Calibration question - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Michael TLV
  • 1 Post By sotti
post #1 of 8 Old 07-20-2014, 01:32 AM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 107
Will 4k or UHD content make video/display calibration simpler?
What specific considerations does higher pixel count add into the mix?
brwsaw is offline
post #2 of 8 Old 07-20-2014, 05:17 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 141
Greetings
Pretty much nothing at all. A gray box is a gray box is a gray box.
People just have to be seated way closer to the TV than before to benefit from the extra pixels. (This really messes up the audio experience part of the equation of course.)
Regards
GeorgeAB likes this.
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 8 Old 07-20-2014, 09:25 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 198 Post(s)
Liked: 63
It will make a difference when adjusting sharpness. 4K will allow more detail and the ability to see smaller line detail on a test pattern. Sharpness adds noise to the edges of the lines and noticeable when viewing text. More sharpness may cause you to lose detail.
kjfalls is offline
post #4 of 8 Old 07-20-2014, 10:00 AM
Quoted: 40 Post(s)
Liked: 141
Greetings
Even for sharpness ... at typical viewing distances ... it makes no difference at all. Only if you decide to sit at 1.8 x picture height or closer to the TV does it matter. And most people are never that close.
I haven't seen anyone that will move closer to their TV because it is UHD. Certainly not anyone that cares about their audio.
regards
post #5 of 8 Old 07-31-2014, 11:25 AM
curlyjive's Avatar
Quoted: 250 Post(s)
Liked: 123
Originally Posted by Michael TLV View Post
Greetings
regards
I'm going to get all near field monitors and sit with my nose touching the screen
If the finalized UHD spec. incorporates a wider color gamut and HDR, will that affect calibration at a fundamental level a all? Other than needing software that understands the new colorspace and patterns for it, the process should be the same. For HDR, I wouldn't think so either.
curlyjive is offline
post #6 of 8 Old 07-31-2014, 01:04 PM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 107
Greetings
regards
We already sit close, true UHD or 4k is most welcome. Thankfully its a ways away yet.
Proud owner of an Axiom Audio home theatre, powered by Axiom Audio.
brwsaw is offline
post #7 of 8 Old 07-31-2014, 04:47 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 328
Rec.2020 doesn't include anything for HDR. HDR is coming from Dolby and so far hasn't been standardized by SMPTE or IBU, to my knowledge.
Also the Rec.2020 spec is a pipedream for color reproduction and in general simply a bad spec that appears to be marketing driven with little sound color science behind it. It doesn't even specify a EOTF (gamma function). Hopefully it'll never truly go into use.
randal_r likes this.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #8 of 8 Old 08-01-2014, 09:43 AM
curlyjive's Avatar
Quoted: 250 Post(s)
Liked: 123
The more I read about the pending UHD specification and the phased in way it will be implemented, the more I feel good about upgrading to a JVC RS4910 now. I want more than just a resolution increase, and the full implantation of a UHD spec seems a ways out....not to mention the content.
Reply Display Calibration
