Samsung SUHD Quantum Dot .ccss file - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-22-2016, 07:57 PM - Thread Starter
Liked: 0
Question Samsung SUHD Quantum Dot .ccss file
Hello
I just got an i1D3 that seems to be working really well with my computer monitor. I do have some issues with a Samsung 55" JS8 though. While the meter seems to be reading light radiated from the set okayish, i.e. it seems possible to have a smooth gamma ramp, it always ends up with a colored tint. To my eyes, this colored tint does not appear on the computer monitor upon calibrating with hcfr.
I guess the meter could have some general issues measuring output from Samsung's SUHD sets, possibly something that could be fixed using a colorimeter calibration spectral sample. Unfortunately, I do not currently have the hardware to make a sample, but maybe someone else does?
From the looks of things, it seems straightforward, in HCFR select Advanced -> Meter correction file -> Build CCSS.
Most probably it is possible to invoke some ArgyllCMS command to achieve the same result.
I would be interested in seeing if a sample would improve reading of the new Samsungs, and a .ccss could be useful to anyone else who might come across a SUHD set.
Anyone able to help?
Almope is offline
post #2 of 4 Old 03-05-2017, 08:11 AM
RKCRLR's Avatar
Quoted: 12 Post(s)
I also have been looking for a correction file for a js8500 but haven't found one. Is there one out there?
Samsung UN65JS8500 TV
Samsung UBD-K8500 UHD Blu-Ray Player
Onkyo TX-NR646 Receiver
RKCRLR is offline
post #3 of 4 Old 03-09-2017, 05:16 PM
Quad5Ny's Avatar
Quoted: 47 Post(s)
Liked: 34
Try setting the Display Type to "Non-Refresh Display" in HCFR or "None" in DisplayCal.
You probably won't be able to do the CMS very accurately but the grayscale should come out ok.
Quad5Ny is offline
post #4 of 4 Old 04-16-2017, 03:48 PM
RKCRLR's Avatar
Quoted: 12 Post(s)
Thanks. Sorry I took so long, I lost the thread. Am I better off just leaving the TV at it's default settings than trying to calibrate the CMS?
RKCRLR is offline
Reply Display Calibration
suhd ccss i1d3 spectral sample
