Jeti 1211 Meter recertification - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By pepsi
  • 3 Post By Chad B
  • 3 Post By Rayjr
  • 1 Post By pepsi
post #1 of 17 Old 07-11-2014, 02:19 AM - Thread Starter
pepsi's Avatar
I was just wondering if anyone has had their Jeti meter recertified? Is shipping it back to Germany the only way to do this? Also, did you notice any difference in it's performance after certification?
I know the recommendation is to get this meter recertified annually but I'm just wondering if it's worth doing or if you take really good care of your meter and you only use it to profile is it more likely that you can stretch the recalibration period?
pepsi is online now
post #2 of 17 Old 07-11-2014, 09:07 AM
Rolls-Royce's Avatar
Quoted: 232 Post(s)
Liked: 332
SpectraCal can recertify the I1 spectros, but they can't do repairs. I haven't seen anything about them and the Jeti meters, though. There are calibration labs here in the US that can calibrate Minolta and other spectros, perhaps even the Jetis. Some of those labs are/were here in CA. You may want to google spectrophotometer calibration.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 17 Old 07-11-2014, 12:04 PM
Chad B's Avatar
Quoted: 485 Post(s)
Liked: 1161
I had to send my Jeti 1211 back to Germany at a cost of $1100 and I was without it over a month.
I would like it if Spectracal would be able to recal spectros. They can recertify them, basically check if it's within a given tolerance, but if it's off they can't do anything about it.
No, I did not notice a large difference after sending it to Germany. They do send a report of the differences. They also update it to the latest FW.
Yes, it's entirely feasible to stretch the time. Spectros are mainly thrown off by shock/impact, not aging over time.
Chad B is online now
post #4 of 17 Old 07-11-2014, 01:17 PM
ConnecTEDDD's Avatar
Quoted: 1012 Post(s)
Liked: 1479
Hey Chad, early 2015 when I will send my JETI 1211 for re-certification, I will take measurements before sending it to various displays, to help me to check for differencies pre vs. post certification.
There is a lot things that JETI engineers are doing on every JETI 1211 Re-certification, they really know what they do.
As we know JETI is a laboratoty meter that is used for a tons of other applications excluding display calibration.
Here is the list of things they check during each re-certification work that it takes some days:
intake measuring check
mechanical and optical alignment test
firmware and software update
wavelength check and possibly recalibration (low pressure discharge lamps HgA (Screen shot see below)
sensitivity recalibration
Spectral Radiance with OL 455 (Gooch & Housego, traceable to NIST)
Spectral Irradiance with OL 200/ UV 40 (Gooch & Housego, traceable to NIST) → Set up see below
automatic test measurements (3 times on 20 different spectra) to check device stability, device intercomparability and comparability to a reference unit (CS-2000 of Konica Minolta)
issuing of the calibration certificate (example)
As for re-certification pricing for 2014:
675 euros / ~ $920 (JETI 1211-L / 1211 without illuminance recalibration)
1.103 euros / $1.500 (JETI 1211 - both modes are recalibrated / luminance + illuminance)
Above prices don't include VAT, add +21% to above prices more for EU.
PhotoReseach has similar prices, for example for PhotoResearch PR-670, the re-certification costs about 2.000$
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #5 of 17 Old 07-11-2014, 01:36 PM
Liked: 1479
Yes, but we have to wait until CalMAN will finally start using the JETI's latest SDK (3.2.3 that was released @ 28 June 2013!)...each firmware updated JETI with firmware versio 2.0 for specbos 1201 or firmware 3.0 for specbos 1211 can use these SDK's.
Since now CalMAN is using older SDK's earlier from 2013.... maybe this is related to the fact that it's already reported that it takes about the double time to measure the same patch with CalMAN vs. other software solutions.
post #6 of 17 Old 07-14-2014, 10:53 AM - Thread Starter
pepsi's Avatar
Thanks for all the feedback everyone.
Chad,
What shipping solution did you use and how much did you insure it for?
ConnecTEDDD likes this.
pepsi is online now
post #7 of 17 Old 07-15-2014, 09:32 PM
sillysally's Avatar
Quoted: 820 Post(s)
Liked: 839
Ted, you should have np with CM not using the latest SDK for the 1211, as long as you are profiling your K10 using ChromaSurf and LiVal for the WRGB readings on your 1211. As I outlined to you the other day.
Now Chad doesn't have the option that we have, so unless he can manually input the WRGB readings he takes using his copy of LiVal into CM and what ever he uses for his WRGB readings for his D3. He may have a problem.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #8 of 17 Old 07-15-2014, 10:21 PM
turbe's Avatar
Liked: 95
Everyone should be profiling the K-10's with Klein's software / saving in the Klein's memories itself IMO (since the beginning)
NOTE: Not all the 3rd Party Applications will utilize the Klein's memories..
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #9 of 17 Old 07-16-2014, 08:47 AM
Chad B's Avatar
Quoted: 485 Post(s)
Liked: 1161
Chad,
I bought the meter from Tom Huffman/ChromaPure, and I decided to go through him instead of dealing with Jeti myself. So I sent it to him, and he sent it off to Germany for me. I'm pretty sure FedEx was used.
post #10 of 17 Old 07-16-2014, 08:54 AM
Chad B's Avatar
Quoted: 485 Post(s)
Liked: 1161
ss
Don't be silly. It shouldn't be a problem. It's not like all of a sudden I will get inaccurate readings from the Jeti with CalMAN, though of course I'd prefer to have the speediest and most efficient readings and that's why I'm looking forward to see CM support the latest SDK.
post #11 of 17 Old 07-16-2014, 11:45 AM
sillysally's Avatar
Quoted: 820 Post(s)
Liked: 839
You misunderstand, I could care less about CM having the latest Jeti SDK. It's Ted that thinks it's a problem.
As I said I use my K10-A/CromaSurf to store and analyze my meter profiles from both the K10 and the Jeti. I use Jeti's LiVal software to take the readings of the 1211, because it does have the latest SDK. Then I manually enter the readout from LiVal xyY, XYZ and RGB readings into ChomaSurf, then CS analyzes the reading from both meter's and tells me how close the meter profile really is.
As you know the Jeti 1211 can be a bit touche when used on a TV like the VT60. So when used to profile any color meter and software like CM (Using outdated SDK, per Ted) you just have to cross your fingers and hope the meter profile comes out well. In my case I want to know how well my meter profiles come out before I calibrate.
btw, from what turbe posted you brought your 1211 used, is this the first time you sent it back to Jeti.? If so how long have you owned it.?
ss
post #12 of 17 Old 07-16-2014, 01:18 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
wow, that is a chunk of change to spend yearly
CalWldLif is offline
post #13 of 17 Old 07-16-2014, 06:02 PM
<^..^>Smokey Joe's Avatar
Quoted: 61 Post(s)
Liked: 91
If the unit is cared for, as many do, and relatively low use, ie just for profiling. Then it is likely not drift out of spec over a number of years. It really depends on use, care and if the NIST is required.
For broadcast arena, yearly is more or less required, for home AV I believe you can easily stretch this out to 2~3 years without worry.
I spoke with jeti about this specifically, although ultimately yearly checks are recommended they have found they are typically still within spec upon the yearly checks. Conclude what you need from that.
PS They recommended that a reference light source could be used to locally check stability.
Masterpiece Calibration Ltd
Christchurch NZ
<^..^>Smokey Joe is offline
post #14 of 17 Old 07-16-2014, 07:03 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
See this thread for some discussion of this idea.
spacediver is offline
post #15 of 17 Old 07-08-2015, 09:43 PM
Chad B's Avatar
Quoted: 485 Post(s)
Liked: 1161
Jeti and Orb Optronix spectros are similar designs, and Orb is based out of Washington state. I called Orb and asked if they could recal a Jeti 1211, and they said they could, but they'd have to reflash it with their software, essentially making it look like an Orb SP-200 to the computer. It also meant that they would need to charge not only for the recal, but also their version of the software, which would be very expensive.
They suggested contacting Sapphire Technical Solutions out of North Carolina, who they had some dealings with and who had a higher level certification lab. Turns out their lab certification is even higher than Jeti's.
Sapphire just completed the service on my Jeti 1211, and so far the turnaround time is impressive compared to sending it back to Europe. The cost is still around a grand, though. Ron, the Lab Manager, has been good to deal with.
I should have my Jeti back within a few days.
ddingle, Kris Deering and pepsi like this.
post #16 of 17 Old 07-09-2015, 09:06 AM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Nice to see there are certification options for US Jeti owners..other then sending it back to Germany.
It was this dilemma that got me looking at Colorimetry Research, as they are US based..Southern California to be exact.
Plus there recert fees are way reasonable.
Just my $.02
RayJr
Kris Deering, Chad B and pepsi like this.
Rayjr is offline
post #17 of 17 Old 09-27-2016, 12:06 AM - Thread Starter
pepsi's Avatar
Thanks for sharing the info about Sapphire Technical Solutions Chad! I feel much better knowing there is a US option available.
Chad B likes this.
pepsi is online now
Reply Display Calibration
certification , jeti , nist
