How does my post calibration chart look? - AVS Forum | Home Theater Discussions And Reviews
Old 07-18-2014, 04:10 PM - Thread Starter
flargosa's Avatar
Is there anything I can do to fix the gamma bump between the 80% and 100%? I do not have gamma controls. What else should I be be tweaking?
meter: i1Display Pro
Software: Chromapure
ID:	168601   Click image for larger version
flargosa is offline
Old 07-18-2014, 06:21 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Your contrast setting is likely too high.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
Old 07-23-2014, 08:48 AM - Thread Starter
flargosa's Avatar
Originally Posted by Michael TLV View Post
Greetings
regards
Thanks for the suggestion. I turned down my contrast a few clicks and compensated with an increase in backlight. The gamma now tracks as it should. I'm surprise the color readings drifted more than i thought. I had to tweak most of the color adjustments again to get back to correct color readings.
flargosa is offline
Old 08-01-2014, 11:18 AM
jdoostil's Avatar
Greetings
regards
This. On my personal TV, the gamma doesn't level out unless the contrast is at 78 (or below...the control goes to 100) even though the contrast pattern looks correct through the 80s. Clipping/colorshifts start in the early 90s
jdoostil is offline
