Colorimetry Research - New Probes for Display Calibration - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 164Likes
Old 02-06-2015, 11:24 PM
Rayjr's Avatar
Quoted: 181 Post(s)
Liked: 221
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Originally Posted by Pres2play View Post
I'm not familiar with Calman, do you know if this bundle also includes license for i1Pro2? I have CP, but this looks like a good time to jump in and Calman for free.
Here is the Matrix for what the software supports.
But I would contact SpectraCal just to be sure.
Hope this helps.
RayJr
Rayjr is offline
Old 02-06-2015, 11:55 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Thanks. I'll give'em a call.
Pres2play is offline
Old 02-07-2015, 04:30 AM
Quoted: 1531 Post(s)
Liked: 631
How accurate are the plasma correction tables for the CR100?
Would you still need to profile off of a spectro?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
Old 02-07-2015, 04:44 AM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
Jim, u always need to (for best accuracy), that will never change - for any display technology (not just Plasma) as these tables are not done on your particular display...
what can "help" (if u don't have a good spectro) is, if the Plasma tables were done on the same brand as ur TV, e.g. Panasonic VT series... contact CRI and ask them which TV brand they used to create the tables...
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
Old 02-07-2015, 04:58 AM
Liked: 631
- M
I know that's the prevailing though on profiling but I've found that a profile off of a jeti 1211 performed off of my Samsung F8500 worked very well on my Panasonic VT50. Maybe its pure luck.
But you're very right. I'll check with them if they don't respond to these post.
JimP is offline
Old 02-07-2015, 05:00 AM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
how would u know that F8500 profile "worked very well" on ur VT50 unless u directly compared it to a real VT50 profile done with the same Jeti 1211 on the same display (VT50) ?
Old 02-07-2015, 05:24 AM
Liked: 631
Good skin tones including gradation of tones without obviously skewed colors in other areas. (full disclosure...I use to be a pro photographer with studio and in house lab....so what's obvious to me might not be that obvious to someone else)
May not be scientific enough for some but ultimately it is about how the picture looks.
JimP is offline
Old 02-07-2015, 03:18 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
... that is all true IF (!) you would know how the colorist graded the footage... they don't all grade skin tones alike
Old 02-08-2015, 01:08 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Okay, heard good things about the CR-100 and placed my order, but what's the story with the CR-250 spectrometer? Is it ready for prime time? I see there's also a CR-250RH that can be ordered with a different spot size...confusing!! I'll be using with Chromapure.
CR-250RH Spot Size Calculation
50mm lens: 20+(0.026 x distance in mm)
60mm lens: 24+(0.02166 x distance in mm)
75mm lens: 30+(0.01733 x distance in mm)
100mm lens: 40+(0.013 x distance in mm)
Old 02-08-2015, 02:09 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
^^^I should mention, I have no projectors. The meters are for my Samsung 55" OLED display, so I'd like know what you guys think the right spot-size should be. I've been using my i1Pro2 in contact mode, so I'm assuming the same for the CR-250.
Old 02-08-2015, 02:26 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
standard 50mm lens is fine... the CRI probes main market is scientific application so they have lots of (optional) features that you may not need for display calibration... in a perfect world you would try to match the spot size of your colorimeter...
there won't be "direct contact" with the CR-250RH as the rubber hood in front of the meter prevents that...
Old 02-08-2015, 03:47 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Sorry to be blunt, but is the CR-250 in Klein K10-A territory in terms of performance. Will it out perform the i1Pro2? I'd appreciate some feedback from the few owners out there. I need to make a decision by tonight.
Old 02-08-2015, 03:51 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
CR-250 is a spectro not a colorimeter, so no sense comparing it to the K10. CR-250 outperforms the i1Pro.
Old 02-08-2015, 03:58 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Oops, meant JETI 2011.
Old 02-08-2015, 04:59 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
the only way to know is to compare both the CR-250 and the Jeti to a superior reference source in terms of accuracy - repeatability is another (very important) characteristic...
FSI has run all of these tests in detail and they were very, very pleased with the CR-250...
Old 02-08-2015, 05:41 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Thanks IronMike, I'll look at their return policy and make a decision.
Old 02-09-2015, 10:15 AM
Liked: 631
- M
Just a heads up for anyone interested in the CR-100 colorimeter and its plasma tables. Per Colorimetry Research, the plasma table is based off of a Panasonic VT-60.
Hey Mike. That was a good idea about contacting them.
JimP is offline
Old 02-10-2015, 11:13 AM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Originally Posted by Rayjr View Post
Just made a video to give you an idea of the meters speed.....very K-10 like.
CR-100 Test
Later
RayJr
It's in contact here, correct?
Old 02-10-2015, 11:31 AM
Rayjr's Avatar
Quoted: 181 Post(s)
Liked: 221
Yes it is.
RayJr
Rayjr is offline
Old 02-10-2015, 12:22 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Okay, thanks.
I hope to meet with David Mackenzie or Kevin Miller at Value Electronics to see what they think of these reference devices when they arrive.
Old 02-10-2015, 07:09 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
I can do 125 point calibration with my Mini3 and i1D3, but now with this faster meter, I want to try a 17^3 LUT. How can I do this without having to buy a new Lumagen?
Old 02-10-2015, 07:13 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
I can do 125 point calibration with my Mini3, but now with this faster meter, I want to try a 17^3 LUT. How can I do this without having to buy a new Lumagen?
eeColor - and u would then do a 65^3 LUT... ;-)
Old 02-10-2015, 07:18 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Doable with ChromaPure?
Wait, 65^3???
Old 02-10-2015, 07:24 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
Wait, 65^3???
welcome to 2012 !
65^3 in home theater... and much cheaper than Lumagen, but the eeColor is NOT a VP, it is a straight LUT box...
not sure if CP supports the eeColor format...
- M
Old 02-10-2015, 07:35 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Well, I've known about the eeColor box, but I never gave it much thought. Found 5 cube LUT too lengthty with i1D3.
How do I incorporate in the chain? Sorry, I know I should be seeking out the appropriate thread, but I want to order this, like, tomorrow.
Old 02-10-2015, 07:40 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
well, there is a difference in logic here...
with the Lumagen Mini, u (usually) profile way more points than is actually used in the LUT... with 65^3 LUTs u (obviously) don't do that, u profile as much as u can and the CMS (LS|CM|Argyll) will calculate the points...
obviously way more control, much better cal... also: now u need a good CMS with a great color engine (to calculate all these points and a few other things)...
and we've done LUTs for eeColor with the i1D3 in the past... no problem...
- M
Old 02-10-2015, 07:52 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
- M
Wasn't aware of this. I have a lot of reading to do tonight.
Old 02-10-2015, 08:22 PM
Iron Mike's Avatar
Quoted: 68 Post(s)
Liked: 413
all done with LS... I think back then we profiled a 17^3 so we sampled roughly 5,000 points... with Avg LLH on it took (if I remember correctly) 6.5 hours... results were pretty good...
nowadays with the K10-A I sample 11,000 points (with an additional pattern delay if the display is Plasma) and it takes 1.5 - 2 hours... 2.5 hours with the extra pattern delay for Plasma TVs...
CR-100 will be 15-20 mins slower than that (for that patch count)...
- M
Old 02-10-2015, 09:14 PM
Liked: 631
I don't think Chromapure supports the eecolor box. You'll have to use Calman, Light Illusions, or Argyl. Additionally, the eecolor box doesn't do 3D or 4K.
Also, you really need to be sure that your display benefits from a 3D LUTs. Not all do.
JimP is offline
Old 02-10-2015, 09:18 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 285
Is the additional pattern delay needed with OLED displays?
You say the eeColor box is not a VP. What happens to Lumagen? Can you explain the hookup? Is it BD player>Lumagen>eeColor box>display?
