avoid red blacks.
ZKACAL is offline
post #2 of 5 Old 06-22-2014, 06:32 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 41 Post(s)
Liked: 144
Greetings
Yes ... use a 10 point system ... a 100 point system... a 1000 point system. Wha!!!! the sony doesn't have one? Get an external processor to fix the problem.
Or compromise the dark end and fix the green by using your eye.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 5 Old 06-23-2014, 04:06 PM - Thread Starter
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
When I fix the green by using my eye, the rest of the grayscale gets tampered with. I guess I can try just the high end next time.
ZKACAL is offline
post #4 of 5 Old 06-23-2014, 07:54 PM
Quoted: 41 Post(s)
Liked: 144
Greetings
Sometimes you just accept that your TV is imperfect. Every TV has some idiosyncrasy ... different they may be. If this is not an issue, then there is another issue that will bug you and you fixate on that.
Regards
post #5 of 5 Old 06-24-2014, 02:23 AM
ConnecTEDDD's Avatar
Quoted: 1732 Post(s)
Liked: 2131
Hi, try to correct you Grayscale based only to your Sony's RGB Gain controls.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Reply Display Calibration
