Image shifting issues - Refresh Rate/Handshake? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-21-2015, 05:50 PM - Thread Starter
Techgique's Avatar
Hello All,
Here is the gear I am working with (I know Frankenstein, it's what I was given):
RTI XP8s Processor
AMX Modula Autopatch HD-15 with audio
Crestron DVPHD Quad Processor
Extron Component to RGBHV converter
DVD Player
4 Computers
6 Samsung TVs
2 Sharp TVs
1 Projector
So for the TVs, I am sending from source to Autopatch to display
for the projector, I am sending from source to autopatch to DVPHD (for PIP processing capabilities) to Projector
All of my programming is working solid and each item can individually be controlled, turned on/off, and sent any discrete command.
My beef is when I fire up the system, occasionally the image on some of the devices is shifted left. So on either the TVs or the Projector there will be a black bar on the right side of the image.
This almost takes the DVPHD out of the equation, because the TVs are doing it too, though I hesitate to exonerate anything yet since it is all connected.
Sometimes sending the auto adjust command will fix it on the TVs, sometimes changing the output resolution of monitor 2 on a computer will fix it (the one that is displaying).
There are different refresh rates at play here. One of my computes only allows 75 or 85 hz on the secondary monitor (going to the autopatch) while the main monitor is at 60hz. There are no custom resolutions going on here, but perhaps the different resolutions being fed to the autopatch are messing with the other outputs? I need the Modula to be able to handle multiple inputs to multiple outputs (which it is doing for the most part) without any screen images being askew.
My goal is to hunt down the culprit and get everything in harmony since all other factors are operational. Any advice out there from the refresh rate/handshake specialists on going about troubleshooting the issue?
Techgique is offline
post #2 of 2 Old 05-22-2015, 06:30 AM - Thread Starter
Techgique's Avatar
As an additional note, the system sometimes turns on and all images are perfect, then after a few source changes, one of the TVs or projector (at random) will have the image shifted left with a black bar on the right side. (while some displays will show the same source properly)
Reply Display Calibration
