R.Masciola's HDR-10 UHD Test Patterns - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 277Likes
post #811 of 815 Unread 05-11-2017, 11:16 PM
Soulnight's Avatar
Quoted: 258 Post(s)
Liked: 169
Hi Ryan,
last "Sendowl download link" I received from you was in February:
R.Masciola's UHD/HDR-10 Test Pattern Suite (.ts/.mp4) update REV_015 re-released!!
Am I using the latest version?
Thank you,
Florian
Soulnight is online now
post #812 of 815 Unread 05-12-2017, 06:26 AM
skschatzman's Avatar
Quoted: 210 Post(s)
Liked: 137
Originally Posted by Soulnight View Post
Hi Ryan,
Thank you,
Florian
Yes
Sent from my SM-G955U using Tapatalk
My P65-C1 Beta Calibration Settings (3.0.13.5)
skschatzman is offline
post #813 of 815 Unread 05-12-2017, 08:58 AM
Candle's Avatar
Liked: 1
Hello Ryan.
The Black Clipping and White Clipping patterns are really too short .
It already takes a few seconds before my JVC projector shows the patterns on the screen.
In the mean time, I'm sitting in the dark. This happens every time a pattern changes, and when the pattern apears on the screen, than after 2 seconds my Panasonic UB900 also shows a info screen on top which disappears after 5 seconds.
So when I finally can start using the Cliiping patterns, it almost go to the next Pattern, and the whole leaving in the dark and info-screen happens again and I have to go back and start with this ritual again.
For the regular patterns I always use the Pauze button, but for clipping it's not usefull.
So by using this clipping patterns I'm using the rewind a lot and wait till the infoscreen dissapears again, but during tweaking I'm so focussed on what I do that I forget to rewind, and there it goes again.
Is it possble to get all the Clipping patterns work much longer?
Candle is online now
post #814 of 815 Unread Yesterday, 08:19 AM
SJHT's Avatar
Quoted: 337 Post(s)
Liked: 176
Originally Posted by SJHT View Post
Is there some specific help on how to set contrast? Probably not simple , but the instructions for brightness seem more specific. For contrast, do you raise until you see nothing blinking above 1000 or does HDR make things different depending on source material. Thanks. SJ
Any help? Up to 2000ish nits can blink. Not sure where to set contrast. Thanks. SJ
SJHT is offline
post #815 of 815 Unread Yesterday, 09:18 PM
Quoted: 802 Post(s)
Liked: 534
How accurate would the clipping pattern be on a Vizio P Series? Does the display have to be profiled, and can it be done for Dolby Vision?
Sent from my XR6P10 using Tapatalk
DisplayCalNoob is offline
Reply Display Calibration
