Properly setting contrast and brightness on blu-ray player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-22-2014, 04:50 PM - Thread Starter
atek99's Avatar
I am having trouble setting brightness and contrast on my LCD TV using AVS HD patterns disc in a Panasonic DMP-BD87 Blu-ray player. When the player is set to normal picture mode I cannot get blacker than black or whiter than white(i.e. below 16 and above 234 respectively) to show from the AVS disc. If I change the player's mode to user and then adjust the default contrast and brightness settings on the player itself (a few clicks from 0 ) , I am then able to see the bars from the AVS disc and then adjust the TV controls to the proper levels. My question is this a legitimate means of doing this or am I making "two wrongs equal a right" and should I leave the Blu-ray player at its default settings.
Thanks in advance,
atek99
atek99 is offline
post #2 of 4 Old 08-22-2014, 09:50 PM
sawfish's Avatar
Quoted: 145 Post(s)
Liked: 145
You should not need to change Brightness or Contrast on the BD player. This post may help you:
AVS HD 709 - Blu-ray & MP4 Calibration
sawfish is offline
post #3 of 4 Old 08-23-2014, 08:29 AM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
The only thing I did on my blu-ray player is turn off noise reduction.
ZKACAL is offline
post #4 of 4 Old 08-23-2014, 12:26 PM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1043
Your blu-ray player should be set to defaults so that it is not doing any video enhancements at all. You want to adjust your panel with as clean of a signal path as possible. Some blu-ray players are just better than others when it comes to default settings.
Otto Pylot is offline
Reply Display Calibration
