Help! Need UN65F8000 Service Menu ADC/WB settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-24-2014, 07:48 PM - Thread Starter
darkvader001's Avatar
Hi,
I looking for one owner of the Samsung LED UN65F8000 series. Like an idiot I played with my White Balance settings (couple of digits) in the service menu, but I cannot get back to original settings
So I'm looking for someone that can give me the original settings of this item in the service menu.
How to work:
Put the TV on an HDMI input source, Turn TV OFF, then press on the remote: MENU then 1, 8, 2 and in the end POWER to put the Tv on again. The tv is now starting up and service menu will appear in a couple of seconds.
Well now the settings:
Go to ADC/WB -> White Balance.
here you can see some settings like:
Sub Brightness
R Offset
G Offset
B Offset
Sub Contrast
R Gain
G Gain
B Gain
I need the digits behind thos settings.
I need the settings behind ADC/WB -> ADC Results too.
So can someone please send me an e-mail or post it here?
Kind Regards,
Darkvader
darkvader001 is offline
post #2 of 3 Old 08-24-2014, 08:22 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Keep in mind that the SM settings are set at the factory and are based, in part, on how the main board(s) QC and can be component specific. In other words, a setting of "5" for example, might not have the same result as a "5" on another tv of the exact same model and build. Good luck.
Otto Pylot is offline
post #3 of 3 Old 08-24-2014, 08:35 PM - Thread Starter
At this point is better than nothing :-), Hopefully someone can help me. I figure that my best bet is to get the numbers from someone that have the same exact model and size.
I know the panel version may be different but at least it will be something close enough to get me closer to what it was for mine.
Reply Display Calibration
