FSI (Flanders Scientific Inc) Monitors Firmware Updates - AVS | Home Theater Discussions And Reviews
post #1 of 3 Old 10-21-2014, 10:17 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 252 Post(s)
Liked: 670
New FSI Monitors Firmware Update Released
A new firmware version (1.0.00-1958) has just been posted for CFE2 Units.
Release Date: 20 October 2014
Firmware Version: 1.0.00-1958
Supported Monitors: BM090, BM210, BM230, CM171, CM172, CM240, CM250, CM320TD, CM420TD, CM500TD.
Release Notes
Monitors now support storage of up to 16 3D DIT LUTs with revised .datV2 LUT format.
- LightSpace and Lattice both now export in this format. DIT LUT is now toggled on/off via assigned function button.
- The 3D LUT that is toggled on/off is set on the Color Management menu by selecting the desired channel.
16 Channel Audio Loudness Monitoring has been added.
Time Code can now be toggled on/off via Function Button.
SDI Black Level Selection allows for easier full range vs. legal range monitor setup.
Default gamma is now 2.4 and default luminance menu setting is 29.
You may reset to previous defaults (2.2. and 35) by selecting those settings from the menu.
Graticules Info On/Off toggle allows line position and span size information to be turned on/off when using the custom graticules marker feature.
Fix for frozen screen when Show PsF as P was selected and H/V delay was toggled on.
OLED models default Flicker Free On.
As always you can get this free firmware update at www.FlandersScientific.com
Press Release:
Powerful New Update Now Available for CFE2 Equipped Monitors
It has been several months since our last significant firmware update, but we've been very busy during that time with a ground up rewrite of the firmware. We think you will agree that it has been well worth the wait.
Now Store Up to 16 3D DIT LUTs at a Time
Our DIT LUT format and supporting firmware has been updated to allow you to store up to 16 different 3D DIT LUTs on the monitor at a time as opposed to just a single LUT as in the previous firmware. Both LightSpace CMS and Lattice already export in this updated LUT format so you can start using this new functionality right away. We have also added the ability to toggle the selected DIT LUT on/off quickly with a single function button.
Our previous beta support of single channel audio loudness monitoring has been replaced by a 16 channel audio loudness meter.
Faster Access to On Screen Time Code
Time Code can now be turned on and off more rapidly using an assigned function key instead of having to go through a menu selection.
This new menu toggle allows for much simpler setup of the monitor for use with full range vs. limited range signal paths.
The graticules information display can now be toggled on and off from the marker menu.
Other Notable Changes
The default gamma setting on all CFE2 equipped units is now 2.4 and the default Luminance setting on the Video Menu is now 29. Previous defaults of 2.2 and 35 may still be selected from their respective menus. On OLED units Flicker Free Mode ON is now the default setting.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, CalPC, ControlCAL
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2 of 3 Old 12-19-2014, 02:35 PM - Thread Starter
Quoted: 252 Post(s)
Liked: 670
A new firmware version (1.0.00-1971) has just been posted for CFE2 Units.
Release Date: 19 December 2014
Firmware Version: 1.0.00-1971
Release Notes
CIE Measurement Feature: Select any point on screen to measure and plot its chromaticty values relative to your active color gamut selection. Additionally, you can select a secondary point on screen for comparative analysis of the two points. This comparison includes the ability to quantify the difference as a dE2000 value. Chromaticty can be plotted in either a CIE 1931 or CIE 1976 view. See page 13 of the updated user manual for details on this new feature.
Lock Brightness/Chroma/Contrast option added to the System Menu. Turn this ON to prevent accidental adjustment of current settings.
The various upload and save CFE/LUT commands have all been consolidated into a single Update LUT command to simplify the LUT loading process.
1D DIT LUT support added. UP to 16 custom 1D DIT LUTs may be uploaded in addition to the 16 3D DIT LUTs already supported. File format uses .lut extension and valid LUT names are dit01.lut through dit16.lut. Support for this 1D LUT format will has already been confirmed for the next official LightSpace CMS release with more programs to follow.
Improvements have been made to signal locking speed when switching sources.
As always you can get this free firmware update at: http://www.FlandersScientific.com
post #3 of 3 Old Today, 02:11 PM - Thread Starter
Quoted: 252 Post(s)
Liked: 670
A new firmware version (1.1.01-1983) has just been posted for All Units.
Release Date: 20 May 2015
Firmware Version: 1.1.01-1983
Supported Monitors: AM210, AM250, BM090, BM210, BM230, CM171, CM172, CM240, CM250, CM320TD, CM420TD, CM500TD, CM-170W, LM-0750W, LM-0950W, LM-1760W, LM-1770W, LM-2140W, LM-2340W, LM-2340TD, LM-2450W (Without CFE), LM-2450W (With CFE), LM-2452W (Without CFE), LM-2452W (With CFE), LM-2453W (Without CFE), LM-2453W (With CFE), LM-2460W, LM-2461W.
Release Notes
For AM, BM, CM Models
Adds two new user created markers: History Channel and TWC 2015.
Adds new Color Space position titled R709-JM. Any user created calibration LUT may be placed here, but when selecting this color space position the CIE1931/Judd Color Matching selection becomes greyed out on the Color Management Menu. The only functional difference between placing this LUT in the USER1 position vs. R709-JM position is that in the R709-JM position the Color Matching Function menu item is not accessible in order to prevent accidental application of Judd Modified CMF on top of a user generated 3D LUT that already directly targets a Judd Modified CMF white balance. If creating a calibration 3D LUT to load into this position the file name should be titled jm.cfe
Adds ability to override factory Rec709 position on OLED units so that operators can load there own calibration LUTs into these positions. This was previously locked out on OLED units with user access only being available on the user1, user2, and user3 positions.
Resolves H/V delay mode bug that showed grey instead of black background in blanking areas when H/V delay feature was activated. (BM & CM only)
For LM & CM-170W
As always you can get this free firmware update at http://www.FlandersScientific.com
Reply Display Calibration
