LG OLED CMS Calibration - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 2 Post By Chad B
  • 2 Post By ConnecTEDDD
  • 2 Post By Miguelronda
  • 1 Post By ConnecTEDDD
Old 09-14-2015, 10:58 AM - Thread Starter
BigCoolJesus's Avatar
Quoted: 684 Post(s)
Liked: 378
Hey guys,
I know that using the CMS controls on the LG OLED's, in my case the EC9300 specifically, produce artifacts/negative impacts but is there a sweet spot/rule of thumb that allows for some subtle calibration without negative effects?
Just wondering if it's possible to try to tweak the CMS some to get it perfect. Out of the box my colors are close but need just a little tweaking (specifically Magenta and Yellow) to get them almost perfect. If I slowly adjust the CMS controls, what should I be looking for to see if they are causing unwanted negative impacts?
BigCoolJesus is offline
Old 09-14-2015, 12:46 PM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
Check an image or a test pattern with smooth color ramps for banding, dark areas, or hard transitions. Run the controls to the extremes to get a handle on what to look out for.
I personally don't think any improvements in the measurements would be worth it the way the controls work.
Sent from my SM-G900V using Tapatalk
BigCoolJesus and ConnecTEDDD like this.
Chad B is offline
Old 09-14-2015, 01:03 PM - Thread Starter
Quoted: 684 Post(s)
Liked: 378
Thanks Chad!
Old 09-14-2015, 01:20 PM
ConnecTEDDD's Avatar
Quoted: 1048 Post(s)
Liked: 1516
Originally Posted by BigCoolJesus View Post
Hey guys,
Hi, it need some practice and continuously verification of each correction step to see if the combination of controls you used don't introducing problems to your colors.
Each CMS control has it's own 'safe working range', and the combination of correcting values you use to one color may interact other colors also.
To be sure about your each step you have to verify each calibration step by looking some color saturation/luminance ramps patterns.
This is the reason I have added more than 150 Color Reproduction Patterns to my calibration disk, to be able to identify problems that meters don't see ,when you will measure only a few color points for verification.
Sometimes extensive usage of the available internal calibration controls values (for the hunt of the lowest dE numbers); this can introduce problems to the display that it's difficult to measure, that's why you have to test this with color reproduction patterns.
Here is an example of a problem:
Miguelronda and W3Rman like this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Old 09-18-2015, 05:29 AM
Miguelronda's Avatar
Quoted: 30 Post(s)
Moreover, setting the grayscale, even slightly, will produce inaccuracies in dark color levels. For example, cyan
Ted disc is an excellent tool to assess and locate this type of problem which will go unnoticed to the measure of the probe.
In short, if you calibrate the screen, you will be at the expense of increasing inexactiud color. No matter what you do, the magic does not work in this case.
10k and ConnecTEDDD like this.
Miguelronda is offline
Old 09-30-2015, 12:33 PM
Liked: 1516
For OLED's display profiling LightSpace CMS has been added an Anisometric Profiling patch sequence to it's latest version.
Anisometric sequences are better suited to displays that have any form of ABL, such as Plasmas and many OLEDs, and which also includes HDR displays where Sequential patch ordering can cause display overheating (overheating can actually be an issue on any display that has high peak luminance outputs, as it can cause the display to drift.
10k likes this.
