Calibrating TV For PC Games? - AVS Forum
post #1 of 7 Old 07-25-2014, 10:42 AM - Thread Starter
Tall-Guy's Avatar
Hi,
My Computer is connected to my LCD 50" screen. I was doing some research on how to Calibrated the LCD to PC Video-Games,. Most of the people suggested to make sure my ATI Driver outputs 0-255 (I can set my LG TV to output "Full RGB"). I used AVSHD for calibration, but no matter which Player I'm using (Media Player Classic, VLC), the brightness and contrast are clipping. I was able to "Solve it" by installing upsilon mixer.
Problem is that I'm pretty sure Upsilon mixer does not work when I play video games. I'm also not completely sure if AVSHD is the right tool to calibrate Video Games. Is DirectX games uses the same brightness contrast settings of a Video File?
Tall-Guy is offline
post #2 of 7 Old 07-25-2014, 11:41 AM
alluringreality's Avatar
Liked: 33
Video and the desktop are somewhat disconnected on a computer. Many computers will scale the video to the desktop in a way that might work, but it's also possible that the video may not match the desktop values. Using a video calibration tool isn't necessarily ideal for what you're trying to do. I'm not familiar enough with calibrating the computer desktop to really comment further.
alluringreality is offline
post #3 of 7 Old 07-25-2014, 12:12 PM
-Hitman-'s Avatar
Quoted: 32 Post(s)
Liked: 56
It should work if you have the output to display set at Full 0-255 (which looks like you've done this part) and also under advanced video color - enable and set dynamic range to 0-255 also.
Then WMP or Powerdvd etc.. video players should output video playback as 0-255.
Edit: Looking at the video players you've mentioned, they can be configured internally, so If you need to use them you will also need to make sure they're configured correctly too and output 0-255 (default will be 16-235).
-Hitman- is offline
post #4 of 7 Old 07-25-2014, 03:02 PM - Thread Starter
Tall-Guy's Avatar
Thanks for the comments guys.
Is there any "Desktop" calibration tool? are DirectX games using "Desktop" calibration? or they have different set of settings?
When you say advanced Video Color you mean on the Computer ATI settings?
Tall-Guy is offline
post #5 of 7 Old 07-25-2014, 06:48 PM
sawfish's Avatar
Liked: 102
Hi,
Using PC Levels means video has to be expanded from Video Levels (16-235) to PC Levels (0-255). Thus, in your AVS Black Clipping pattern, Bars 16 and below contain RGB 0, Bar 17 contains RGB 1, and so forth, though scaling is obviously necessary to pack 0-255 into the 220 bars in the video range. You will never see bars < 17 or > 235 when using PC Levels, because the former all contain RGB 0, while the latter all contain RGB 255. OTOH, when using Video Levels, the bars contain the the RGB values they are labeled with, and then it's possible to see BTB and WTW.
As for games, they use PC Levels. If you don't have a meter and software, I think the best way to adjust your TV for PC Levels is with images designed for that. I often see people link to:
http://www.lagom.nl/lcd-test/
sawfish is online now
post #6 of 7 Old 07-26-2014, 01:03 AM
-Hitman-'s Avatar
Quoted: 32 Post(s)
Liked: 56
You can use any calibration software for your desktop.
Yes it's in the ATI CCC under - Video\Advanced Video Color.
-Hitman- is offline
post #7 of 7 Old 07-26-2014, 06:17 AM - Thread Starter
Tall-Guy's Avatar
I actually used Windows 7 Calibration agent. And the results are not bad. But I'll check the site your provided.
Thanks for the help guys!
Tall-Guy is offline
Reply Display Calibration
User Tag List
