How the hell am I supposed to calibrate like this? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-23-2014, 06:54 PM - Thread Starter
Liked: 0
I have a PS51F5500 and whenever I enter the menu it alters the actual image colors - sort of like "dims" the display. Maybe the idea was so that people can "focus" on the menu text or something? I don't know... but it kinda makes changing the brightness/contrast/sharpness/temp/black levels/etc/etc impossible since I never get to see the *true picture* while I'm tweaking the settings.
Samsung, WTF were you thinking? How am I supposed to do this?
Here is a picture I made to illustrate my problem:
Keeperza is offline
post #2 of 14 Old 08-23-2014, 09:49 PM
Rolls-Royce's Avatar
Quoted: 406 Post(s)
Liked: 572
Like it or not, it's what many of us have had to do over the years: measure, go into the menu and make changes, exit the menu and measure again, etc., etc.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3 of 14 Old 08-24-2014, 02:20 AM
James Freeman's Avatar
Quoted: 517 Post(s)
Liked: 341
Yep, deal with it.
James Freeman is offline
post #4 of 14 Old 08-24-2014, 05:38 AM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Get out of the Standard mode.
Edit: While you're at it, turn Sharpness to 0 - the only correct setting with Samsung!
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #5 of 14 Old 08-24-2014, 06:47 AM - Thread Starter
Liked: 0
That's not my settings, it's actually just a comparison I created from a screenshot.
I don't really know how to calibrate/measure and stuff with special filters/tool/dvds and whatnot, I just want to see the actual image while i'm tweaking the brightness/color/contrast
Why the hell do Samsung do this?! If anyone from Samsung see this, Please get them to make a software patch!
Keeperza is offline
post #6 of 14 Old 08-24-2014, 06:52 AM
buzzard767's Avatar
Liked: 2439
The steady reduction in luminance usually happens with static images when in the Normal mode. Do you have all Eco items turned off?
Buzz
post #7 of 14 Old 08-24-2014, 07:57 AM - Thread Starter
Liked: 0
No it's not anything like that, it happens every time you open the menu and actually want to change the brightness.
Happens in all modes, not just normal mode.
Dumbest thing I've ever seen.
Keeperza is offline
post #8 of 14 Old 08-24-2014, 09:47 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
something must be broke.
every TV I have seen goes to a small window at the bottom only showing the selected setting control
and the TV shows content normally.
Loving D65
CalWldLif is offline
post #9 of 14 Old 08-24-2014, 10:29 AM
rmongiovi's Avatar
Quoted: 27 Post(s)
Even for displays that use only a small bar across the bottom of the screen there can be an impact to the test pattern. Especially for a plasma with ABL, I would only measure the test pattern with the adjustment menu closed.
Is that annoying? Yeah. But what would be the fun if calibration was easy?
Buzz, I think the decrease in luminance of static images is a completely different issue. Though of course it's yet another roadblock to the convenience of calibrating the display.
rmongiovi is offline
post #10 of 14 Old 08-24-2014, 11:36 AM - Thread Starter
Liked: 0
Yes it does go to a small window when actually tweaking the brightness/etc.... but it still creates this "haze" or "filter" over the screen giving me an entirely different picture than when I finally exit that small window.
I've noticed it doesn't do this when watching normal TV, only when I enter the menu when playing a movie inside Plex.
The problem is in South Africa we only have 4 terrestrial channels, and the reception is bad... I basically only watch my content through Plex and would like to configure it there with 1080p content.
Maybe the Samsung Plex App is broken?
Keeperza is offline
post #11 of 14 Old 08-25-2014, 12:21 AM
Quoted: 406 Post(s)
Liked: 572
I doubt the app is "broken". It may be switching the set into a Game, PC, or similar mode internally when starting up (I say "internally" because those modes are normally used with external inputs), and the menu/GUI is overlaid in another mode. It may have to be done that way to give you any kind of user control at all within the app.
...Royce...
post #12 of 14 Old 08-25-2014, 02:12 AM - Thread Starter
Liked: 0
Well, It seems the Plex App was indeed broken, and the developer reports that he will fix the bug.
https://forums.plex.tv/index.php/top...nter-settings/
Thanks for all the help!
Keeperza is offline
post #13 of 14 Old 08-25-2014, 10:35 AM
Muza's Avatar
Hello, Just put the test patterns on a usb stick or HHD and calibrate the internal player, there should be no dimming that way, btw, is the same internal player for apps, usb and dlna.
Muza is online now
post #14 of 14 Old 08-31-2014, 02:22 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
To make things easier for you:
Switch to Movie Mode (since it is more accurate). Hit picture reset. Keep Brightness around 50. Contrast around 100. Color and tint around 50. Sharpness around 0.
Set Screen adjustment to Screen Fit. Then turn off everything that has an off option (dynamic contrast, noise reduction, auto motion plus, etc.).
And Backlight is up to you. Us calibrators tend to set Samsungs around 6 or so for watching in dimly lit conditions.
*I would however recommend the AVS 709 HD disc or any other other good calibration disc for properly adjusting the above settings I mentioned since every TV is slightly different (even if they are the same model).
ZKACAL is offline
Reply Display Calibration
