How do I calibrate 10 point gamma with colorhcfr? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Dominic Chan
post #1 of 6 Old 12-30-2015, 12:00 PM - Thread Starter
Overhaze's Avatar
I've used this guide and hcfr to calibrate my tvs for years http://www.curtpalme.com/forum/viewtopic.php?t=10457
The problem is it doesn't cover calibrating 10 point gamma and I have absolutely no idea how to do it. Can anyone talk me through it?
Overhaze is offline
post #2 of 6 Old 12-30-2015, 12:26 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
moving the RGB points at each IRE in the minus direction
lowers the luminance so gamma goes up.
increasing the RGB increase luminance so gamma goes down.
this is the general way.
use 2 point first. same deal.
then switch to 10 point and measure first to see if the 2 point changes stayed.
if the 2 point changes did stay, then you can use both 2 and 10 to bend the luminance curve to your target.
be aware, color temp D65/6504k will be done at the SAME time.
so first, run measures with different tv settings of both color temp and gamma settings to find the combo that gets the grayscale and gamma close.
Loving D65
CalWldLif is offline
post #3 of 6 Old 12-30-2015, 01:00 PM
VBB
VBB's Avatar
Quoted: 1008 Post(s)
Liked: 861
While you're adjusting the 2-point or 10-point controls on the TV, make sure to switch the preview window in HCFR to Gamma. That allows you to see your changes in real-time.
VBB is offline
post #4 of 6 Old 12-30-2015, 02:27 PM
Quoted: 1193 Post(s)
Liked: 300
I have outlined the steps in a previous post:
LG 60" PB5600 Calibration (Following "For Dummies")
VBB likes this.
Dominic Chan is online now
post #5 of 6 Old 12-31-2015, 06:57 AM
Liked: 300
A further note if you're trying to adjust the gamma using the 2-point controls [NOT recommended!]: when monitoring the 70- or 80-IRE point, the gamma curve on the preview may appear to be responding to the adjustment of RGB-High controls in real-time, but it will not show the actual gamma until you re-measure the 100-IRE point - and that will be very different.
VBB likes this.
post #6 of 6 Old 12-31-2015, 02:04 PM
VBB
VBB's Avatar
Liked: 861
Thank you Dominic. I was thinking grayscale for some reason
VBB is offline
Reply Display Calibration
