Colorimetry Research - New Probes for Display Calibration - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 164Likes
post #481 of 496 Old 12-29-2016, 03:59 AM
Hello, World!
Mark_H's Avatar
Quoted: 300 Post(s)
Liked: 210
Jumping over from the LG OLED thread where we just talked about the CR250-RH firmware upgrades...
So, I've not upgraded my firmware since purchase, and I'm not having any problems with my calibrations, that I'm aware of...
Have there been any critical updates since launch where perhaps I DO need to consider a firmware upgrade??
I'm currently only calibrating LCD, OLED TVs and SXRD projector, but have a JVC Z1 laser incoming in a couple of weeks.
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #482 of 496 Old 12-29-2016, 11:04 AM
Rayjr's Avatar
Quoted: 188 Post(s)
Liked: 225
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
The Firmware upgrade just adds a few new features...should not affect the way the meter reads.
RayJr
Rayjr is offline
post #483 of 496 Old 12-29-2016, 11:19 AM
Hello, World!
Mark_H's Avatar
Quoted: 300 Post(s)
Liked: 210
RayJr
Thanks. In that case I'll hold off.
Mark_H is offline
post #484 of 496 Old 12-29-2016, 11:27 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2136
Hi Mark. CR250RH at earlier firmware, they added new improved sync mode, so this affects readings in a good way, faster, more stable etc.
There also firmware update at past for CR-100 which improved a lot (sync) and also the near black measurement performance significantly.
There meter updates where any user can perform (this is why they make them available for download to public), but there some times where the meter or hardware has to come back to the factory, to install the newer firmware (which will require meter re-certification also).
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #485 of 496 Old 12-29-2016, 11:57 PM
Hello, World!
Mark_H's Avatar
Quoted: 300 Post(s)
Liked: 210
Do any of the public firmwares, eg the current one, need any of the factory ones first? Or are they completely different types of update? In other words, could I go ahead and do the update to the current firmware without worrying about the factory-only stuff...?
Mark_H is offline
post #486 of 496 Old 12-30-2016, 12:17 AM - Thread Starter
Liked: 2136
Hi Mark, you can update your meters with the firmware available online, no problem
post #487 of 496 Old 01-18-2017, 04:42 AM
Quoted: 1704 Post(s)
Liked: 731
I understand how you load optional color matching functions such as the judd vos into the utility program but how do you tell the CRI app whether to use one or not?
I tried loading it into the utility app and assumed that the CR250 would just use it until it's removed but my x,y,Y results in CRI App are the same with or without it in the utility. I also unplugged the spectro after making changes for the changes to take from what I underststand in the manual.
I'm using a 65B6P and for all I know, the reading might be the same both ways. I don't know but based on a statement about Judd Vos adding about 10% blue, that appears to be more neutral to the eye.
JimP is offline
post #488 of 496 Old 02-07-2017, 05:50 AM - Thread Starter
Liked: 2136
Colorimetry Research CRI Installer Version 1.4.4 for Windows 32-bit / OS X 64 bit (28 November 2016) Released.
The installer packages include CRI App, Colorimeter Utility, Software manual, Remote communication manual, USB Driver.
Release Notes
New RGB Balance Interface
Added import option to merge multiple measurements into one workspace for data/chart analysis
Added option to create a color profile using a wizard
Added support for SyncModes PAL, NTSC and CINEMA in the CR-250
Updated the date(Day, Month) and time(Hours, Mins, Seconds) fields to have two digit formatting
Download Link
alex_t likes this.
post #489 of 496 Old 05-24-2017, 12:24 AM - Thread Starter
Liked: 2136
Colorimetry Research CRI Installer Version 1.4.5 for Windows 32/64-bit / OS X 64 bit (03 April 2017) Released.
Release Notes
Added calculation of reflectance with a reference illuminant in the Reflectance Mode
Add/Copy Color profile allows changing of units
Fixed a bug in the RGB Balance when matching target Luminance.
Tweaked the RGB Balance interface to be a little more user friendly.
Resolved the issue where the CRIApp exceeded the screen height.
Flicker measurements are reported in calibrated units whenever available.
Download Link
alex_t likes this.
post #490 of 496 Old 05-24-2017, 11:07 AM
Rayjr's Avatar
Quoted: 188 Post(s)
Liked: 225
New CR-250 firmware released . Version 1.34
Sent from my SM-N910V using Tapatalk
alex_t likes this.
Rayjr is offline
post #491 of 496 Old 05-24-2017, 11:17 AM - Thread Starter
Liked: 2136
Cool
Colorimetry Research CR-250, CR-250-RH, CR-250-FP, CR-250-IR Spectroradiometers 1.34 Firmware Update Released
Release Notes
Added support for Sync Modes NTSC, PAL and CINEMA.
Fixed an issue that caused incorrect reporting of the error "Variable light level" when speed setting was Fast or 2x Fast.
Minor improvements and optimizations.
Download Link
post #492 of 496 Old 05-26-2017, 10:57 PM
Liked: 731
On the CR250RH, synch modes of PAL, NTSC and CINEMA have been added to None and Manual with this latest firmware update.
So if you're using this on a North American display using a OLED panel that's 120hz, do you use NTSC which I'm guessing is 60hz or use manual and adjust the frequency to 120hz?
Edit: I think I may have answered my own question. NTSC is the old analog standard that was discontinued, so it would seem that I'd use manual and 120hz? or am I missing something here???????
JimP is offline
post #493 of 496 Old 05-27-2017, 08:00 AM
Rayjr's Avatar
Quoted: 188 Post(s)
Liked: 225
Hello Jim
Ok...here is the way I understand the new setting.
PAL is 50Hz or multiples of that frequency
NTSC is 60Hz or multiples of that frequency
CINEMA is 24Hz or multiples of that frequency
so NTSC would work because 120Hz is a multiple of 60Hz
Hope that helps.
Later
RayJr
JimP, imagic and alex_t like this.
Rayjr is offline
post #494 of 496 Old 07-08-2017, 02:02 PM
Liked: 731
Ray....
Can you review how the Color Matching Function works in the utility program. I know we talked about it but for the life of me I don't remember what you said. Sorry. ...and I now see a CIE 2006 as a downloadable CMF.
JimP is offline
post #495 of 496 Old 09-24-2017, 05:56 PM
Pres2play's Avatar
Quoted: 679 Post(s)
Liked: 327
Checking the CR specs, the spectral bandwidth for the CR250RH is now 4 nm. Used to be 5. Is this for a new CR250 probe?
Pres2play is online now
post #496 of 496 Old 09-24-2017, 06:37 PM
Rayjr's Avatar
Quoted: 188 Post(s)
Liked: 225
I think about 2 years ago they did a Diffraction grating upgrade that gave the unit 4nm Spectral Bandwidth .. sort of a running change from what I was told.
hope this helps
RayJr
Rayjr is offline
Reply Display Calibration
