Tripod mounting for Colormunki Design - AVS | Home Theater Discussions And Reviews
Old Yesterday, 01:33 PM - Thread Starter
ttnuagmada's Avatar
Found a decent deal on a Colormunki spectro to go along with my i1Display Pro. I can't, however seem to find anything at all about whether or not the Colormunki can be mounted to a tripod. Does anyone know if it can?
HTPC: I3 2100, Radeon 6950.
ttnuagmada is offline
Old Today, 04:43 AM
kkpro's Avatar
Quoted: 20 Post(s)
Liked: 25
I made a bracket to hold the Colormunki. It was just a piece of thin metal that I bent into a "U" shape and put padding on. I believe the threads for a tripod are 1/4-20. Held it nicely.
kkpro is online now
Old Today, 09:03 AM
sjschaff's Avatar
For temporary mounting I've used blue painter's tape from the hardware store. Creating a flattened loop of the tape to allow it to adhere to the meter and the flat top of the tripod mounting area will work well as long as the meter is relatively horizontal.
Steve Schaffer
sjschaff is offline
Old Today, 09:11 AM - Thread Starter
ttnuagmada's Avatar
Would you be willing to take a pic of it so I can get a good idea of what you did?
Old Today, 10:17 AM
kkpro's Avatar
Quoted: 20 Post(s)
Liked: 25
Sure, I can do that this evening. It has the mount for a Spyder 3 which I don't use anymore with it. If you want to PM me with your e-mail, I can send the picture to you.
kkpro is online now
Old Today, 06:43 PM
Rayjr's Avatar
Quoted: 67 Post(s)
Liked: 124
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
I actually designed a mount for this unit...and had a prototype made up..but there was no interest.
Here is the thread:
Need for a ColorMunki Tripod Mount?
Maybe you can get some ideas from it.
Later
RayJr
Rayjr is offline
