DIY Calibration of a new HDTV - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By J_E_F_F
post #1 of 13 Old 07-17-2014, 03:59 PM - Thread Starter
J_E_F_F's Avatar
I have 10 year old 720p max, no HDMI input TVs; I am planning to replace them later this year, and get with the 1080p HDTV times.
I do not have a DVD or Blu-Ray player, though I stream HD content from a local server or from the net.
I'd like to calibrate my new TVs, I am not a videophile but I'd like things to look nice.
Would I be better off buying a Blu-Ray player and a Disney WOW disk, that I'd use only for that, and then disconnect them and put them in the closet for ever, or would I be better off buying a X-Rite CMUNDIS ColorMunki Display. Cost for the two setups would be similar.
Assuming the results for the ColorMunki would be the same or better, I'd feel better buying that over the Blu-Ray equipment.
Do the two options offer similar types of final visual calibration for the home user?
Remember, this is for HDTV viewing, not a computer monitor.
J_E_F_F is offline
post #2 of 13 Old 07-17-2014, 06:01 PM
Liked: 0
Why would you not USE the blu ray player if you bought it? How are you currently streaming content? Many blu ray players will allow you to stream content from other devices in the home.
If you must, I would see if you might be able to borrow a blu ray player from someone before paying for one. Although you could always return it to the store lol. As far as cal. discs go, I've never tried the disney WOW disc or the Colormunki but have always heard good things. I personally own a Spears & Munsil disc and that worked just fine for me.
ten80pee is offline
post #3 of 13 Old 07-17-2014, 06:40 PM - Thread Starter
J_E_F_F's Avatar
I'm not into disks, I ripped all my CDs to MP3 11 years ago, and my DVDs to MP4,etc. I use WD Live media players to stream audio and video around the house from the local file server or from the internet. i don't see myself renting or buying blu-ray disks,... ever. I did talk to a buddy about borrowing a blu-ray player, and that is an option. If the Colormunki does the same type of calibrations without relying on my old eyes, that may be the best route for me. I'm just not sure if it does things like sharpness, etc. I like computer gadgets and I could use it for all 4 TVs and we have several laptops that I could calibrate. I just want to be sure it does TVs correctly as that is my main concern.
J_E_F_F is offline
post #4 of 13 Old 07-18-2014, 05:38 AM
chunon's Avatar
Quoted: 1562 Post(s)
Liked: 1440
You would need a pattern source and software for the ColorMunki, so would most likely need a bluray player anyway.
65C6 OLED
55EG9100
Time Warner Cable/Oppo 103d/ Sony XT1 Soundbase/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
My JS9500 Calibration review(CHADB)http://www.avsforum.com/forum/166-lc...l#post36534866
chunon is online now
post #5 of 13 Old 07-18-2014, 03:19 PM
fastman's Avatar
I have and have used WOW, it's a good start and better then nothing. I just got an X-Rite Display 3 PRO Colorimeter, it's a higher end maybe from the ColorMunki but the same method in calibration as far as I know. Haven't used it yet but it's much more involved in its use. I also use the BR player to stream from my NAS which works great. I tried streaming from the Roku 3 I have but with poor results for some reason.
fastman is offline
post #6 of 13 Old 07-21-2014, 12:33 AM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 24
Since you don't want to own any disks or blu-ray, just borrow your friend's blu-ray and buy one calibration disk. Simple as that. Otherwise, buy a meter and install software on a laptop and a pattern generator (like a blu-ray player) and do a full on calibration.
ZKACAL is offline
post #7 of 13 Old 07-21-2014, 09:22 AM
sillysally's Avatar
Quoted: 805 Post(s)
Liked: 828
You don't need to buy a DVD/Blu Ray player or a WOW/calibration disc.
All you would need is a D3 meter, HCFR calibration software.
You can use your PC to generate the color patches on your TV, if your PC has a HDMI output.
HCFR software is Free, I think it uses madVR and also Argyll's matrix for the D3 meter.
So the only cost to you is the D3 meter.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #8 of 13 Old 07-21-2014, 10:56 AM
LastButNotLeast's Avatar
Quoted: 1361 Post(s)
Liked: 958
Old version of "The Guide", which has a good intro and better (IMO) explanations and deals with HCFR:
http://www.curtpalme.com/forum/viewtopic.php?t=10457
New version, which, understandably, plugs ChromaPure more:
http://www.curtpalme.com/forum/viewtopic.php?t=35322
HCFR thread:
HCFR - Open source projector and display calibration software
Calibration disc:
AVS HD 709 - Blu-ray & MP4 Calibration
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #9 of 13 Old 07-21-2014, 05:56 PM - Thread Starter
J_E_F_F's Avatar
My original thoughts were to buy a calibration disk, and borrow a blu-ray player for it.
It seems that the cal disk and the meter do different things. It seems the meter is more for colors and the disks are for everything else. Is that accurate?
J_E_F_F is offline
post #10 of 13 Old 07-21-2014, 06:15 PM
Liked: 958
No. With a disc you can set brightness and contrast, color and tint (with a blue filter or blue-only setting on your set) and sharpness.
You need a meter for color, yes, but also for white balance and gamma. The source images that the meter is measuring are on the disc, of course.
The "Guides" explain it pretty well.
The AVS disc is available as mp4 files, but a BDP would be more convenient.
post #11 of 13 Old 07-23-2014, 03:59 PM - Thread Starter
J_E_F_F's Avatar
great, thank you
J_E_F_F is offline
post #12 of 13 Old 07-23-2014, 04:27 PM
ConnecTEDDD's Avatar
Quoted: 771 Post(s)
Liked: 1233
Hi, if you like you can see at this post what you can/can't do with a calibration disk.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #13 of 13 Old 07-24-2014, 06:00 PM - Thread Starter
J_E_F_F's Avatar
very informative, thank you
ConnecTEDDD likes this.
J_E_F_F is offline
Reply Display Calibration
