Sony TRILUMINOS technology - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By nuke
post #1 of 11 Old 07-19-2014, 01:19 AM - Thread Starter
Brian Hampton's Avatar
Quoted: 584 Post(s)
Liked: 312
Hi,
Does this TRILUMINOS technology have any value?... Am I right in thinking I should double check to make sure my current stuff doesn't have it and if it does have it I ought to try to dis-able it.
-Brian
Brian Hampton is offline
post #2 of 11 Old 07-19-2014, 05:50 AM
chunon's Avatar
Quoted: 2466 Post(s)
Liked: 2208
If your post is serious ?
It can't be disabled, it is a special coating used in the manufacturing process. I have seen positive reviews regarding the Sony sets that have it.
65C6 OLED/65 A1E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 11 Old 07-19-2014, 05:58 AM - Thread Starter
Quoted: 584 Post(s)
Liked: 312
Oh I thought it was a alternative color space.... Thanks.
Some blu ray players offer it as a "feature" so it's not simply part of display manufacture.
post #4 of 11 Old 07-19-2014, 06:19 AM
chunon's Avatar
Liked: 2208
No problem
post #5 of 11 Old 07-19-2014, 08:23 AM
HDTVChallenged's Avatar
Liked: 215
Supposedly, it makes it possible to display a much *wider* color space than REC709/SMPTE-C ... approaching REC2020. The question remains as to whether that native colorspace can be pulled back in to REC709, without resorting to LUT boxes.
HDTVChallenged is offline
post #6 of 11 Old 07-20-2014, 08:25 AM
8mile13's Avatar
Quoted: 1726 Post(s)
Liked: 1008
Are you shure about that? Triluminos Display
Seems that the 2013 Sony Triluminos ''is a new backlighting method'' ''which includes Color IQ''
http://www.cnet.com/news/what-are-qu...-your-next-tv/
So in 2013 Sony Triluminos included the use of Color IQ (Quantum Dots). In 2014 however Sony stopped using Color IQ and replaced it by white LEDs while still using the name Triluminos, and still claiming that ''a Triluminos display is using more colors to produce a more vibrant picture.''
http://store.sony.com/84.6-diag-x950...id-Sony-HD-TVs
8mile13 is offline
post #7 of 11 Old 07-20-2014, 08:39 AM
chunon's Avatar
Liked: 2208
So you are saying that can be turned on and off ? Even if you could why would you want to ?
post #8 of 11 Old 07-20-2014, 08:48 AM
8mile13's Avatar
Liked: 1008
No, my respons was not about wether or not Triluminos could be turned on or off. My respons is about your claim that Triluminos is ''a special coating''.
8mile13 is offline
post #9 of 11 Old 07-20-2014, 09:05 AM
chunon's Avatar
Liked: 2208
Okay I stand corrected
post #10 of 11 Old 08-02-2014, 03:55 PM
nuke's Avatar
Quoted: 244 Post(s)
Liked: 140
The Tri-Luninous thing is just a Sony trademark buzzword. It applied on the 2013 4k sets which used "Color IQ Quantum Dots". For 2014, it applies to the white LED backlight system. It
It is a little technical what that means exactly. LED's produce light at a single wavelength. To get white light, you need red, green and blue. The way white LED's work is they produce light at a blue wavelength at the semiconductor P/N junction. On top of the semiconductor is a layer of phosphor that absorbs some of the blue and emits red and green light wavelengths.
A phosphor is a chemical substance and it produces light at somewhat diffuse wavelengths. It is also hard to get the right wavelengths of red for use in display technology. It is the chemistry that determines the color of light it produces.
The Color IQ Quantum Dot is a lot like a phosphor, but it operates on a different principle than the molecular phosphor. The Quantum dots are tiny particles (nano particles) of cadmium with another material such as zinc sulphide or cadmium selenide coating it, like a candy shell on an M&M. It works a lot like a semiconductor in that the junction between the two layers is what makes it work. The Quantum Dots are manufactured to produce light at precise wavelengths. Chemically, the red and green dots are the same, but the way they are manufactured determines color it produces when blue light strikes it. The emitted wavelengths are also very narrow in spectra, which means the light is more precisely centered on the wavelengths of red, green and blue needed for backlighting the LCD display.
If you took the panel apart, you'd find an array of blue LED's along the side, with a yellow looking glass strip in between the LED's and the plastic light spreader that is behind the LCD itself. The yellow looking glass is what has the Quantum Dots in it and is the origin of the "Triluminous display."
Since "Triluminous" is Sony's own trademark, they can apply to anything they please. For 2014, Sony believes they have white LED's that are worthy of the trademark.
nuke
nuke is offline
post #11 of 11 Old 08-04-2014, 07:14 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
nice info
Loving D65
CalWldLif is offline
Reply Display Calibration
