Clean optic, i1display pro (3) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-17-2015, 12:59 PM - Thread Starter
mac1guru's Avatar
Quoted: 12 Post(s)
Hi,
How do you use to clean your optic / lins on your i1display pro or other meter?
I can see a little dot like dust or something on my optic and I have tried to blow a little easy on it but it dont disaper.
How should I do?
Use a microfiber blanket to easy clean it?
You know the blanket that you can clean your glases with.
SpectraCal CalMan 5.4.1 Enthusiast
i1Display Pro
MobileForge at AppleTV 3rd gen / Amazon Fire TV stick
DVE / AVSHD709 / Ted's LightSpace CMS Calibration Disk
Samsung UE48H6275 (XXE) European model) / Playstation 4
mac1guru is online now
post #2 of 6 Old 08-17-2015, 02:38 PM
randal_r's Avatar
Quoted: 110 Post(s)
Liked: 86
Go to your nearest photography store; they will sell you a lens cleaner and have proper advice as to how it may be cleaned.
randal_r is offline
post #3 of 6 Old Yesterday, 12:46 PM
GeorgeAB's Avatar
Quoted: 62 Post(s)
Liked: 163
Lightbulb
If the user manual does not instruct you, contact the manufacturer before trying to get advice from forums.
GeorgeAB is offline
post #4 of 6 Old Yesterday, 02:09 PM - Thread Starter
mac1guru's Avatar
Quoted: 12 Post(s)
yes George but I have not gotten any replay on my email yet from x-rite.
So I have tried to blow on it with no luck.
But now I have purches a little blow-thing, that sucks in air then blow it out again and a little pensile soft one and that works great.
i1Display Pro
post #5 of 6 Old Yesterday, 05:29 PM
nuke's Avatar
Quoted: 219 Post(s)
Liked: 120
The I1-Display Pro (aka, i1DP3) lens is not very critical. Small amounts of dust will not bother it. The lens collects light, then it goes to a diffuser (like a white translucent screen). It isn't making a sharp image or anything.
If you get it all gunked up, that would be different. Don't do that.
nuke
nuke is offline
post #6 of 6 Old Today, 01:44 AM - Thread Starter
mac1guru's Avatar
Quoted: 12 Post(s)
OK I understand.
I have just used the plastic blow thing and a duster-pensle thing on it.
I have not toutch it with anything beside that so I'm safe I guess.
Beside when I did blow on it before with my mouth, I guesd that some saliva / spitt can have gone out of my mouth but I did not feal that so.
Skickat från min SM-G900F via Tapatalk
i1Display Pro
Reply Display Calibration
