Upgrade from HCFR to Calman basic or Chromapure standard? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-16-2014, 02:05 PM - Thread Starter
flargosa's Avatar
I want to upgrade from HCFR to something within my $200 budget. Looking at both they each seem to have the functionality I need. Only issue I have with Chromapure standard is cost per additional meter if ever I needed to upgrade mine. I have the i1Display Pro, which I believe works with both.
Which one do you guys think is a better tool? Something one can continue to learn from and grow into? From what I have read either one seems good enough, so I'm a little confuse.
flargosa is offline
post #2 of 7 Old 07-20-2014, 11:45 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
I'd recommend Calman. I started with Basic and now use Advanced. If you aren't new to calibration, just go with Calman Advanced.
ZKACAL is offline
post #3 of 7 Old 07-21-2014, 08:11 AM
SiGGy's Avatar
Quoted: 381 Post(s)
Liked: 332
What is it that's missing in HCFR that you are seeking in Calman/Chromapure?
-SiGGy
SiGGy is offline
post #4 of 7 Old 07-21-2014, 08:53 AM
Quoted: 1701 Post(s)
Liked: 731
Don't you have to spend more than the $200 with Calman and Chromapure to get the functionality needed to do a calibration?
JimP is offline
post #5 of 7 Old 07-21-2014, 06:24 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2438
ChromaPure!!!
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #6 of 7 Old 07-23-2014, 07:39 AM - Thread Starter
flargosa's Avatar
Thanks for the suggestions. I got the Chromapure and have successfully calibrated with it. It's much better put together than HCFR and was worth the upgrade. Not sure if Calman is a better choice. So far happy with Chromapure, in terms of navigation and simplicity in design.
flargosa is offline
post #7 of 7 Old 07-23-2014, 01:26 PM
ConnecTEDDD's Avatar
Quoted: 1671 Post(s)
Liked: 2082
Hi, here you can find the latest and detailed ChromaPure's Manual: http://www.chromapure.com/support.asp
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Reply Display Calibration
