Opinions wanted on my calibration - HCRF plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-09-2014, 03:11 AM - Thread Starter
Liked: 0
Hi guys, this is the first time I used the HCFR (just downloaded the latest version). I have read a lot, so I hope got it right.
My TV is a Samsung 60F5300 plasma, and I used a Colormunki Smile probe with the AVS HD 709 mp4 test patterns (I used the APL small Windows patterns to avoid ABL). I used the mp4 files directly from the pendrive on the TV. Is it ok?
I'll post the pictures comparing the before and after. Please tell me if I made it right? Thanks
Color Space before
Corrected:
Luma before:
Luma corrected:
Gamma before:
Gamma corrected:
RGB levels before
RGB levels corrected:
Color temp before:
Color temp corrected:
alfas is offline
post #2 of 8 Old 07-09-2014, 05:28 AM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2526
From what you measured it looks pretty good. I'm not sure if the calibration settings will be the same for the HDMI inputs as the USB port though.
Stereodude is online now
post #3 of 8 Old 07-09-2014, 05:31 AM
Mark Henninger
imagic's Avatar
Quoted: 6600 Post(s)
Liked: 11363
It looks like you've done well.
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #4 of 8 Old 07-09-2014, 09:56 AM - Thread Starter
Liked: 0
If I plug the USB stick on my bluray player, the TV will be fed via HDMI. Would this still be different than a burned disk input?
I did this USB calibration because I often watch movies from the USB port, so I think this must be calibrated also.
As for the disk input, as I can't burn a Bluray disc, is it exactly the same if I burn a DVD, or should I buy a Bluray disk calibration?
alfas is offline
post #5 of 8 Old 07-09-2014, 10:38 AM
Stereodude's Avatar
Liked: 2526
Maybe, maybe not. It depends if the blu-ray player processes the video from the USB port differently from how it handles a disc.
A reasonable course of action if you watch movies from the USB port.
You could use the AVCHD version and burn it to a DVD (assuming you have a DVD burner and your Blu-ray player can play AVCHD discs).
post #6 of 8 Old 07-09-2014, 10:41 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
It's the same disk patterns. No difference .
Unless you want straight perfection and turn this into a hobby I would say your in excellent shape
Holiday121 is offline
post #7 of 8 Old 07-10-2014, 05:21 PM - Thread Starter
Liked: 0
Thanks for the answers. I have just burned a DVD with AVCHD version and calibrated fine. The color parameters looked different - as expected.
Why HCFR changed my gamma reference to 2.4? Sometimes the reference were a curve starting somewhere to 2.1 and slowing increasing to 2.3 (as you can see in the chart on my first post), but now is a straight line at 2.4.
I didn't change anything in the preferences/options to do that. Why did that happened?
Also, my gama now is a straight line at around 2.3. Which gamma option is better to have, and which reference should I trust?
Here's what looks like now with HDMI input:
alfas is offline
post #8 of 8 Old 09-05-2016, 01:20 PM
leonkennedy's Avatar
Quoted: 43 Post(s)
Can't get hcfr to connect to the colormunki smile.
Color Space before
Corrected:
Luma before:
Luma corrected:
Gamma before:
Gamma corrected:
RGB levels before
Color temp before:
How did you get HCFR to recognize the colormunki. I've tried the "end process tree" thing, still no luck. Thanks
leonkennedy is offline
Reply Display Calibration
