Sony w800b Game Mode - AVS Forum
post #1 of 5 Old 06-24-2014, 07:45 AM - Thread Starter
TAM2215's Avatar
Just purchased the w800b and while i'm impressed with everything else, the gaming mode drastically reduces the picture quality and brightness. I know that's usually the case in gaming modes as it disables all filters to reduce input lag, but it gets so dim that it's almost unplayable in darker areas of games. Been tweaking settings but just can't find that perfect medium. Anyone have the same set and mind sharing their gaming settings? Thanks.
TAM2215 is offline
post #2 of 5 Old 06-24-2014, 08:17 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Liked: 114
Greetings
For which game? Kind of varies by game ...
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 5 Old 06-24-2014, 09:22 AM
22point8's Avatar
Quoted: 13 Post(s)
Have a read of this, this guy is an expert at these sort of gaming related things. http://shmups.system11.org/viewtopic.php?f=6&t=48662
22point8 is offline
post #4 of 5 Old 06-26-2014, 02:04 PM
Starhawk's Avatar
Brightness doesn't really lower unless you are using Impulse with it. (I don't use Impulse on my W800B).
Starhawk is offline
post #5 of 5 Old 06-27-2014, 10:43 PM
ZKACAL's Avatar
Make sure your HDMI black level for the TV matches with your console. Double check that all external processing is off (like dynamic contrast or auto dim stuff). Adjust the actual game's brightness to match with your playing environment (follow the barely visible parameter if they give you one).
ZKACAL is offline
Reply Display Calibration
User Tag List
