Samsung UN50H6400AFXZA Calibration - AVS Forum
Old 12-18-2014, 05:45 PM - Thread Starter
orestesdd's Avatar
Samsung UN50H6400AFXZA calibration settings:
Does anyone have a some settings that worked for them, or that they borrowed from someone else. By the way, does anyone know if the owner's manual will be enough to calibrate this set? Or do I need a more technical manual? Today I just bought this set at "samsung.com", and I hope to get it before Christmas, and if not, then I will wait until I get it. Thanks.
orestesdd is offline
Old 12-18-2014, 06:40 PM
GeorgeAB's Avatar
Quoted: 26 Post(s)
Liked: 128
Lightbulb
From the "stickies."
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
GeorgeAB is offline
Old 12-18-2014, 07:12 PM - Thread Starter
orestesdd's Avatar
Not a good response since the stickies are tooooo looooooooong posts. A search didn't help either. Thanks anyhow.
Old 12-18-2014, 07:54 PM
willieconway's Avatar
Quoted: 38 Post(s)
Liked: 48
Yeah man, what's up with all them words?
To calibrate your set you need a meter, software, and test patterns. Free software exists, as do free patterns, but here's an example of a complete bundle:
http://calman.spectracal.com/store/p...splay_Pro.html
Oh, and you'll need to spend the necessary time on learning and practicing.
willieconway is offline
Old 12-18-2014, 09:22 PM
GeorgeAB's Avatar
Quoted: 26 Post(s)
Liked: 128
Lightbulb
Education is such hard work! Who's got time for correct facts, anyway? Isn't there an easier way that doesn't take any effort? Copying someone else's work is so much simpler, even if the results likely won't work right.
GeorgeAB is offline
Old 12-18-2014, 10:25 PM - Thread Starter
orestesdd's Avatar
Thumbs down
Again, not a good response. What you state makes no sense and it is all Greek!
Old 12-18-2014, 10:26 PM - Thread Starter
orestesdd's Avatar
Thanks, this is better...
Old 12-24-2014, 09:27 PM - Thread Starter
orestesdd's Avatar
I found the following calibration for my Samsung 50" H6400 series TV:
Picture:
Picture Mode: Movie
Backlight --------> 17
Contrast ---------> 97
Brightness -------> 49
Sharpness -------> 12
Color -------------> 51
Tint (G/R) -------> G50/R50
Apply Picture Mode: [Current Source]
Picture Size: [Screen Fit]
3D: 3D Mode: [off]
PIP: [off]
Advanced Settings:
..............Dynamic Contrast: [off]
..............Black Tone: [off]
..............Flesh Tone: 0 (zero)
..............RGB Only Mode: [off]
..............Color Space: [Auto]
..............White Balance:
............................2 Point:
........................................Setting... ...Value
........................................R-Offset.....25
........................................G-Offset.....24
........................................B-Offset.....27
........................................R-Gain.......20
........................................G-Gain.......23
........................................B-Gain.......21
............................10 Point:
................................10 Point White Balance.............On
................................Level........Red.. ..Green....Blue
................................10%.........0..... +1...........0
................................20%.......+1...... .0..........-2
................................30%.........0..... ..0.........+2
................................40%.........0..... .-1...........0
................................50%........-1.......0.........+1
................................60%.........0..... .-1...........0
................................70%........-1......-2..........-2
................................80%.........0..... +2...........0
................................90%.......+1...... .0...........0
................................100%.....+2....... 0...........0
..............Gamma: [+1]
..............Motion Lighting: [off]
Picture Options:
..............Color Tone: [Warm2]
..............Digital Clean View: [off]
..............MPEG Noise Filter : [off]
..............HDMI Black Level: [Low]
..............Film Mode (grayed out): [off]
..............Auto Motion Plus: [off]
Picture Off
I hope these setting will help someone. These setting can also be found at: Samsung H6400 Expert Picture Settings Calibrations by Robert Wiley, Editor, Reviewer
Old 12-24-2014, 10:55 PM
GeorgeAB's Avatar
Quoted: 26 Post(s)
Liked: 128
Lightbulb
......I hope these setting will help someone. These setting can also be found at: Samsung H6400 Expert Picture Settings Calibrations by Robert Wiley, Editor, Reviewer
Did you post this in the owners' thread in the LCD Flat Panel Displays section of the forum? That's where such information is appropriate, NOT in the Display Calibration section. Copying other settings is not calibration. Such practice is a persistent myth that provides no assurance of an accurate image. Liking the results is not verification of accuracy or fidelity. Copying others' work has been abundantly proven to be unreliable and has even resulted in a less authentic image than preset factory modes in some cases. It's a role of the dice at best.
GeorgeAB is offline
Old 12-28-2014, 04:32 PM - Thread Starter
orestesdd's Avatar
I am not of the same opinion as yours. Like it or leave it! That's all!
P.S. I am very satisfied with these settings after reviewing them thru my DVE HD Basics blu-ray, Avia DVD, and Video Essential DVD running them on my PS3.
