CalMAN 5 - RGB Balance / Gamma Issue - Panasonic GT30 / i1Display Pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 06-25-2014, 07:57 PM - Thread Starter
drangel1's Avatar
I'm trying to diagnose an issue I'm seeing in a recent calibration of my Panasonic GT30 with CalMAN 5 Enthusiast. I'm using a two point calibration (30 IRE and 80 IRE), and can get the RGB balance within3 dE, but am experiencing a weird overall RGB curve across 0-100 IRE:
Can anyone help me understand why I'm seeing this behavior? I'm using Custom picture mode, Warm 2, 2.2 Gamma, with all the "extra" picture settings disabled.
The gamma curve drops off substantially at 30 IRE:
Is this an issue with my set, or potentially with my meter (i1Display Pro)?
Any help is greatly appreciated.
drangel1 is offline
post #2 of 17 Old 06-25-2014, 08:36 PM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
This is not at all unusual with two-point grayscale adjustment systems. The effects of adjustments at 30 and at 80 usually overlap, so increasing brightness at both ends will add up together and boost the middle. Because your gamma is at its worst at 80, I'd start by decreasing all 3 colors at 80 percent to cut brightness there (one or two clicks each color, then measure the whole range, repeating until you've reached a balance across the range). You may have to give up a perfect D65 in order to reach dEs of 3 or less across the range and a decent gamma curve.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 17 Old 06-25-2014, 11:02 PM
venkatesh_m's Avatar
Quoted: 33 Post(s)
Liked: 26
What is your pattern source and size of the window? Seems like a case of ABL as the 30 series had a more aggressive ABL that required one to use small windows.
venkatesh_m is online now
post #4 of 17 Old 06-25-2014, 11:47 PM
Chad B's Avatar
Quoted: 493 Post(s)
Liked: 1179
HDMI content type needs to be switched to "graphics" and gamma to 2.4. The GT and ST30s were both that way.
Chad B is online now
post #5 of 17 Old 06-26-2014, 08:09 AM - Thread Starter
drangel1's Avatar
I'm using the AVS HD 709 disc with the CalMAN Windows patterns. Also to note - this set has never had the fluctuating brightness fix.
Thanks Chad - I'll give that a shot.
drangel1 is offline
post #6 of 17 Old 06-26-2014, 08:12 AM - Thread Starter
drangel1's Avatar
Sorry - missed this in the multi-quote. Appreciate the advice. I'll give this a shot as well if I'm still seeing this behavior after implementing Chad's fixes below.
drangel1 is offline
post #7 of 17 Old 06-26-2014, 09:21 AM
randal_r's Avatar
Quoted: 168 Post(s)
Liked: 113
Hi,
I see you got some great advice and it is well worth following up on. I am going to offer an unorthodox approach. If it does work just reset or redo as you would do normally. In the RGB image I see you have it set at "absolute"; that's okay. It is the image of the Gamma Log is what I am interested in. If you do a grayscale and take note of the "Y" values in comparison to the "Target Y" values you will probably see that the "Y" values are much higher then the "Target Y" values. Here is the clincher, some displays track linear while others do not. Edit the grayscale so you can see both of the aforementioned values on the screen and run a grayscale reading. If I am right, you will notice what I had surmised and the "Y" values will be much higher. Adjust the RGB to be equal, then equally adjust all RGB values to bring the "Y" as close to the "Target Y" value for both the 30% and the 80%. This is time consuming but you will find it worth it. If your display tracks linear you will note the values throughout the grayscale will come in line after doing a re-read. If it isn't linear you will notice that the 30% and the 80% appear perfect while all other points appear chaotic. If all works well (if tracking linear), not only will the Gamma Log correct itself but the RGB should level off as well. You can't hurt your display by doing this.
randal_r is offline
post #8 of 17 Old 06-28-2014, 08:01 PM - Thread Starter
drangel1's Avatar
Thanks to everyone for the suggestions. I finally got the chance to re-calibrate tonight with the following results:
I still can't get the Gamma curve up to 2.2 at the high end. I took the suggestion to lower all RGB balance to try to decrease the brightness at the higher IRE, but these results are with the limiting color bottomed out (Red).
My current key settings (I can include all the detail with the W/B highs and lows if helpful):
Picture Mode - User
Color Temp - Warm2
Gamma - 2.4
Content Type - Graphics
Panel Brightness - Mid
Would this constitute a successful calibration? Any additional suggestions are appreciated.
drangel1 is offline
post #9 of 17 Old 06-28-2014, 08:30 PM
randal_r's Avatar
Quoted: 168 Post(s)
Liked: 113
Picture Mode - User
Color Temp - Warm2
Gamma - 2.4
Did you do a comparison of the "Y" value to the Target "Y" in the grayscale? The Gamma chart still exhibits very high values.
randal_r is offline
post #10 of 17 Old 06-28-2014, 08:45 PM - Thread Starter
drangel1's Avatar
I did - full results below. I attempted to balance, then reduce, the RGB values to bring down the Target "Y" but as I mentioned the limiting color bottomed out (R). Unfortunately, to keep RGB in balance G and B are considerably higher than R at 80 IRE.
drangel1 is offline
post #11 of 17 Old 06-28-2014, 09:07 PM
randal_r's Avatar
Quoted: 168 Post(s)
Liked: 113
Don't use "Y fL", use the "Y". Even with the values that you have chosen shows the issues. O% and 100% are always stable and constant. The 100% is the value is set when you adjust the backlight or cell light (THX standard is 35 Ft L). The higher the "Y" over the target value the higher the Gamma and the reverse the lower the Gamma.
A question; is the "warm 2" the closest to D65? Some people choose a setting because they read it somewhere that is was the setting to use. Displays vary and what worked on one display doesn't work on another. Re-test or try "warm 1". I to have experienced this situation and changing the temperature setting helped.
I really don't know how much you know about CalMAN 5 but the datagrid can be edited to reflect the proper "Y" value. Please let me know how it progresses for you. For years I have looked at many reports that have been submitted and in about 97% of them never do they utilize the target values. They are there for a reason. How do you know if your adjustments are correct without a reference target?
randal_r is offline
post #12 of 17 Old 06-28-2014, 09:59 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
randal,
'Y' is a measurement of luminance. It requires a unit of measurement -- either foot-Lambert (ftL) or candela per square meter (cd/m^2). 'Y' without an associated unit is meaningless.
Larry
LarryInRI is offline
post #13 of 17 Old 06-28-2014, 11:29 PM
Quoted: 239 Post(s)
Liked: 352
You are actually closer than you might think. Note that you are only 1 ft/l or so off the luminance (Y) target values from 70 up. This close to 100% White, small differences have a big impact in the gamma plot.
...Royce...
post #14 of 17 Old 06-29-2014, 08:10 AM
randal_r's Avatar
Quoted: 168 Post(s)
Liked: 113
I ran this through Calman for illustration purposes. The first image is my gamma screen without data the second is the gamma screen with simulated data. Note the differences between the "Target Y" and the "Y". The "Y" values are lower the the target values resulting in a higher Gamma (darker image). If the the "Y" values were greater than the target values then the results would be a lower Gamma (brighter image).
The third and forth images are the grayscale screens (without and with simulated data respectively). note the 60% value and how the RGB appears to be fine. Then note the "Y" & "Target Y" values. even though the graph shows an excellent setting for the x & y values the Y value states other wise. As I had stated in a previous posting not utilizing the numeric target values may only be half the job.
To LarryInRI, you are correct. I have submitted the "Y" variables from the Calman properties section in the last image that show where the values for "Y" appear the same. Thank you for your point of view it was a great help.
To drangel1, the issue with the color's bottoming out; I too have experienced this. Re-evaluating the color temperature is worth giving a try. If the "Warm 2" is the best setting, sometimes we have to settle for how the engineers designed the display. My advice is not to give up.
Name:	Gamma (Bare).png
ID:	141082   Click image for larger version
Name:	Gamma (with simulated data).png
ID:	141090   Click image for larger version
Name:	Grayscale (bare).png
ID:	141098   Click image for larger version
Name:	Grayscale (with simulated data).png
ID:	141106   Click image for larger version
Name:	Y variables.png
randal_r is offline
post #15 of 17 Old 06-29-2014, 10:33 AM - Thread Starter
drangel1's Avatar
Thanks randal_r. I'm still getting acclimated to the CalMAN 5 workflows. Is there a specific workflow, whether built-in or custom, that you'd recommend? I don't recall seeing the workflows you're using in the screenshots.
drangel1 is offline
post #16 of 17 Old 06-29-2014, 08:13 PM
randal_r's Avatar
Quoted: 168 Post(s)
Liked: 113
I have a number of workflows that are not standard issue. Some I have designed myself and others that only those who have taken the video calibration courses will have. As for the one that I used for the illustration, is designed for those starting out or better. That one I give away freely while others I can not.
randal_r is offline
post #17 of 17 Old 06-30-2014, 01:35 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
you can get to the options by clicking on the data grid and then the right panel arrow.
If you can find some dead space on datagrid then you can also right-click the chart and select properties from context menu.
We have have 5 types of Y in the product. Y, Y_fL, Y_Lux, Y_fc, and Y_unit.
metric and imperial emissive measurements:
Y is in Candelas per meter squared
Y_fL is in Foot Lamberts
metric and imperial reflective measurements:
Y_Lux is Lux
Y_fc is Foot Candles.
Y_unit is the user selectable unit so that it returns one of the previous 4 types based on user preference.
They are all valid, and as long as you are consistent.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Reply Display Calibration
